๐Ÿ‘‰ Ready to explore and create with us? Click [here] and join today!
2.1.4 Potentiometer๏ƒ
Introduction๏ƒ
The ADC function can be used to convert analog signals to digital signals, and in this experiment, ADC0834 is used to get the function involving ADC. Here, we implement this process by using potentiometer. Potentiometer changes the physical quantity โ€“ voltage, which is converted by the ADC function.
Required Components๏ƒ
../_images/2.1.7_potentiometer_list.png
Schematic Diagram๏ƒ
../_images/2.1.7_potentiometer_second_1.png ../_images/2.1.7_potentiometer_second_2.png
Experimental Procedures๏ƒ
Step 1: Build the circuit.
../_images/2.1.7_Potentiometer_circuit.png
Please place the chip by referring to the corresponding position depicted in the picture. Note that the grooves on the chip should be on the left when it is placed.
Step 2: Open the code file
Step 3: Run.
sudo python3 2.1.4_Potentiometer.py
After the code runs, rotate the knob on the potentiometer, the intensity of LED will change accordingly.
Warning
If there is an error prompt RuntimeError: Cannot determine SOC peripheral base address, please refer to If gpiozero doesnโ€™t work.
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like davinci-kit-for-raspberry-pi/python-pi5. After modifying the code, you can run it directly to see the effect.
from gpiozero import PWMLED
import ADC0834
# Initialize a PWM LED on GPIO pin 22
led = PWMLED(22)
# Set up the ADC0834 module
ADC0834.setup()
    Map a value from one range to another.
    :param x: The value to be mapped.
    :param in_min: The lower bound of the value's current range.
    :param in_max: The upper bound of the value's current range.
    :param out_min: The lower bound of the value's target range.
    :param out_max: The upper bound of the value's target range.
    :return: The mapped value.
        # Get the current reading from the ADC0834 module
        res = ADC0834.getResult()
        print('res = %d' % res)
        # Map the ADC value to a range suitable for setting LED brightness
        R_val = MAP(res, 0, 255, 0, 100)
        # Set the LED brightness
        led.value = float(R_val / 100)
        # Wait for 0.2 seconds before reading again
        time.sleep(0.2)
# Graceful exit when 'Ctrl+C' is pressed
    led.value = 0  # Turn off the LED
Code Explanation
  1. gpiozero for PWM LED control, ADC0834 for analog-to-digital conversion, and time for implementing delays.
    import ADC0834
  2. Initialize a PWMLED object connected to GPIO pin 22 and set up the ADC0834 converter.
    led = PWMLED(22)
    ADC0834.setup()
  3. Define a function named MAP to convert one range of values to another, useful for mapping ADC values to appropriate LED brightness levels.
  4. Continuously read the ADC value in a loop, mapping the ADC reading (0-255) to a brightness level (0-100) for the LED. Adjust the LEDโ€™s brightness based on this mapped value. Implement a delay of 0.2 seconds for better readability and stability.
            time.sleep(0.2)
