3.1.4 Smart Fan(MCP3008)
_images/mcp3008_and_adc0834.jpg
In this project, we will use motors, buttons and thermistors to make a manual + automatic smart fan whose wind speed is adjustable.
_images/list2_Smart_Fan.png
Schematic Diagram
T-Board Name
physical
wiringPi
SPICE0
Pin 24
10
8
SPIMOSI
Pin 19
12
10
SPIMISO
Pin 21
13
9
SPISCLK
Pin 23
14
11
GPIO22
Pin 15
GPIO5
Pin 29
21
GPIO6
Pin 31
22
GPIO13
Pin 33
23
13
_images/schematic_3.1.4_smart_fan_mcp3008.png
Experimental Procedures
Step 1: Build the circuit.
_images/july24_3.1.4_smart_fan_mcp3008.png
The power module can apply a 9V battery with the 9V Battery Buckle in the kit. Insert the jumper cap of the power module into the 5V bus strips of the breadboard.
_images/image118.jpeg
For C Language Users
Step 2: Get into the folder of the code.
cd ~/davinci-kit-for-raspberry-pi/c/3.1.4-2/
Step 3: Compile.
gcc 3.1.4_SmartFan.c -o SmartFan -lwiringPi -lm
Step 4: Run the executable file above.
./SmartFan
As the code runs, start the fan by pressing the button. Every time you press, 1 speed grade is adjusted up or down. There are 5 kinds of speed grades: 0~4. When set to the 4th speed grade and you press the button, the fan stops working with a 0 wind speed.
Once the temperature goes up or down for more than 2℃, the speed automatically gets 1-grade faster or slower.
#include <wiringPi.h>
#include <wiringPiSPI.h>
#include <stdio.h>
#include <softPwm.h>
#include <math.h>
#define SPI_CHANNEL 0
#define SPI_SPEED   1000000
#define MotorPin1   21
#define MotorPin2   22
#define MotorEnable 23
#define BtnPin      3
int read_ADC(int channel)
    unsigned char buffer[3];
    buffer[0] = 1;                      // Start bit
    buffer[1] = (8 + channel) << 4;     // Single-ended mode and channel
    buffer[2] = 0;
    int result = ((buffer[1] & 3) << 8) | buffer[2];
    return result;
int temperture()
    int analogVal = read_ADC(0);
    double Vr = 3.3 * analogVal / 1023.0;  // Use 3.3V as Vref for MCP3008
    double Rt = 10000.0 * Vr / (3.3 - Vr);
    double temp = 1 / (((log(Rt / 10000.0)) / 3950.0) + (1 / (273.15 + 25.0)));
    double cel = temp - 273.15;
    double Fah = cel * 1.8 + 32;
    printf("Celsius: %.2f C  Fahrenheit: %.2f F\n", cel, Fah);
    return (int)cel;
int motor(int level)
    if (level == 0) {
        digitalWrite(MotorEnable, LOW);
    if (level >= 4) {
        level = 4;
    digitalWrite(MotorEnable, HIGH);
    softPwmWrite(MotorPin1, level * 25);
    return level;
void setup()
    if (wiringPiSetup() == -1) {
        printf("wiringPi setup failed!\n");
        return;
        printf("SPI setup failed!\n");
        return;
    softPwmCreate(MotorPin1, 0, 100);
    softPwmCreate(MotorPin2, 0, 100);
    pinMode(MotorEnable, OUTPUT);
    pinMode(BtnPin, INPUT);
int main(void)
    setup();
    int currentState, lastState = 0;
    int level = 0;
    int currentTemp, markTemp = 0;
    while (1) {
        currentState = digitalRead(BtnPin);
        currentTemp = temperture();
        if (currentTemp <= 0) continue;
        if (currentState == 1 && lastState == 0) {
            level = (level + 1) % 5;
            markTemp = currentTemp;
            delay(500);
        lastState = currentState;
        if (level != 0) {
            if (currentTemp - markTemp <= -2) {
                level = level - 1;
            if (currentTemp - markTemp >= 2) {
                level = level + 1;
        level = motor(level);
Code Explanation
    buffer[2] = 0;
    return result;
This function is used to read analog input from MCP3008 on the specified channel. It sends a 3-byte SPI command and returns a 10-bit digital value between 0–1023.
int temperture()
    return (int)cel;
The temperture() function reads the thermistor analog signal via MCP3008, calculates voltage, resistance, then converts to Celsius and Fahrenheit using the thermistor formula (Steinhart–Hart approximation).
    if (level == 0) {
    if (level >= 4) {
        level = 4;
    return level;
This motor() function controls fan speed via PWM. Level ranges from 0–4, where 0 turns the fan off and each level increases the duty cycle by 25%.
void setup()
        return;
        return;
The setup() function initializes WiringPi, sets up SPI, configures PWM and GPIO pins needed for motor control and button input.
int main(void)
    setup();
    int level = 0;
    while (1) {
            delay(500);
        if (level != 0) {
                level = level - 1;
                level = level + 1;
The main() function contains the program loop:
  1. Constantly checks button state and reads current temperature.
  2. On button press, fan level increases (cycles 0–4) and saves temperature.
  3. If temperature changes by ±2°C, it auto-adjusts fan speed accordingly.
  4. Calls motor(level) to update PWM output based on current level.
For Python Language Users
Step 2: Set up the SPI interface and install the spidev library (see SPI Configuration for detailed instructions). If you have already completed these steps, you can skip this.
