.. note:: Hello, welcome to the SunFounder Raspberry Pi & Arduino & ESP32 Enthusiasts Community on Facebook! Dive deeper into Raspberry Pi, Arduino, and ESP32 with fellow enthusiasts. **Why Join?** - **Expert Support**: Solve post-sale issues and technical challenges with help from our community and team. - **Learn & Share**: Exchange tips and tutorials to enhance your skills. - **Exclusive Previews**: Get early access to new product announcements and sneak peeks. - **Special Discounts**: Enjoy exclusive discounts on our newest products. - **Festive Promotions and Giveaways**: Take part in giveaways and holiday promotions. πŸ‘‰ Ready to explore and create with us? Click [|link_sf_facebook|] and join today! .. _3.1.5_c_mcp3008: 3.1.5 Battery Indicator(MCP3008) ================================== .. note:: .. image:: img/mcp3008_and_adc0834.jpg :width: 25% :align: left Depending on your kit version, please identify whether you have **ADC0834** or **MCP3008** and proceed with the matching section. Introduction -------------- In this project, we will make a battery indicator device that can visually display the battery level on the LED Bargraph. .. warning:: Do not use battery components that exceed 3.3V to avoid overloading, which may damage the chip or Raspberry Pi. Required Components ------------------------------ In this project, we need the following components. .. image:: img/list2_Battery_Indicator.png :align: center Schematic Diagram ------------------- ============ ======== ======== === T-Board Name physical wiringPi BCM SPICE0 Pin 24 10 8 SPIMOSI Pin 19 12 10 SPIMISO Pin 21 13 9 SPISCLK Pin 23 14 11 GPIO25 Pin 22 6 25 GPIO12 Pin 32 26 12 GPIO16 Pin 36 27 16 GPIO20 Pin 38 28 20 GPIO21 Pin 40 29 21 GPIO5 Pin 29 21 5 GPIO6 Pin 31 22 6 GPIO13 Pin 33 23 13 GPIO19 Pin 35 24 19 GPIO26 Pin 37 25 26 ============ ======== ======== === .. image:: img/schematic_battery_indicator_mcp3008.png :align: center Experimental Procedures ------------------------- **Step 1:** Build the circuit. .. image:: img/july24_3.1.5_battery_indicator_mcp3008.png **For C Language Users** ^^^^^^^^^^^^^^^^^^^^^^^^^ **Step 2:** Go to the folder of the code. .. raw:: html .. code-block:: cd ~/davinci-kit-for-raspberry-pi/c/3.1.5-2/ **Step 3:** Compile the code. .. raw:: html .. code-block:: gcc 3.1.5_BatteryIndicator.c -lwiringPi **Step 4:** Run the executable file. .. raw:: html .. code-block:: sudo ./a.out After the program runs, give the 3rd pin of MCP3008 and the GND a lead-out wire separately and then lead them to the two poles of a battery separately. You can see the corresponding LED on the LED Bargraph is lit up to display the power level (measuring range: 0-5V). .. note:: If it does not work after running, or there is an error prompt: \"wiringPi.h: No such file or directory\", please refer to :ref:`install_wiringpi`. Code -------- .. code-block:: c #include #include #include #define SPI_CHANNEL 0 #define SPI_SPEED 1000000 // 1MHz #define VREF 3.3 int pins[10] = {6, 26, 27, 28, 29, 21, 22, 23, 24, 25}; int read_ADC(int channel) { if (channel < 0 || channel > 7) return -1; unsigned char buffer[3]; buffer[0] = 1; // Start bit buffer[1] = (8 + channel) << 4; // Single-ended mode buffer[2] = 0; wiringPiSPIDataRW(SPI_CHANNEL, buffer, 3); int value = ((buffer[1] & 3) << 8) | buffer[2]; return value; } void LedBarGraph(int value) { for (int i = 0; i < 10; i++) { if (i < value) digitalWrite(pins[i], HIGH); else digitalWrite(pins[i],LOW); } } int main(void) { if (wiringPiSetup() == -1) { printf("setup wiringPi failed!\n"); return 1; } if (wiringPiSPISetup(SPI_CHANNEL, SPI_SPEED) == -1) { printf("SPI setup failed!