Tilt LED 2.0
Kit purchase
Includes ESP32 board |
PURCHASE LINK |
ESP32 Ultimate Starter Kit |
ESP32 WROOM 32E + |
Universal Maker Sensor Kit |
Course Introduction
This project controls an array of LEDs based on the tilt angle detected by an MPU6050 sensor.
The LEDs illuminate in response to X-axis tilt, visually indicating the board’s orientation.
Tilt angles are continuously calculated from acceleration data provided by the MPU6050, and corresponding LEDs activate according to predefined angle thresholds.
If this is your first time working with an ESP32 project, we recommend downloading and reviewing the basic materials first.
SN |
COMPONENT INTRODUCTION |
QUANTITY |
PURCHASE LINK |
Arduino Nano ESP32 |
USB Type-C cable |
Breadboard |
Wires |
Several |
1kΩ resistor |
Several |
LED |
Several |
7 |
MPU6050 Module |
Common Connections:
LED
Connect the LEDs cathode to a 1kΩ resistor then to the negative power bus on the breadboard, and the LEDs anode to D6 to D12 on the ESP32.
MPU6050
SDA: Connect to D2 on the ESP32.
SCL: Connect to D3 on the ESP32.
Writing the Code
To install the library, use the Arduino Library Manager and search for MPU6050 and install it.
Don’t forget to select the board(Arduino Nano ESP32) and the correct port before clicking the Upload button.
#include <Wire.h>
#include <MPU6050.h>
MPU6050 mpu;
// LED pins (you have verified these work)
// Pin -> LED -> Resistor -> GND (HIGH = ON)
const int ledPins[] = {12, 11, 10, 9, 8, 7, 6};
const int ledCount = sizeof(ledPins) / sizeof(ledPins[0]);
// 6 boundaries -> 7 LED regions
const float thresholds[] = {-30, -15, -5, 5, 15, 30};
// LED helpers
void ledWrite(int pin, bool on) {
digitalWrite(pin, on ? HIGH : LOW);
void allLedsOff() {
for (int i = 0; i < ledCount; i++) ledWrite(ledPins[i], false);
void allLedsOn() {
for (int i = 0; i < ledCount; i++) ledWrite(ledPins[i], true);
// LED self-test to confirm wiring
void ledSelfTest() {
allLedsOff();
for (int i = 0; i < ledCount; i++) {
delay(200);
allLedsOn();
delay(400);
allLedsOff();
delay(200);
// Map angle to LED index
int getLEDIndex(float angleX) {
const int n = sizeof(thresholds) / sizeof(thresholds[0]);
for (int i = 0; i < n; i++) {
if (angleX < thresholds[i]) return i;
return ledCount - 1;
void updateLEDs(float angleX) {
allLedsOff();
int idx = getLEDIndex(angleX);
if (idx >= 0 && idx < ledCount) {
ledWrite(ledPins[idx], true);
Serial.begin(115200);
delay(200);
// LED setup
pinMode(ledPins[i], OUTPUT);
Serial.println("LED self-test start...");
ledSelfTest();
Serial.println("LED self-test done.");
// ---- I2C init (IMPORTANT CHANGE) ----
// MPU6050 SDA -> D2
// MPU6050 SCL -> D3
Wire.begin(D2, D3);
// MPU6050 init
Serial.println("Init MPU6050...");
mpu.initialize();
if (!mpu.testConnection()) {
Serial.println("MPU6050 connection failed. Blinking all LEDs.");
while (true) {
allLedsOn();
delay(300);
allLedsOff();
delay(300);
Serial.println("MPU6050 connected.");
int16_t ax, ay, az;
mpu.getAcceleration(&ax, &ay, &az);
// Calculate tilt angle around X axis
float angleX = atan2((float)ay, (float)az) * 180.0f / PI;
Serial.print("angleX=");
Serial.println(angleX);
updateLEDs(angleX);
delay(100);
