3.1.12 GAME– Guess Number
Guessing Numbers is a fun party game where you and your friends take turns inputting a number (0~99). The range will be smaller with the inputting of the number till a player answers the riddle correctly. Then the player is defeated and punished. For example, if the lucky number is 51 which the players cannot see, and the player ① inputs 50, the prompt of number range changes to 50~99; if the player ② inputs 70, the range of number can be 50~70; if the player ③ inputs 51, this player is the unlucky one. Here, we use keypad to input numbers and use LCD to output outcomes.
Components
_images/list_GAME_Guess_Number.png
Schematic Diagram
T-Board Name
physical
wiringPi
GPIO18
Pin 12
GPIO23
Pin 16
GPIO24
Pin 18
GPIO25
Pin 22
SPIMOSI
Pin 19
12
10
GPIO22
Pin 15
GPIO27
Pin 13
GPIO17
Pin 11
0
17
SDA1
Pin 3
SDA1(8)
SDA1(2)
SCL1
Pin 5
SCL1(9)
SDA1(3)
_images/Schematic_three_one12.png
Experimental Procedures
Step 1: Build the circuit.
_images/image273.png
Step 2: Setup I2C (see Appendix. If you have set I2C, skip this step.)
For C Language Users
Step 3: Change directory.
cd ~/davinci-kit-for-raspberry-pi/c/3.1.12/
Step 4: Compile.
gcc 3.1.12_GAME_GuessNumber.c -lwiringPi
Step 5: Run.
After the program runs, there displays the initial page on the LCD:
Welcome!
Press A to go!
Press 'A', and the game will start and the game page will appear on the LCD.
Enter number:
0 ‹point‹ 99
A random number 'point' is produced but not displayed on the LCD when the game starts, and what you need to do is to guess it. The number you have typed appears at the end of the first line till the final calculation is finished. (Press 'D' to start the comparation, and if the input number is larger than 10, the automatic comparation will start.)
The number range of 'point' is displayed on the second line. And you must type the number within the range. When you type a number, the range narrows; if you got the lucky number luckily or unluckily, there will appear "You’ve got it!"
Code Explanation
At the beginning part of the code are the functional functions of keypad and I2C LCD1602. You can learning more details about them in 1.1.7 I2C LCD1602 and 2.1.5 Keypad.
Here, what we need to know is as follows:
//Start from here
void init(void){
    fd = wiringPiI2CSetup(LCDAddr);
    lcd_init();
    lcd_clear();
    for(int i=0 ; i<4 ; i++) {
        pinMode(rowPins[i], OUTPUT);
        pinMode(colPins[i], INPUT);
    lcd_clear();
    write(0, 0, "Welcome!");
    write(0, 1, "Press A to go!");
This function is used to initially define I2C LCD1602 and Keypad and to display "Welcome!" and "Press A to go!".
void init_new_value(void){
    srand(time(0));
    pointValue = rand()%100;
    upper = 99;
    lower = 0;
    count = 0;
    printf("point is %d\n",pointValue);
The function produces the random number 'point' and resets the range hint of the point.
bool detect_point(void){
    if(count > pointValue){
        if(count < upper){
            upper = count;
    else if(count < pointValue){
        if(count > lower){
            lower = count;
    else if(count = pointValue){
        count = 0;
        return 1;
    count = 0;
    return 0;
detect_point() compares the input number with the produced "point". If the comparing outcome is that they are not same, count will assign values to upper and lower and return '0'; otherwise, if the outcome indicates they are same, there returns '1'.
void lcd_show_input(bool result){
    char *str=NULL;
    str =(char*)malloc(sizeof(char)*3);
    lcd_clear();
    if (result == 1){
        write(0,1,"You've got it!");
        delay(5000);
        init_new_value();
        lcd_show_input(0);
        return;
    write(0,0,"Enter number:");
    Int2Str(str,count);
    write(13,0,str);
    Int2Str(str,lower);
    write(0,1,str);
    write(3,1,"<Point<");
    Int2Str(str,upper);
    write(12,1,str);
This function works for displaying the game page. Pay attention to the function Int2Str(str,count), it converts these variables count, lower, and upper from integer to character string for the correct display of lcd.
int main(){
    unsigned char pressed_keys[BUTTON_NUM];
    unsigned char last_key_pressed[BUTTON_NUM];
    if(wiringPiSetup() == -1){ //when initialize wiring failed,print messageto screen
        printf("setup wiringPi failed !");
        return 1;
    init();
    init_new_value();
        keyRead(pressed_keys);
        bool comp = keyCompare(pressed_keys, last_key_pressed);
        if (!comp){
            if(pressed_keys[0] != 0){
                bool result = 0;
                if(pressed_keys[0] == 'A'){
                    init_new_value();
                    lcd_show_input(0);
                else if(pressed_keys[0] == 'D'){
                    result = detect_point();
                    lcd_show_input(result);
                else if(pressed_keys[0] >='0' && pressed_keys[0] <= '9'){
                    count = count * 10;
                    count = count + (pressed_keys[0] - 48);
                    if (count>=10){
            keyCopy(last_key_pressed, pressed_keys);
        delay(100);
    return 0;
Main() contains the whole process of the program, as show below:
  1. Initialize I2C LCD1602 and Keypad.
  2. Use init_new_value() to create a random number 0-99.
  3. Judge whether the button is pressed and get the button reading.
  4. If the button 'A' is pressed, a random number 0-99 will appear then the game starts.
  5. If the button 'D' is detected to have been pressed, the program will enter into the outcome judgement and will display the outcome on the LCD. This step helps that you can also judge the outcome when you press only one number and then the button 'D'.
