1. Basic Movementsď
You will learn how to make the Zeus Car move in all directions in this project.
How to do?
The ESP32-CAM and the Arduino board share the same RX (receive) and TX (transmit) pins. So, when youâre uploading code, youâll need to first disconnect the ESP32-CAM to avoid any conflicts or potential issues.
Connect the Zeus Car to your computer with the blue USB cable. When you plug in your Arduino board, the computer automatically recognizes it and assigns it a COM port, which you can view in Device Manager.
Open the
1_basic_move.inofile under the path ofzeus-car-main\examples\1_basic_move.You can quickly select the board and port from this place.
In case COMxx doesnât appear, open the Board Manager from the left and make sure the âArduino AVR Boardsâ core is installed.
Now click the Upload button to upload the code to the Arduino board. When it is finished, a notification pops up in the bottom right of your IDE window. Of course, sometimes there are some complications when uploading, and these errors will be listed here as well.
If you get a âCompilation error: SoftPWM.h: No such file or directoryâ prompt, it means you donât have the
SoftPWMlibrary installed.Please refer to Install the Required Libraries to install the two required libraries
SoftPWMandIRLremote.
Letâs start the Zeus Car.
When first used or when the battery cable is unplugged, Zeus Car Shield will activate its over-discharge protection circuitry.
So youâll need to plug in the Type-C cable for about 5 seconds.
If the power indicator lights up, it means that the protection status has been released. At this time look at the battery indicators, if both battery indicators are off, please continue to plug in the Type-C cable to charge the battery.
You will now see the Zeus Car move for one second in each direction.
How it works?
These movements are obtained by the 4 Mecanum Wheels cooperating together, for example, four wheels forward or backward at the same time can make the car also forward or backward, and two wheels forward and two wheels backward can cause the car to pan or rotate to the left or right.
Letâs look at how these movements are specifically achieved.
Moving forward and backward, panning left and right.
Diagonal panning
Rotate left and right
