Xmas Matrixο
π Welcome to the SunFounder Facebook Community! Whether youβre into Raspberry Pi, Arduino, or ESP32, youβll find inspiration, help ideas here.
β Be the first to get free learning resources.
β Stay updated on new products & exclusive giveaways.
β Share your creations and get real feedback.
Kit purchaseο
Looking for parts? Check out our all-in-one kits below β packed with components, beginner-friendly guides, and tons of fun.
Includes ESP32 board |
PURCHASE LINK |
ESP32 Ultimate Starter Kit |
ESP32 WROOM 32E + |
Universal Maker Sensor Kit |
Course Introductionο
This project uses an Arduino Nano ESP32 and a MAX7219 8Γ8 LED matrix to display animated Christmas patterns with a smooth breathing-light effect.
SN |
COMPONENT INTRODUCTION |
QUANTITY |
PURCHASE LINK |
Arduino Nano ESP32 |
USB Type-C cable |
Breadboard |
Wires |
Several |
MAX7219 Dot Matrix Module |
Common Connections:
CLK: Connect to D13 on the ESP32.
CS: Connect to D10 on the ESP32.
DIN: Connect to D11 on the ESP32.
GND: Connect to GND on the ESP32 Extension Board.
VCC: Connect to 5V on the ESP32 Extension Board.
Writing the Code
Donβt forget to select the board(Arduino Nano ESP32) and the correct port before clicking the Upload button.
// Arduino Nano ESP32 - MAX7219 8x8 LED Matrix Christmas Animations
// - Compatible with ESP32 (no AVR-only LedControl library)
// - Uses a minimal MAX7219 bit-bang driver
// Wiring (same as your Nano ESP32 Tetris reference):
// DIN -> D11
// CS -> D10
// CLK -> D13
// -------------------- MAX7219 Pins (Nano ESP32) --------------------
#define DIN 11 // Data to MAX7219 DIN
#define CS 10 // Chip Select to MAX7219 CS/LOAD
#define CLK 13 // Clock to MAX7219 CLK
// -------------------- Minimal MAX7219 Driver (ESP32 compatible) --------------------
class MAX7219_8x8 {
public:
MAX7219_8x8(int din, int clk, int cs) : _din(din), _clk(clk), _cs(cs) {}
// Initialize MAX7219
void begin(uint8_t intensity /*0..15*/) {
pinMode(_din, OUTPUT);
pinMode(_clk, OUTPUT);
pinMode(_cs, OUTPUT);
digitalWrite(_cs, HIGH);
digitalWrite(_clk, LOW);
// MAX7219 setup
sendCmd(0x0F, 0x00); // Display test: off
sendCmd(0x09, 0x00); // Decode mode: none
sendCmd(0x0B, 0x07); // Scan limit: 8 digits (0..7)
sendCmd(0x0C, 0x01); // Shutdown: normal operation
setIntensity(intensity);
clear();
// Set brightness 0..15
void setIntensity(uint8_t intensity) {
if (intensity > 15) intensity = 15;
sendCmd(0x0A, intensity);
// Clear display
void clear() {
for (int row = 0; row < 8; row++) setRow(row, 0x00);
// Set a row (row: 0..7), bits in data are columns (bit0 = col0)
void setRow(uint8_t row, uint8_t data) {
// MAX7219 digit registers are 1..8
sendCmd(row + 1, data);
// Set a column (col: 0..7), bits in data are rows (bit0 = row0)
// This matches LedControl's setColumn() behavior.
void setColumn(uint8_t col, uint8_t data) {
// Update internal buffer as rows, then write all rows.
// For each row r, set/clear the bit at "col" based on data bit r.
for (int r = 0; r < 8; r++) {
bool on = (data >> r) & 0x01;
if (on) _rowBuf[r] |= (1 << col);
else _rowBuf[r] &= ~(1 << col);
// Push buffer to MAX7219
for (int r = 0; r < 8; r++) setRow(r, _rowBuf[r]);
// Clear internal buffer + display (useful when using setColumn)
void clearBuffered() {
for (int r = 0; r < 8; r++) _rowBuf[r] = 0;
clear();
private:
int _din, _clk, _cs;
uint8_t _rowBuf[8] = {0};
// Shift out 16 bits: register then data, MSB first
void shiftOut16(uint8_t reg, uint8_t data) {
for (int i = 7; i >= 0; i--) {
digitalWrite(_din, (reg >> i) & 1);
digitalWrite(_clk, HIGH);
digitalWrite(_din, (data >> i) & 1);
// Send one command to MAX7219
void sendCmd(uint8_t reg, uint8_t data) {
digitalWrite(_cs, LOW);
shiftOut16(reg, data);
MAX7219_8x8 lc(DIN, CLK, CS);
// -------------------- Patterns (8x8) --------------------
// Note: These patterns are the same as your original sketch.
byte treeBase[8] = {
B00010000,
B00111000,
B01111100,
B11111110,
B00111000,
B01111100,
B11111110,
B00111000
byte bellBase[8] = {
B00000010,
B00011100,
B00111100,
B11111100,
B00111000,
B01010000,
B00010000,
B00000000
byte bellMirror[8] = {
B01000000,
B00111000,
B00111100,
B00111111,
B00011100,
B00001010,
B00001000,
B00000000
byte hatBase[8] = {
B00001100,
B00011110,
B00111101,
B01111000,
B01111000,
B01111000,
B11111100,
B11111100
byte letterX[8] = {
B10000001,
B01000010,
B00100100,
B00011000,
B00011000,
B00100100,
B01000010,
B10000001
byte letterM[8] = {
B10000001,
B11000011,
B10100101,
B10011001,
B10000001,
B10000001,
B10000001,
B10000001
byte letterA[8] = {
B00111100,
B01100110,
B11000011,
B11000011,
B11111111,
B11000011,
B11000011,
B11000011
byte letterS[8] = {
B00111110,
B01100000,
B01100000,
B00111100,
B00000110,
B00000110,
B01100110,
B00111100
// -------------------- Display Helpers --------------------
// Display pattern using column writes (keeps your original orientation logic)
// The original code reversed the order: pattern[7 - i]
void displayPattern(const byte pattern[8]) {
lc.clearBuffered(); // Clear matrix + internal buffer
for (int col = 0; col < 8; col++) {
// Write column data in reverse order for correct orientation
lc.setColumn(col, pattern[7 - col]);
// Breathing brightness effect
void displayWithBreathing(const byte pattern[8], int repeat) {
for (int r = 0; r < repeat; r++) {
for (int brightness = 0; brightness <= 15; brightness++) {
lc.setIntensity((uint8_t)brightness); // Increase brightness
displayPattern(pattern);
delay(30);
for (int brightness = 15; brightness >= 0; brightness--) {
lc.setIntensity((uint8_t)brightness); // Decrease brightness
delay(30);
lc.begin(15); // Start with max intensity
lc.clearBuffered();
// Christmas tree breathing effect (twice)
displayWithBreathing(treeBase, 2);
// Bell breathing effect (original + mirrored)
displayWithBreathing(bellBase, 1);
displayWithBreathing(bellMirror, 1);
// Christmas hat breathing effect (twice)
displayWithBreathing(hatBase, 2);
// Display "XMAS" breathing effect
displayWithBreathing(letterX, 1);
displayWithBreathing(letterM, 1);
displayWithBreathing(letterA, 1);
displayWithBreathing(letterS, 1);
// Delay before repeating
delay(500);