Step 3: Get into the folder of the code.
Step 4: Run.
sudo python3 3.1.4-2_SmartFan.py
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like davinci-kit-for-raspberry-pi/python. After modifying the code, you can run it directly to see the effect.
import RPi.GPIO as GPIO
import spidev
import math
# Pin configuration
BTN_PIN = 22            # Button GPIO (physical pin 15)
MOTOR_IN1 = 5           # Motor forward
MOTOR_IN2 = 6           # Motor backward
MOTOR_EN = 13           # PWM enable pin
# GPIO setup
GPIO.setmode(GPIO.BCM)
GPIO.setup(BTN_PIN, GPIO.IN, pull_up_down=GPIO.PUD_UP)
GPIO.setup(MOTOR_IN1, GPIO.OUT)
GPIO.setup(MOTOR_IN2, GPIO.OUT)
GPIO.setup(MOTOR_EN, GPIO.OUT)
# PWM setup for motor speed control
pwm = GPIO.PWM(MOTOR_EN, 1000)  # 1kHz frequency
pwm.start(0)
# Initialize SPI for MCP3008
spi = spidev.SpiDev()
spi.open(0, 0)  # Bus 0, CE0
# Global variables
level = 0
currentTemp = 0
markTemp = 0
def read_adc(channel):
        return -1
    return value
def temperature():
    analogVal = read_adc(0)
    tempK = 1.0 / (((math.log(Rt / 10000.0)) / 3950.0) + (1.0 / (273.15 + 25.0)))
    Cel = tempK - 273.15
    return Cel
def motor_run(level):
    if level == 0:
        GPIO.output(MOTOR_IN1, GPIO.LOW)
        GPIO.output(MOTOR_IN2, GPIO.LOW)
        pwm.ChangeDutyCycle(0)
        return 0
    if level >= 4:
        level = 4
    GPIO.output(MOTOR_IN1, GPIO.HIGH)
    pwm.ChangeDutyCycle(level * 25)  # Map level (1–4) to 25%–100%
    return level
def changeLevel(channel):
    global level, currentTemp, markTemp
    print("Button pressed")
# Add event detection for button press
GPIO.add_event_detect(BTN_PIN, GPIO.FALLING, callback=changeLevel, bouncetime=300)
def main():
    markTemp = temperature()
        currentTemp = temperature()
        if level != 0:
            if currentTemp - markTemp <= -2:
                level -= 1
            elif currentTemp - markTemp >= 2:
                if level < 4:
                    level += 1
        level = motor_run(level)
        time.sleep(0.2)
    main()
finally:
    pwm.stop()
    GPIO.cleanup()
    spi.close()
Code Explanation
  1. Import required modules:
    • RPi.GPIO for GPIO control (button and motor),
    • spidev for communicating with MCP3008 ADC,
    • time for delays,
    • math for temperature calculation using logarithmic functions.
    import spidev
    import math
  2. Set up GPIO pins:
    • Button on GPIO22 (with internal pull-up),
    • Motor control using GPIO5 (forward), GPIO6 (backward), and GPIO13 (PWM enable).
    BTN_PIN = 22
    MOTOR_IN1 = 5
    MOTOR_IN2 = 6
    MOTOR_EN = 13
    pwm.start(0)
  3. Initialize SPI communication to the MCP3008 (Bus 0, Chip Enable 0) at 1 MHz.
    spi.open(0, 0)
    spi.max_speed_hz = 1000000
  4. Define read_adc() function to read a 10-bit analog value (0–1023) from the specified MCP3008 channel (0–7).
            return -1
        return value
  5. Define temperature() function to:
    • Convert analog voltage to resistance,
    • Apply the Steinhart–Hart equation to compute temperature in Celsius.
    def temperature():
        return Cel
  6. Define motor_run() to:
    • Stop motor at level 0,
    • Run motor forward at increasing speed based on level 1–4, with PWM duty cycle of 25% to 100%.
        if level == 0:
            return 0
        if level >= 4:
            level = 4
        return level
  7. Define changeLevel() callback for button press to:
    • Increase the motor level cyclically (0 to 4),
    • Record the current temperature as the new baseline.
  8. Define main() loop to:
    • Monitor temperature change relative to the marked temperature,
    • Decrease level if temperature drops by 2°C or more,
    • Increase level if it rises by 2°C or more,
    • Adjust motor speed accordingly every 0.2 seconds.
    def main():
            if level != 0:
                    level -= 1
                    if level < 4:
                        level += 1
            time.sleep(0.2)
  9. Run the main function and ensure proper cleanup on Ctrl+C (stop motor, cleanup GPIO, close SPI).
        main()
    finally:
        pwm.stop()
        GPIO.cleanup()
        spi.close()
