Controll eyes
Kit purchase
Includes ESP32 board |
PURCHASE LINK |
ESP32 Ultimate Starter Kit |
ESP32 WROOM 32E + |
Universal Maker Sensor Kit |
Course Introduction
This Arduino project animates a pair of interactive eyes on an OLED screen, controlled by a joystick.
The eyes track the joystick’s movement, simulating the effect of following an object within a defined range.
Pressing the joystick button triggers a blinking animation that mimics a natural blink by covering the upper part of the eyes.
If this is your first time working with an ESP32 project, we recommend downloading and reviewing the basic materials first.
SN |
COMPONENT INTRODUCTION |
QUANTITY |
PURCHASE LINK |
Arduino Nano ESP32 |
USB Type-C cable |
Breadboard |
Wires |
Several |
Joystick Module |
OLED Display Module |
Common Connections:
Joystick Module
VRX: Connect to A0 on the ESP32.
VRY: Connect to A1 on the ESP32.
SW: Connect to D4 on the ESP32.
OLED Display Module
SDA: Connect to D2 on the Arduino.
SCK: Connect to D3 on the Arduino.
Writing the Code
To install the library, use the Arduino Library Manager and search for Adafruit SSD1306 and Adafruit GFX and install it.
Don’t forget to select the board(Arduino Nano ESP32) and the correct port before clicking the Upload button.
Arduino Nano ESP32 (ESP32-S3)
RGB LED color blending with potentiometer (LEDC PWM)
// RGB LED pins (use Dx labels)
const int redPin = D9;
const int greenPin = D10;
const int bluePin = D11;
// Potentiometer pin (ADC)
const int potPin = A0;
// PWM settings
const int PWM_FREQ = 5000; // 5 kHz
const int PWM_RES = 8; // 8-bit resolution (0~255)
Serial.begin(115200);
delay(200);
// Attach PWM to pins (Arduino-ESP32 3.x style)
ledcAttach(redPin, PWM_FREQ, PWM_RES);
ledcAttach(greenPin, PWM_FREQ, PWM_RES);
ledcAttach(bluePin, PWM_FREQ, PWM_RES);
// Optional: Set ADC behavior (not required, but helps stability)
analogReadResolution(12); // ESP32 ADC default is typically 12-bit (0~4095)
// Read potentiometer value (ESP32 ADC: 0~4095)
int potValue = analogRead(potPin);
Serial.println(potValue);
// Map ADC value to 0~765 for color blending
int range = map(potValue, 0, 4095, 0, 765);
int r = 0, g = 0, b = 0;
// Blend RGB colors based on range
if (range <= 255) {
r = 255;
g = range;
b = 0;
} else if (range <= 510) {
r = 510 - range;
g = 255;
b = range - 255;
} else {
r = 0;
g = 765 - range;
b = 255;
// Output PWM (inverted for common-anode RGB LED)
// If you are using common-cathode, remove the "255 -" inversion.
ledcWrite(redPin, 255 - r);
ledcWrite(greenPin, 255 - g);
ledcWrite(bluePin, 255 - b);
delay(20);