  6. If the button 0-9 is pressed, the value of count will be changed; if the count is larger than 10, then the judgement starts.
  7. The changes of the game and its values are displayed on LCD1602.
For Python Language Users
Step 4: Run.
sudo python3 3.1.12_GAME_GuessNumber.py
Welcome!
Press A to go!
Enter number:
0 ‹point‹ 99
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like davinci-kit-for-raspberry-pi/python.
import RPi.GPIO as GPIO
import LCD1602
import random
##################### HERE IS THE KEYPAD LIBRARY TRANSPLANTED FROM Arduino ############
#class Key:Define some of the properties of Key
class Keypad():
   def __init__(self, rowsPins, colsPins, keys):
      self.rowsPins = rowsPins
      self.colsPins = colsPins
      self.keys = keys
      GPIO.setwarnings(False)
      GPIO.setmode(GPIO.BCM)
      GPIO.setup(self.rowsPins, GPIO.OUT, initial=GPIO.LOW)
      GPIO.setup(self.colsPins, GPIO.IN, pull_up_down=GPIO.PUD_DOWN)
   def read(self):
      pressed_keys = []
      for i, row in enumerate(self.rowsPins):
            GPIO.output(row, GPIO.HIGH)
            for j, col in enumerate(self.colsPins):
               index = i * len(self.colsPins) + j
               if (GPIO.input(col) == 1):
            GPIO.output(row, GPIO.LOW)
      return pressed_keys
################ EXAMPLE CODE START HERE ################
count = 0
pointValue = 0
upper=99
lower=0
def setup():
   global keypad, last_key_pressed,keys
   rowsPins = [18,23,24,25]
   colsPins = [10,22,27,17]
   keys = ["1","2","3","A",
            "4","5","6","B",
            "7","8","9","C",
            "*","0","#","D"]
   keypad = Keypad(rowsPins, colsPins, keys)
   last_key_pressed = []
   LCD1602.init(0x27, 1)    # init(slave address, background light)
   LCD1602.clear()
   LCD1602.write(0, 0, 'Welcome!')
   LCD1602.write(0, 1, 'Press A to Start!')
def init_new_value():
   global pointValue,upper,count,lower
   pointValue = random.randint(0,99)
   upper = 99
   lower = 0
   count = 0
   print('point is %d' %(pointValue))
def detect_point():
   global count,upper,lower
   if count > pointValue:
      if count < upper:
            upper = count
   elif count < pointValue:
      if count > lower:
            lower = count
   elif count == pointValue:
      count = 0
      return 1
   count = 0
   return 0
def lcd_show_input(result):
   LCD1602.clear()
   if result == 1:
      LCD1602.write(0,1,'You have got it!')
      time.sleep(5)
      init_new_value()
      lcd_show_input(0)
      return
   LCD1602.write(0,0,'Enter number:')
   LCD1602.write(13,0,str(count))
   LCD1602.write(0,1,str(lower))
   LCD1602.write(3,1,' < Point < ')
   LCD1602.write(13,1,str(upper))
def loop():
   global keypad, last_key_pressed,count
   while(True):
      result = 0
      pressed_keys = keypad.read()
      if len(pressed_keys) != 0 and last_key_pressed != pressed_keys:
            if pressed_keys == ["A"]:
               init_new_value()
               lcd_show_input(0)
            elif pressed_keys == ["D"]:
            elif pressed_keys[0] in keys:
               if pressed_keys[0] in list(["A","B","C","D","#","*"]):
                  continue
               count = count * 10
               count += int(pressed_keys[0])
               if count >= 10:
            print(pressed_keys)
      time.sleep(0.1)
# Define a destroy function for clean up everything after the script finished
def destroy():
   # Release resource
   GPIO.cleanup()
   LCD1602.clear()
if __name__ == '__main__':     # Program start from here
      setup()
            loop()
   except KeyboardInterrupt:   # When 'Ctrl+C' is pressed, the program destroy() will be executed.
      destroy()
Code Explanation
    upper = 99
    lower = 0
    count = 0
def detect_point():
        if count < upper:
            upper = count
        if count > lower:
            lower = count
        count = 0
        return 1
    count = 0
    return 0
detect_point() compares the input number (count) with the produced "point". If the comparing outcome is that they are not same, count will assign values to upper and lower and return '0'; otherwise, if the outcome indicates they are same, there returns '1'.
    LCD1602.clear()
    if result == 1:
        time.sleep(5)
        init_new_value()
        lcd_show_input(0)
        return
str(count): Because write() can only support the data type — character string, str() is needed to convert the number into string.
def loop():
    while(True):
        result = 0
                init_new_value()
                lcd_show_input(0)
                    continue
                count = count * 10
                if count >= 10:
            print(pressed_keys)
        last_key_pressed = pressed_keys
        time.sleep(0.1)
  2. Judge whether the button is pressed and get the button reading.
  3. If the button 'A' is pressed, a random number 0-99 will appear then the game starts.
  4. If the button 'D' is detected to have been pressed, the program will enter into the outcome judgement.
  5. If the button 0-9 is pressed, the value of count will be changed; if the count is larger than 10, then the judgement starts.
  6. The changes of the game and its values are displayed on LCD1602.
Phenomenon Picture
_images/image274.jpeg
