3.1.5 Battery Indicator
_images/mcp3008_and_adc0834.jpg
In this course, we will make a battery indicator device that can visually display the battery level on the LED Bargraph.
Components
_images/list_Battery_Indicator.png
Schematic Diagram
T-Board Name
physical
wiringPi
GPIO17
Pin 11
0
17
GPIO18
Pin 12
GPIO27
Pin 13
GPIO25
Pin 22
GPIO12
Pin 32
26
12
GPIO16
Pin 36
27
16
GPIO20
Pin 38
28
20
GPIO21
Pin 40
29
21
GPIO5
Pin 29
21
GPIO6
Pin 31
22
GPIO13
Pin 33
23
13
GPIO19
Pin 35
24
19
GPIO26
Pin 37
25
26
_images/Schematic_three_one5.png
Experimental Procedures
Step 1: Build the circuit.
_images/image248.png
For C Language Users
cd ~/davinci-kit-for-raspberry-pi/c/3.1.5/
Step 3: Compile the code.
gcc 3.1.5_BatteryIndicator.c -lwiringPi
After the program runs, give the 3rd pin of ADC0834 and the GND a lead-out wire separately and then lead them to the two poles of a battery separately. You can see the corresponding LED on the LED Bargraph is lit up to display the power level (measuring range: 0-5V).
Code Explanation
void LedBarGraph(int value){
    for(int i=0;i<10;i++){
        digitalWrite(pins[i],HIGH);
    for(int i=0;i<value;i++){
        digitalWrite(pins[i],LOW);
This function works for controlling the turning on or off of the 10 LEDs on the LED Bargraph. We give these 10 LEDs high levels to let they are off at first, then decide how many LEDs are lit up by changing the received analog value.
int main(void)
    uchar analogVal;
    if(wiringPiSetup() == -1){ //when initialize wiring failed,print messageto screen
        printf("setup wiringPi failed !");
        return 1;
    pinMode(ADC_CS,  OUTPUT);
    pinMode(ADC_CLK, OUTPUT);
    for(int i=0;i<10;i++){       //make led pins' mode is output
        pinMode(pins[i], OUTPUT);
        analogVal = get_ADC_Result(0);
        LedBarGraph(analogVal/25);
        delay(100);
    return 0;
analogVal produces values (0-255) with varying voltage values (0-5V), ex., if a 3V is detected on a battery, the corresponding value 152 is displayed on the voltmeter.
The 10 LEDs on the LED Bargraph are used to display the analogVal readings. 255/10=25, so every 25 the analog value increases, one more LED turns on, ex., if “analogVal=150 (about 3V), there are 6 LEDs turning on.”
For Python Language Users
Step 3: Run the executable file.
sudo python3 3.1.5_BatteryIndicator.py
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like davinci-kit-for-raspberry-pi/python.
import RPi.GPIO as GPIO
import ADC0834
ledPins = [25, 12, 16, 20, 21, 5, 6, 13, 19, 26]
def setup():
    GPIO.setmode(GPIO.BCM)
    ADC0834.setup()
    for i in ledPins:
        GPIO.setup(i, GPIO.OUT)
        GPIO.output(i, GPIO.HIGH)
def LedBarGraph(value):
    for i in ledPins:
        GPIO.output(i,GPIO.HIGH)
    for i in range(value):
        GPIO.output(ledPins[i],GPIO.LOW)
def destroy():
    GPIO.cleanup()
def loop():
        LedBarGraph(int(analogVal/25))
if __name__ == '__main__':
    setup()
        loop()
        destroy()
Code Explanation
    for i in ledPins:
def loop():
    while True:
Phenomenon Picture
_images/image249.jpeg
