3.1.1 Counting Device
Here we will make a number-displaying counter system, consisting of a PIR sensor and a 4-digit segment display. When the PIR detects that someone is passing by, the number on the 4-digit segment display will add 1. You can use this counter to count the number of people walking through the passageway.
Components
_images/list_Counting_Device1.png _images/list_Counting_Device2.png
Schematic Diagram
T-Board Name
physical
wiringPi
GPIO17
Pin 11
0
17
GPIO27
Pin 13
GPIO22
Pin 15
SPIMOSI
Pin 19
12
10
GPIO18
Pin 12
GPIO23
Pin 16
GPIO24
Pin 18
GPIO26
Pin 37
25
26
_images/Schematic_three_one1.png
Experimental Procedures
Step 1: Build the circuit.
_images/image235.png
For C Language Users
cd ~/davinci-kit-for-raspberry-pi/c/3.1.1/
Step 3: Compile the code.
gcc 3.1.1_CountingDevice.c -lwiringPi
After the code runs, when the PIR detects that someone is passing by, the number on the 4-digit segment display will add 1.
There are two potentiometers on the PIR module: one is to adjust sensitivity and the other is to adjust the detection distance. To make the PIR module work better, you You need to turn both of them counterclockwise to the end.
Code Explanation
void display()
    clearDisplay();
    pickDigit(0);
    hc595_shift(number[counter % 10]);
    clearDisplay();
    pickDigit(1);
    hc595_shift(number[counter % 100 / 10]);
    clearDisplay();
    pickDigit(2);
    hc595_shift(number[counter % 1000 / 100]);
    clearDisplay();
    pickDigit(3);
    hc595_shift(number[counter % 10000 / 1000]);
First, start the fourth segment display, write the single-digit number. Then start the third segment display, and type in the tens digit; after that, start the second and the first segment display respectively, and write the hundreds and thousands digits respectively. Because the refreshing speed is very fast, we see a complete four-digit display.
void loop(){
    int currentState =0;
    int lastState=0;
        display();
        currentState=digitalRead(sensorPin);
        if((currentState==0)&&(lastState==1)){
            counter +=1;
        lastState=currentState;
This is the main function: display the number on the 4-digit segment display and read the PIR value. When the PIR detects that someone is passing by, the number on the 4-digit segment display will add 1.
For Python Language Users
Step 3: Run the executable file.
sudo python3 3.1.1_CountingDevice.py
code
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like davinci-kit-for-raspberry-pi/python.
import RPi.GPIO as GPIO
sensorPin = 26
SDI = 24
RCLK = 23
SRCLK = 18
placePin = (10, 22, 27, 17)
counter = 0
def clearDisplay():
    for i in range(8):
        GPIO.output(SDI, 1)
        GPIO.output(SRCLK, GPIO.HIGH)
        GPIO.output(SRCLK, GPIO.LOW)
    GPIO.output(RCLK, GPIO.HIGH)
    GPIO.output(RCLK, GPIO.LOW)
def hc595_shift(data):
    for i in range(8):
        GPIO.output(SDI, 0x80 & (data << i))
def pickDigit(digit):
    for i in placePin:
        GPIO.output(i,GPIO.LOW)
    GPIO.output(placePin[digit], GPIO.HIGH)
def display():
    global counter
    clearDisplay()
    pickDigit(0)
    clearDisplay()
    pickDigit(1)
    hc595_shift(number[counter % 100//10])
    clearDisplay()
    pickDigit(2)
    hc595_shift(number[counter % 1000//100])
    clearDisplay()
    pickDigit(3)
    hc595_shift(number[counter % 10000//1000])
def loop():
    global counter
    currentState = 0
    lastState = 0
        display()
        currentState=GPIO.input(sensorPin)
            counter +=1
def setup():
    GPIO.setmode(GPIO.BCM)
    GPIO.setup(SDI, GPIO.OUT)
    GPIO.setup(RCLK, GPIO.OUT)
    GPIO.setup(SRCLK, GPIO.OUT)
    for i in placePin:
        GPIO.setup(i, GPIO.OUT)
    GPIO.setup(sensorPin, GPIO.IN)
def destroy():   # When "Ctrl+C" is pressed, the function is executed.
    GPIO.cleanup()
if __name__ == '__main__':  # Program starting from here
    setup()
        loop()
        destroy()
Code Explanation
Based on 1.1.5 4-Digit 7-Segment Display, this lesson adds PIR module to change the automatic counting of lesson 1.1.5 into count detecting. When the PIR detects that someone is passing by, the number on the 4-digit segment display will add 1.
def display():
    global counter
    clearDisplay()
    pickDigit(0)
    clearDisplay()
    pickDigit(1)
    clearDisplay()
    pickDigit(2)
    clearDisplay()
    pickDigit(3)
def loop():
global counter
    currentState = 0
    lastState = 0
    while True:
        display()
            counter +=1
Phenomenon Picture
_images/image236.jpeg
