๐Ÿ‘‰ Ready to explore and create with us? Click [here] and join today!
3.1.5 Battery Indicator(MCP3008)๏ƒ
_images/mcp3008_and_adc0834.jpg
Introduction๏ƒ
In this project, we will make a battery indicator device that can visually display the battery level on the LED Bargraph.
Warning
Do not use battery components that exceed 3.3V to avoid overloading, which may damage the chip or Raspberry Pi.
Required Components๏ƒ
_images/list2_Battery_Indicator.png
Schematic Diagram๏ƒ
T-Board Name
physical
wiringPi
SPICE0
Pin 24
10
8
SPIMOSI
Pin 19
12
10
SPIMISO
Pin 21
13
9
SPISCLK
Pin 23
14
11
GPIO25
Pin 22
GPIO12
Pin 32
26
12
GPIO16
Pin 36
27
16
GPIO20
Pin 38
28
20
GPIO21
Pin 40
29
21
GPIO5
Pin 29
21
GPIO6
Pin 31
22
GPIO13
Pin 33
23
13
GPIO19
Pin 35
24
19
GPIO26
Pin 37
25
26
_images/schematic_battery_indicator_mcp3008.png
Experimental Procedures๏ƒ
Step 1: Build the circuit.
_images/july24_3.1.5_battery_indicator_mcp3008.png
For C Language Users๏ƒ
cd ~/davinci-kit-for-raspberry-pi/c/3.1.5-2/
Step 3: Compile the code.
gcc 3.1.5_BatteryIndicator.c -lwiringPi
After the program runs, give the 3rd pin of MCP3008 and the GND a lead-out wire separately and then lead them to the two poles of a battery separately. You can see the corresponding LED on the LED Bargraph is lit up to display the power level (measuring range: 0-5V).
Code๏ƒ
#include <wiringPi.h>
#include <wiringPiSPI.h>
#include <stdio.h>
#define SPI_CHANNEL 0
#define SPI_SPEED   1000000  // 1MHz
#define VREF        3.3
int pins[10] = {6, 26, 27, 28, 29, 21, 22, 23, 24, 25};
int read_ADC(int channel)
    unsigned char buffer[3];
    buffer[0] = 1;  // Start bit
    buffer[1] = (8 + channel) << 4;  // Single-ended mode
    buffer[2] = 0;
    int value = ((buffer[1] & 3) << 8) | buffer[2];
    return value;
void LedBarGraph(int value) {
    for (int i = 0; i < 10; i++) {
        if (i < value)
        digitalWrite(pins[i], HIGH);
    else
        digitalWrite(pins[i],LOW);
int main(void)
    if (wiringPiSetup() == -1) {
        printf("setup wiringPi failed!\n");
        printf("SPI setup failed!\n");
        pinMode(pins[i], OUTPUT);
    while (1) {
        int analogVal = read_ADC(0);  // MCP3008 CH0
        if (analogVal < 0) continue;
        float voltage = analogVal * VREF / 1023.0;
        int level = analogVal * 10 / 1024;
        if (level > 10) level = 10;
        LedBarGraph(level);
        printf("ADC Value: %d\tVoltage: %.2f V\tLevel: %d\n", analogVal, voltage, level);
        delay(200);
Code Explanation๏ƒ
    buffer[1] = (8 + channel) << 4;  // Single-ended mode, CH0~CH7
    buffer[2] = 0;
    int value = ((buffer[1] & 3) << 8) | buffer[2];  // Combine 10-bit result
    return value;
This function reads analog values from the MCP3008 ADC chip using SPI. The channel parameter selects one of the 8 analog inputs (CH0โ€“CH7). The MCP3008 returns a 10-bit digital value between 0 and 1023 representing the analog voltage.
        if (i < value)
            digitalWrite(pins[i], HIGH);  // Turn on LED (assumes active HIGH wiring)
        else
            digitalWrite(pins[i], LOW);   // Turn off LED
This function controls a 10-LED bar graph display. Each LED represents 1/10th of the voltage range. LEDs are turned on in order up to the specified level.
