17. APP Controlď
In the previous project we simply viewed the footage taken by the camera and used the AI detection function in the SunFounder Controller.
In this project, we will try to control the movement and direction of the Zeus Car using the joystick widget in the app, so now letâs see how it works.
Please install SunFounder Controller from APP Store(iOS) or Google Play(Android).
How to do?
The ESP32-CAM and the Arduino board share the same RX (receive) and TX (transmit) pins. So, when youâre uploading code, youâll need to first disconnect the ESP32-CAM to avoid any conflicts or potential issues.
Open the
17_app_control.inofile under the path ofzeus-car-main\examples\17_app_control.After the code is uploaded successfully, you can plug in the ESP32-CAM and then slide the power switch to ON to start the Zeus Car.
Toggle the Upload Switch to the side of Run (right side on this diagram) to start the ESP32 CAM.
Press the reset button to get the Arduino boardâs program running again.
Connect to
Zeus_Car-XXXXXXWLAN.Find
Zeus_Car-XXXXXXon the WLAN of the mobile phone (tablet), enter the password12345678and connect to it.XXXXXXare the last six characters of the ESP32 CAMâs MAC address, so the hotspot name is different on every car.
The default connection mode is AP mode. So after you connect, there will be a prompt telling you that there is no Internet access on this WLAN network, please choose to continue connecting.
Create a controller.
To add a controller on SunFounder Controller, click the + icon.
There are preset controllers for some products in the Preset section. But here we choose a Blank and Dual Stick template.
Click the + icon in the J area and select a Switch widget. You may need to slide to the left to see the widget.
If you think you selected the wrong widget, you can click on it again and use the Delete button to remove it.
Run the Controller.
After the âConnected Successfullyâ message appears, click the
button, then the camera footage will appear on the app, and now you can control your Zeus Car with these widgets.The functions of the three widgets are referenced as follows
Move in All Directions(K)
The Zeus Car will move in the appropriate direction when you swipe the
widget.
The car moves once every time you slide, so if you donât release your hand all the time, the car keeps moving.
Drift Enable(J)
Click the
button to enable the drift function.By sliding the
widget counterclockwise, you will see Zeus Car drift to the right. Upon releasing the hand, the car will stop at its current position.Similarly, if you slide the
widget clockwise, the Zeus Car will drift to the left and stop in the current position.
Control the Drection(Q)
