Stacker Blocks๏
๐ Welcome to the SunFounder Facebook Community! Whether youโre into Raspberry Pi, Arduino, or ESP32, youโll find inspiration, help ideas here.
โ Be the first to get free learning resources.
โ Stay updated on new products & exclusive giveaways.
โ Share your creations and get real feedback.
Kit purchase๏
Looking for parts? Check out our all-in-one kits below โ packed with components, beginner-friendly guides, and tons of fun.
Includes ESP32 board |
PURCHASE LINK |
ESP32 Ultimate Starter Kit |
ESP32 WROOM 32E + |
Universal Maker Sensor Kit |
Course Introduction๏
In this lesson, youโll learn how to use a MAX7219 Dot Matrix Module, a button with the Arduino Nano ESP32 to create a stacker blocks game.
The MAX7219 Dot Matrix Module will display the game, and players can use the button to control the gameplay in the stacker blocks game.
SN |
COMPONENT INTRODUCTION |
QUANTITY |
PURCHASE LINK |
Arduino Nano ESP32 |
USB Type-C cable |
Breadboard |
Wires |
Several |
MAX7219 Dot Matrix Module |
Button |
Common Connections:
CLK: Connect to D13 on the ESP32.
CS: Connect to D10 on the ESP32.
DIN: Connect to D11 on the ESP32.
GND: Connect to GND on the ESP32 Extension Board.
VCC: Connect to 5V on the ESP32 Extension Board.
Button
Connect to D2 on the ESP32.
Writing the Code
Donโt forget to select the board(Arduino Nano ESP32) and the correct port before clicking the Upload button.
// Arduino Nano ESP32 - 4x MAX7219 (32x8) Stacking Block Game
// - ESP32-compatible bit-bang MAX7219 driver
// - 4 daisy-chained MAX7219 modules => total width = 32 columns
// - Button places blocks
// - Blocks appear from bottom to top (right to left by columns)
// -------------------- MAX7219 Pins (Nano ESP32) --------------------
#define DIN_PIN 11 // Data to MAX7219 DIN
#define CLK_PIN 13 // Clock to MAX7219 CLK
#define CS_PIN 10 // Chip Select to MAX7219 CS/LOAD
// -------------------- Input Pin --------------------
const int buttonPin = 2; // Button (active LOW, using INPUT_PULLUP)
// -------------------- Game Constants --------------------
const int MODULES = 4; // Number of MAX7219 modules
const int blockColumns = 2; // Each block occupies 2 columns
const int TOTAL_COLS = 32; // 4 modules * 8 columns
// -------------------- Minimal MAX7219 Driver (ESP32 compatible) --------------------
class MAX7219Chain {
public:
MAX7219Chain(int din, int clk, int cs, int modules)
: _din(din), _clk(clk), _cs(cs), _modules(modules) {}
void begin(uint8_t intensity /*0..15*/) {
pinMode(_din, OUTPUT);
pinMode(_clk, OUTPUT);
pinMode(_cs, OUTPUT);
digitalWrite(_cs, HIGH);
digitalWrite(_clk, LOW);
sendCmdAll(0x0F, 0x00); // Display test: off
sendCmdAll(0x09, 0x00); // Decode mode: none
sendCmdAll(0x0B, 0x07); // Scan limit: 0..7
sendCmdAll(0x0C, 0x01); // Shutdown: normal operation
setIntensity(intensity);
clear();
void setIntensity(uint8_t intensity) {
if (intensity > 15) intensity = 15;
sendCmdAll(0x0A, intensity);
void clear() {
for (int m = 0; m < _modules; m++) {
for (int row = 0; row < 8; row++) _buf[m][row] = 0;
refreshAll();
// row: 0..7, col: 0..7
void setLed(int module, int row, int col, bool on) {
if (module < 0 || module >= _modules) return;
if (row < 0 || row > 7) return;
if (col < 0 || col > 7) return;
if (on) _buf[module][row] |= (1 << col);
else _buf[module][row] &= ~(1 << col);
void clearModule(int module) {
for (int row = 0; row < 8; row++) _buf[module][row] = 0;
void refreshAll() {
for (int row = 0; row < 8; row++) {
digitalWrite(_cs, LOW);
for (int m = _modules - 1; m >= 0; m--) {
shiftOut8(row + 1); // digit register: 1..8
shiftOut8(_buf[m][row]); // row data
private:
int _din, _clk, _cs, _modules;
uint8_t _buf[MODULES][8] = {0};
void shiftOut8(uint8_t v) {
for (int i = 7; i >= 0; i--) {
digitalWrite(_din, (v >> i) & 1);
digitalWrite(_clk, HIGH);
void sendCmdAll(uint8_t reg, uint8_t data) {
shiftOut8(reg);
shiftOut8(data);
MAX7219Chain lc(DIN_PIN, CLK_PIN, CS_PIN, MODULES);
// -------------------- Game State --------------------
int currentWidth = 4;
int currentPos = -4;
int direction = 1;
int moveDelay = 150;
bool gameOver = false;
unsigned long lastMoveTime = 0;
int maxPosition = 0;
int buttonPressCount = 0;
int currentLayerCount = 0;
struct BlockLayer {
int position; // top row
int width; // height
int startCol; // global start column in 0..31
int colWidth; // always blockColumns (2)
BlockLayer layers[32];
// -------------------- Helpers --------------------
void updateMaxPosition() {
maxPosition = 7 + currentWidth;
// Debounced button check (waits for release)
bool checkButton() {
if (digitalRead(buttonPin) == LOW) {
delay(20);
while (digitalRead(buttonPin) == LOW) { delay(1); }
return true;
return false;
// Map global column (0..31) to physical module + local column.
