πŸ‘‰ Ready to explore and create with us? Click [here] and join today!
2.2.5 Ultrasonic Sensor Module
Introduction
The ultrasonic sensor uses ultrasonic to accurately detect objects and measure distances. It sends out ultrasonic waves and converts them into electronic signals.
Required Components
../_images/2.2.5_ultrasonic_list.png
Schematic Diagram
../_images/2.2.5_ultrasonic_schematic.png
Experimental Procedures
Step 1: Build the circuit.
../_images/2.2.5_ultrasonic_circuit.png
Step 3: Run the executable file.
sudo python3 2.2.5_Ultrasonic.py
With the code run, the ultrasonic sensor module detects the distance between the obstacle ahead and the module itself, then the distance value will be printed on the screen.
Warning
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like davinci-kit-for-raspberry-pi/python-pi5. After modifying the code, you can run it directly to see the effect.
from gpiozero import DistanceSensor
from time import sleep
# Initialize the DistanceSensor using GPIO Zero library
# Trigger pin is connected to GPIO 23, Echo pin to GPIO 24
sensor = DistanceSensor(echo=24, trigger=23)
    # Main loop to continuously measure and report distance
        dis = sensor.distance * 100  # Measure distance and convert from meters to centimeters
        print('Distance: {:.2f} cm'.format(dis))  # Print the distance with two decimal precision
        sleep(0.3)  # Wait for 0.3 seconds before the next measurement
    # Handle KeyboardInterrupt (Ctrl+C) to gracefully exit the loop
Code Explanation
  1. Imports the DistanceSensor class from the gpiozero library for distance measurement, and the sleep function from the time module for delays.
  2. Initializes the ultrasonic distance sensor with the Echo pin connected to GPIO 24 and the Trigger pin to GPIO 23.
  3. The main loop continuously measures the distance, converts it from meters to centimeters, and prints it with two decimal precision. Then wait 0.3 seconds and re-measure the distance. Catches a KeyboardInterrupt (like Ctrl+C) to allow for a graceful exit from the script.