\n"); return 1; } for (int i = 0; i < 10; i++) { pinMode(pins[i], OUTPUT); digitalWrite(pins[i], HIGH); } while (1) { int analogVal = read_ADC(0); // MCP3008 CH0 if (analogVal < 0) continue; float voltage = analogVal * VREF / 1023.0; int level = analogVal * 10 / 1024; if (level > 10) level = 10; LedBarGraph(level); printf("ADC Value: %d\tVoltage: %.2f V\tLevel: %d\n", analogVal, voltage, level); delay(200); } return 0; } Code Explanation ---------------------- .. code-block:: c int read_ADC(int channel) { if (channel < 0 || channel > 7) return -1; unsigned char buffer[3]; buffer[0] = 1; // Start bit buffer[1] = (8 + channel) << 4; // Single-ended mode, CH0~CH7 buffer[2] = 0; wiringPiSPIDataRW(SPI_CHANNEL, buffer, 3); int value = ((buffer[1] & 3) << 8) | buffer[2]; // Combine 10-bit result return value; } This function reads analog values from the MCP3008 ADC chip using SPI. The ``channel`` parameter selects one of the 8 analog inputs (CH0–CH7). The MCP3008 returns a 10-bit digital value between 0 and 1023 representing the analog voltage. .. code-block:: c void LedBarGraph(int value) { for (int i = 0; i < 10; i++) { if (i < value) digitalWrite(pins[i], HIGH); // Turn on LED (assumes active HIGH wiring) else digitalWrite(pins[i], LOW); // Turn off LED } } This function controls a 10-LED bar graph display. Each LED represents 1/10th of the voltage range. LEDs are turned on in order up to the specified level. Note: This version assumes LED anodes are connected to GPIOs and cathodes to GND (i.e. active HIGH). .. code-block:: c int main(void) { if (wiringPiSetup() == -1) { printf("setup wiringPi failed!\n"); return 1; } if (wiringPiSPISetup(SPI_CHANNEL, SPI_SPEED) == -1) { printf("SPI setup failed!\n"); return 1; } for (int i = 0; i < 10; i++) { pinMode(pins[i], OUTPUT); digitalWrite(pins[i], HIGH); // Initialize all LEDs to ON } while (1) { int analogVal = read_ADC(0); // Read voltage on CH0 if (analogVal < 0) continue; float voltage = analogVal * VREF / 1023.0; int level = analogVal * 10 / 1024; // Map to 0–10 levels if (level > 10) level = 10; LedBarGraph(level); // Display level on LEDs printf("ADC Value: %d\tVoltage: %.2f V\tLevel: %d\n", analogVal, voltage, level); delay(200); // Update rate: 5 Hz } return 0; } Main program logic: - Initializes wiringPi and SPI communication. - Sets GPIO pins as outputs for controlling the 10-LED bar. - Continuously reads analog voltage via MCP3008 (CH0). - Converts the reading to a voltage using ``VREF = 3.3V``. - Scales voltage to a 0–10 level bar graph and lights up LEDs. - Displays the raw ADC value, voltage (in volts), and LED level via serial console. This acts as a visual battery level indicator or analog voltmeter. **For Python Language Users** ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ **Step 2:** Set up the SPI interface and install the ``spidev`` library (see :ref:`spi_configuration` for detailed instructions). If you have already completed these steps, you can skip this. **Step 3:** Go to the folder of the code. .. raw:: html .. code-block:: cd ~/davinci-kit-for-raspberry-pi/python **Step 4:** Run the executable file. .. raw:: html .. code-block:: sudo python3 3.1.5-2_BatteryIndicator.py After the program runs, give the 3rd pin of ADC0834 and the GND a lead-out wire separately and then lead them to the two poles of a battery separately. You can see the corresponding LED on the LED Bargraph is lit up to display the power level (measuring range: 0-5V). .. warning:: If there is an error prompt ``RuntimeError: Cannot determine SOC peripheral base address``, please refer to :ref:`faq_soc` **Code** .. note:: You can **Modify/Reset/Copy/Run/Stop** the code below. But before that, you need to go to source code path like ``davinci-kit-for-raspberry-pi/python``. After modifying the code, you can run it directly to see the effect. .. raw:: html .. code-block:: python #!