// This version flips the module order so the game starts from the bottom module,
// while keeping the block column order unchanged.
void mapColumn(int globalCol, int &module, int &col) {
int logicalModule = globalCol / 8; // 0..3
module = (MODULES - 1) - logicalModule; // flip: 0<->3, 1<->2
col = 7 - (globalCol % 8); // keep original column mirroring
// Compute the start column for a given layer index so that
// layers fill from right to left (bottom to top visually).
int layerStartCol(int layerIndex) {
// layerIndex = 0 => start at 30 (right-most 2 columns)
// layerIndex = 1 => start at 28, ...
return TOTAL_COLS - (layerIndex + 1) * blockColumns;
// Draw all fixed layers + current moving block into buffer and refresh
void updateDisplay() {
for (int m = 0; m < MODULES; m++) lc.clearModule(m);
// Draw placed layers
for (int i = 0; i < currentLayerCount; i++) {
int startCol = layers[i].startCol;
int colWidth = layers[i].colWidth;
for (int colOffset = 0; colOffset < colWidth; colOffset++) {
int globalCol = startCol + colOffset;
int module, col; mapColumn(globalCol, module, col);
if (module >= MODULES) continue;
for (int j = 0; j < layers[i].width; j++) {
int row = layers[i].position + j;
if (row >= 0 && row < 8) lc.setLed(module, row, col, true);
// Draw moving block if not game over
if (!gameOver) {
int startCol = layerStartCol(currentLayerCount);
for (int colOffset = 0; colOffset < blockColumns; colOffset++) {
for (int j = 0; j < currentWidth; j++) {
int row = currentPos + j;
lc.refreshAll();
void clearMovingBlock() {
if (row >= 0 && row < 8) lc.setLed(module, row, col, false);
void displayMovingBlock() {
lc.refreshAll();
// Simple & safe: redraw everything when a block is placed
void updatePlacedBlockDisplay(int /*layerIndex*/) {
updateDisplay();
// Place the block and compute overlap with the previous layer
void placeBlock() {
buttonPressCount++;
if (buttonPressCount == 4) moveDelay = 120;
else if (buttonPressCount == 8) moveDelay = 90;
else if (buttonPressCount == 12) moveDelay = 60;
// First layer
if (currentLayerCount == 0) {
layers[0].position = currentPos;
layers[0].width = currentWidth;
layers[0].startCol = layerStartCol(0);
layers[0].colWidth = blockColumns;
currentLayerCount = 1;
updateMaxPosition();
currentPos = random(-currentWidth, maxPosition + 1);
updatePlacedBlockDisplay(0);
return;
// Overlap with previous layer
int prevPos = layers[currentLayerCount - 1].position;
int prevWidth = layers[currentLayerCount - 1].width;
int overlapTop = max(prevPos, currentPos);
int overlapBottom = min(prevPos + prevWidth - 1, currentPos + currentWidth - 1);
// No overlap => game over
if (overlapBottom < overlapTop) {
clearMovingBlock();
lc.refreshAll();
gameOver = true;
return;
// Save overlap as new layer
layers[currentLayerCount].position = overlapTop;
layers[currentLayerCount].width = overlapBottom - overlapTop + 1;
layers[currentLayerCount].startCol = layerStartCol(currentLayerCount);
layers[currentLayerCount].colWidth = blockColumns;
currentWidth = layers[currentLayerCount].width;
currentLayerCount++;
// If full width reached, end game
int totalUsedCols = currentLayerCount * blockColumns;
if (totalUsedCols >= TOTAL_COLS) {
gameOver = true;
updateDisplay();
return;
updatePlacedBlockDisplay(currentLayerCount - 1);
pinMode(buttonPin, INPUT_PULLUP);
lc.begin(8);
lc.clear();
currentWidth = 4;
currentPos = -currentWidth;
randomSeed((uint32_t)analogRead(A0) ^ (uint32_t)micros());
updateDisplay();
// Game over blink + reset
if (gameOver) {
static bool blinkState = false;
static unsigned long lastBlinkTime = 0;
if (millis() - lastBlinkTime > 500) {
lastBlinkTime = millis();
blinkState = !blinkState;
if (blinkState) updateDisplay();
else lc.clear();
if (checkButton()) {
gameOver = false;
currentWidth = 4;
moveDelay = 150;
direction = 1;
updateDisplay();
return;
// Move the block periodically
unsigned long now = millis();
if (now - lastMoveTime > (unsigned long)moveDelay) {
lastMoveTime = now;
clearMovingBlock();
currentPos += direction;
// Reflect at boundaries
if (currentPos < -currentWidth) {
int overshoot = (-currentWidth) - currentPos;
currentPos = -currentWidth + overshoot;
direction = -direction;
} else if (currentPos > maxPosition) {
int overshoot = currentPos - maxPosition;
currentPos = maxPosition - overshoot - (currentWidth - 1);
displayMovingBlock();
// Place block on button press
placeBlock();
