Programming with Arduino IDE
After you have experienced Quick Play with APP or IR Remote Control, if you want to understand how each function is implemented, and then modify the effect according to your own ideas, you can come to read this programming mode carefully.
Every function in the programming mode chapter is made into a separate project, there are 17 of them. Each project has corresponding code and explanation, so you can see how each function works.
This project uses the Arduino programming language, so you’ll need to install the Arduino IDE and related libraries before you can begin.
Now let’s start the journey of discovery!
- Download the Code
- Download and Install Arduino IDE 2.0
- Introduce of Arduino IDE
- Install the Required Libraries
- Fun Projects
- 1. Basic Movements
- 2. Omni Move
- 3. Move and Rotate
- 4. Drift
- 5. Remote Control
- 6. Car Light
- 7. Compass
- 8. Move Field Centric
- 9. IR Obstacle
- 10. Ultrasonic
- 11. Obstacle Avoidance
- 12. Follow
- 13. Grayscale
- 14. Line Track
- 15. Line Track Field Centric
- 16. AI Detection from APP
- 17. APP Control
- 18. APP Control Plus
