2.2.1 Photoresistor(MCP3008)ο
Introductionο
Photoresistor is a commonly used component of ambient light intensity in life. It helps the controller to recognize day and night and realize light control functions such as night lamp. This project is very similar to potentiometer, and you might think it changing the voltage to sensing light.
Required Componentsο
Schematic Diagramο
T-Board Name |
physical |
WiringPi |
BCM |
SPICE0 |
pin24 |
10 |
8 |
SPIMOSI |
pin19 |
12 |
10 |
SPIMISO |
pin21 |
13 |
9 |
SPISCLK |
pin23 |
14 |
11 |
GPIO22 |
pin15 |
22 |
Experimental Proceduresο
Step 1: Build the circuit.
Step 2: Set up the SPI interface and install the spidev library (see SPI Configuration for detailed instructions). If you have already completed these steps, you can skip this.
Step 3: Go to the folder of the code.
sudo python3 2.2.1-2_Photoresistor_zero.py
When the code is running, the brightness of the LED will change according to the light intensity sensed by the photoresistor.
Warning
If there is an error prompt RuntimeError: Cannot determine SOC peripheral base address, please refer to If gpiozero doesnβt work.
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like davinci-kit-for-raspberry-pi/python-pi5. After modifying the code, you can run it directly to see the effect.
import spidev
from gpiozero import PWMLED
# Initialize a PWM LED on GPIO pin 22
led = PWMLED(22)
# Initialize SPI communication (Bus 0, CE0 -> GPIO8)
spi = spidev.SpiDev()
spi.open(0, 0) # Bus 0, CS0
spi.max_speed_hz = 1000000 # 1 MHz
# Function to read from MCP3008 channel (0β7)
def read_adc(channel):
Read analog value from MCP3008 (0β1023)
return -1
# MCP3008 protocol: Start bit, Single-ended mode, Channel (3 bits), filler
value = ((r[1] & 3) << 8) | r[2]
return value
# Define a function for mapping values from one range to another
# Main loop for reading ADC value and controlling LED brightness
def loop():
# Read analog value from channel 0 of MCP3008
analogVal = read_adc(0)
print('value = %d' % analogVal)
# Map 0β1023 to PWM range 0.0β1.0
led.value = analogVal / 1023.0
# Wait for 0.2 seconds
time.sleep(0.2)
# Run the main loop and handle KeyboardInterrupt for graceful shutdown
loop()
led.value = 0 # Turn off LED before exiting
Code Explanation
This segment imports the
PWMLEDclass from thegpiozerolibrary for controlling PWM LEDs,spidevfor SPI communication with MCP3008, andtimefor executing sleep/delay operations.#!/usr/bin/env python3 import spidev import time from gpiozero import PWMLED
Initializes a PWM LED connected to GPIO pin 22, and sets up the SPI interface for MCP3008 (Bus 0, CE0). The SPI clock speed is set to 1 MHz.
# Initialize a PWM LED on GPIO pin 22 led = PWMLED(22) # Initialize SPI communication (Bus 0, CE0 -> GPIO8) spi = spidev.SpiDev() spi.open(0, 0) # Bus 0, CS0 spi.max_speed_hz = 1000000 # 1 MHz
Defines a function to read from a specific MCP3008 ADC channel. It sends a 3-byte command over SPI and extracts a 10-bit value (0β1023) from the response.
# Function to read from MCP3008 channel (0β7) def read_adc(channel): """ Read analog value from MCP3008 (0β1023) """ if channel < 0 or channel > 7: return -1 # MCP3008 protocol: Start bit, Single-ended mode, Channel (3 bits), filler r = spi.xfer2([1, (8 + channel) << 4, 0]) value = ((r[1] & 3) << 8) | r[2] return value
Defines a helper function
MAP()that maps a number from one range to another. This is useful for converting raw ADC values into a suitable PWM range.# Define a function for mapping values from one range to another def MAP(x, in_min, in_max, out_min, out_max): return (x - in_min) * (out_max - out_min) / (in_max - in_min) + out_min
This section implements a loop that repeatedly reads an analog value from channel 0 of the MCP3008, maps it to a PWM brightness value (0.0β1.0), and applies it to the LED. The loop pauses for 0.2 seconds between readings.
# Main loop for reading ADC value and controlling LED brightness def loop(): while True: # Read analog value from channel 0 of MCP3008 analogVal = read_adc(0) print('value = %d' % analogVal) # Map 0β1023 to PWM range 0.0β1.0 led.value = analogVal / 1023.0 # Wait for 0.2 seconds time.sleep(0.2)
Executes the loop and gracefully handles
KeyboardInterrupt. When the user stops the program (Ctrl+C), the LED is turned off before exiting.# Run the main loop and handle KeyboardInterrupt for graceful shutdown try: loop() except KeyboardInterrupt: # Turn off LED before exiting led.value = 0