Note: This version assumes LED anodes are connected to GPIOs and cathodes to GND (i.e. active HIGH).
int main(void)
        digitalWrite(pins[i], HIGH);  // Initialize all LEDs to ON
    while (1) {
        int analogVal = read_ADC(0);  // Read voltage on CH0
        int level = analogVal * 10 / 1024;  // Map to 0โ€“10 levels
        LedBarGraph(level);  // Display level on LEDs
        delay(200);  // Update rate: 5 Hz
Main program logic:
  • Initializes wiringPi and SPI communication.
  • Sets GPIO pins as outputs for controlling the 10-LED bar.
  • Continuously reads analog voltage via MCP3008 (CH0).
  • Converts the reading to a voltage using VREF = 3.3V.
  • Scales voltage to a 0โ€“10 level bar graph and lights up LEDs.
  • Displays the raw ADC value, voltage (in volts), and LED level via serial console.
This acts as a visual battery level indicator or analog voltmeter.
For Python Language Users๏ƒ
Step 2: Set up the SPI interface and install the spidev library (see SPI Configuration for detailed instructions). If you have already completed these steps, you can skip this.
Step 3: Go to the folder of the code.
sudo python3 3.1.5-2_BatteryIndicator.py
After the program runs, give the 3rd pin of ADC0834 and the GND a lead-out wire separately and then lead them to the two poles of a battery separately. You can see the corresponding LED on the LED Bargraph is lit up to display the power level (measuring range: 0-5V).
Warning
If there is an error prompt RuntimeError: Cannot determine SOC peripheral base address, please refer to If gpiozero doesnโ€™t work.
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like davinci-kit-for-raspberry-pi/python. After modifying the code, you can run it directly to see the effect.
import RPi.GPIO as GPIO
import spidev
# GPIO pins connected to 10 LEDs, ordered from left to right
led_pins = [25, 12, 16, 20, 21, 5, 6, 13, 19, 26]  # BCM numbering
# GPIO setup
GPIO.setmode(GPIO.BCM)
for pin in led_pins:
    GPIO.setup(pin, GPIO.OUT)
    GPIO.output(pin, GPIO.LOW)
# Initialize SPI
spi = spidev.SpiDev()
spi.open(0, 0)  # Bus 0, CE0
# Read value from MCP3008 channel
def read_adc(channel):
        return -1
    value = ((r[1] & 0x03) << 8) | r[2]
    return value
# Light up LED bar graph according to value
def led_bar_graph(level):
    for i, pin in enumerate(led_pins):
        if i < level:
            GPIO.output(pin, GPIO.HIGH)
# Main loop
        analog_val = read_adc(0)  # Read from MCP3008 channel 0
        level = int(analog_val * 10 / 1023)
        print(f"ADC: {analog_val}, Level: {level}")
        time.sleep(0.2)
finally:
    GPIO.cleanup()
    spi.close()
Code Explanation๏ƒ
This program reads analog voltage from an MCP3008 ADC and displays the result on a 10-LED bar graph using a Raspberry Pi (BCM pin layout).
  1. Import Modules
    • RPi.GPIO controls the GPIO pins on Raspberry Pi.
    • spidev communicates with MCP3008 via SPI.
    • time provides delay/sleep functionality.
    import spidev
  2. GPIO LED Setup
    A list of 10 GPIO pins is defined for LED control. These pins are configured as output and initialized to LOW (off).
  3. SPI Initialization
    Initializes SPI bus 0 and chip enable 0 (CE0) to communicate with MCP3008. The communication speed is set to 1 MHz.
  4. ADC Read Function
    Reads an analog value from a specified MCP3008 channel (0โ€“7). The function sends a 3-byte SPI command and decodes the 10-bit result.
            return -1
        return value
  5. LED Bar Graph Function
    Lights up LEDs based on the analog level. If the level is 7, the first 7 LEDs will be ON and the rest OFF.
            if i < level:
  6. Main Loop
    Continuously reads analog input from channel 0, scales the result to a value from 0 to 10, and updates the LED display accordingly. Prints ADC and level values for monitoring.
            time.sleep(0.2)
  7. Cleanup on Exit
    When Ctrl+C is pressed, the program turns off all LEDs, cleans up GPIO state, and closes the SPI interface.
    finally:
        GPIO.cleanup()
        spi.close()
