Water Level 2.0
Kit purchase
../_images/esp32_kit1.png
Includes ESP32 board
PURCHASE LINK
ESP32 Ultimate Starter Kit
ESP32 WROOM 32E +
Universal Maker Sensor Kit
Course Introduction
In this lesson, you’ll learn how to build a simple water level indicator using an analog water level sensor and 8 LEDs with the Arduino Nano ESP32.
As the water level rises, more LEDs light up to visually display the current level in real time.
If this is your first time working with an ESP32 project, we recommend downloading and reviewing the basic materials first.
SN
COMPONENT INTRODUCTION
QUANTITY
PURCHASE LINK
Arduino Nano ESP32
USB Cable
Wires
Several
Water Level Detection Module
Resistor
1KΩ
LED
Several
../_images/water_level2.0_bb1.png
Common Connections:
  • Water Level Detection Module
    • A: Connect to A0 on the ESP32.
    • G: Connect to breadboard’s negative power bus.
    • V: Connect to 3.3V on the ESP32 Extension Board.
  • LEDS
    • Connect the LED cathode to a 1KΩ resistor then to the negative power bus on the breadboard, and the anode to the D2~D9 on the ESP32.
Writing the Code
  • Don’t forget to select the board(Arduino Nano ESP32) and the correct port before clicking the Upload button.
// LED pin array (Dx labels for Arduino Nano ESP32)
const int ledPins[] = {D2, D3, D4, D5, D6, D7, D8, D9};
const int numLEDs = 8;
// Water level sensor analog input pin
// Use an ADC-capable pin on ESP32
const int sensorPin = A0;   // On Nano ESP32, A0 is mapped to a valid ADC pin
  Serial.begin(115200);
  // Set all LED pins as output
  for (int i = 0; i < numLEDs; i++) {
    pinMode(ledPins[i], OUTPUT);
    digitalWrite(ledPins[i], LOW);
  // Read the water level sensor value (ESP32 ADC range: 0~4095)
  int sensorValue = analogRead(sensorPin);
  Serial.print("Water level analog value: ");
  Serial.println(sensorValue);
  // Map the analog value to number of LEDs (0~8)
  // Adjust 0~1900 according to your actual sensor output range
  int level = map(sensorValue, 0, 1900, 0, numLEDs);
  level = constrain(level, 0, numLEDs);
  // Turn on LEDs according to the water level
    if (i < level) {
      digitalWrite(ledPins[i], HIGH);
    } else {
  delay(500);  // Delay before next update