/usr/bin/env python3 import RPi.GPIO as GPIO import spidev import time # GPIO pins connected to 10 LEDs, ordered from left to right led_pins = [25, 12, 16, 20, 21, 5, 6, 13, 19, 26] # BCM numbering # GPIO setup GPIO.setmode(GPIO.BCM) for pin in led_pins: GPIO.setup(pin, GPIO.OUT) GPIO.output(pin, GPIO.LOW) # Initialize SPI spi = spidev.SpiDev() spi.open(0, 0) # Bus 0, CE0 spi.max_speed_hz = 1000000 # 1 MHz # Read value from MCP3008 channel def read_adc(channel): if channel < 0 or channel > 7: return -1 r = spi.xfer2([1, (8 + channel) << 4, 0]) value = ((r[1] & 0x03) << 8) | r[2] return value # Light up LED bar graph according to value def led_bar_graph(level): for i, pin in enumerate(led_pins): if i < level: GPIO.output(pin, GPIO.HIGH) else: GPIO.output(pin, GPIO.LOW) # Main loop try: while True: analog_val = read_adc(0) # Read from MCP3008 channel 0 level = int(analog_val * 10 / 1023) led_bar_graph(level) print(f"ADC: {analog_val}, Level: {level}") time.sleep(0.2) except KeyboardInterrupt: pass finally: for pin in led_pins: GPIO.output(pin, GPIO.LOW) GPIO.cleanup() spi.close() Code Explanation -------------------- This program reads analog voltage from an MCP3008 ADC and displays the result on a 10-LED bar graph using a Raspberry Pi (BCM pin layout). 1. **Import Modules** - ``RPi.GPIO`` controls the GPIO pins on Raspberry Pi. - ``spidev`` communicates with MCP3008 via SPI. - ``time`` provides delay/sleep functionality. .. code-block:: python #!/usr/bin/env python3 import RPi.GPIO as GPIO import spidev import time 2. **GPIO LED Setup** A list of 10 GPIO pins is defined for LED control. These pins are configured as output and initialized to LOW (off). .. code-block:: python # GPIO pins connected to 10 LEDs, ordered from left to right led_pins = [25, 12, 16, 20, 21, 5, 6, 13, 19, 26] # BCM numbering GPIO.setmode(GPIO.BCM) for pin in led_pins: GPIO.setup(pin, GPIO.OUT) GPIO.output(pin, GPIO.LOW) 3. **SPI Initialization** Initializes SPI bus 0 and chip enable 0 (CE0) to communicate with MCP3008. The communication speed is set to 1 MHz. .. code-block:: python spi = spidev.SpiDev() spi.open(0, 0) # Bus 0, CE0 spi.max_speed_hz = 1000000 # 1 MHz 4. **ADC Read Function** Reads an analog value from a specified MCP3008 channel (0–7). The function sends a 3-byte SPI command and decodes the 10-bit result. .. code-block:: python def read_adc(channel): if channel < 0 or channel > 7: return -1 r = spi.xfer2([1, (8 + channel) << 4, 0]) value = ((r[1] & 0x03) << 8) | r[2] return value 5. **LED Bar Graph Function** Lights up LEDs based on the analog level. If the level is 7, the first 7 LEDs will be ON and the rest OFF. .. code-block:: python def led_bar_graph(level): for i, pin in enumerate(led_pins): if i < level: GPIO.output(pin, GPIO.HIGH) else: GPIO.output(pin, GPIO.LOW) 6. **Main Loop** Continuously reads analog input from channel 0, scales the result to a value from 0 to 10, and updates the LED display accordingly. Prints ADC and level values for monitoring. .. code-block:: python try: while True: analog_val = read_adc(0) level = int(analog_val * 10 / 1023) led_bar_graph(level) print(f"ADC: {analog_val}, Level: {level}") time.sleep(0.2) 7. **Cleanup on Exit** When ``Ctrl+C`` is pressed, the program turns off all LEDs, cleans up GPIO state, and closes the SPI interface. .. code-block:: python except KeyboardInterrupt: pass finally: for pin in led_pins: GPIO.output(pin, GPIO.LOW) GPIO.cleanup() spi.close()
