2.1.4 Potentiometer(MCP3008)ο
Introductionο
The ADC function is used to convert analog signals into digital values. In this experiment, we use the MCP3008 ADC chip to perform this conversion. A potentiometer is used to generate a variable voltage, which changes the physical quantity. The MCP3008 then converts this analog voltage into a digital value that can be read and processed by the Raspberry Pi.
Required Componentsο
Schematic Diagramο
T-Board Name |
physical |
WiringPi |
BCM |
SPICE0 |
pin24 |
10 |
8 |
SPIMOSI |
pin19 |
12 |
10 |
SPIMISO |
pin21 |
13 |
9 |
SPISCLK |
pin23 |
14 |
11 |
GPIO22 |
pin15 |
22 |
Experimental Proceduresο
Step 1: Build the circuit.
Please place the chip by referring to the corresponding position depicted in the picture. Note that the grooves on the chip should be on the left when it is placed.
Step 2: Set up the SPI interface and install the spidev library (see SPI Configuration for detailed instructions). If you have already completed these steps, you can skip this.
Step 3: Open the code file
Step 4: Run.
sudo python3 2.1.4-2_Potentiometer_zero.py
After the code runs, rotate the knob on the potentiometer, the intensity of LED will change accordingly.
Warning
If there is an error prompt RuntimeError: Cannot determine SOC peripheral base address, please refer to If gpiozero doesnβt work.
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like davinci-kit-for-raspberry-pi/python-pi5. After modifying the code, you can run it directly to see the effect.
import spidev
from gpiozero import PWMLED
# Initialize PWM LED on GPIO22
led = PWMLED(22)
# Initialize SPI
spi = spidev.SpiDev()
spi.open(0, 0) # Bus 0, CS0 (CE0)
spi.max_speed_hz = 1000000
def read_adc(channel):
Read analog value from MCP3008
:param channel: ADC channel (0-7)
:return: 10-bit integer (0-1023)
return -1
# MCP3008 protocol
value = ((adc[1] & 3) << 8) | adc[2]
return value
Map a value from one range to another
# Read from MCP3008 channel 0
res = read_adc(0)
print('res = %d' % res)
# Map 0β1023 to 0β100%
R_val = MAP(res, 0, 1023, 0, 100)
# Set LED brightness
led.value = R_val / 100.0
time.sleep(0.2)
led.value = 0 # Turn off the LED
Code Explanation
gpiozerofor PWM LED control,spidevfor SPI communication with MCP3008, andtimefor implementing delays.#!/usr/bin/env python3 import spidev import time from gpiozero import PWMLED
Initialize a PWMLED object connected to GPIO pin 22 and configure SPI communication (Bus 0, CE0) with MCP3008.
# Initialize PWM LED on GPIO22 led = PWMLED(22) # Initialize SPI spi = spidev.SpiDev() spi.open(0, 0) # Bus 0, CS0 (CE0) spi.max_speed_hz = 1000000
Define a function named
read_adcto communicate with MCP3008 and read analog values from the specified channel (0β7).def read_adc(channel): """ Read analog value from MCP3008 :param channel: ADC channel (0-7) :return: 10-bit integer (0-1023) """ if channel < 0 or channel > 7: return -1 adc = spi.xfer2([1, (8 + channel) << 4, 0]) value = ((adc[1] & 3) << 8) | adc[2] return value
MAPto convert one range of values to another, useful for mapping ADC values to appropriate LED brightness levels.def MAP(x, in_min, in_max, out_min, out_max): return (x - in_min) * (out_max - out_min) / (in_max - in_min) + out_min
Continuously read the ADC value in a loop, mapping the 10-bit ADC value (0β1023) to a brightness level (0β100) for the LED. Adjust the LEDβs brightness accordingly. Wait 0.2 seconds between each read.
try: while True: # Read from MCP3008 channel 0 res = read_adc(0) print('res = %d' % res) # Map 0β1023 to 0β100% R_val = MAP(res, 0, 1023, 0, 100) # Set LED brightness led.value = R_val / 100.0 time.sleep(0.2) except KeyboardInterrupt: led.value = 0 # Turn off the LED
