Auto Pump
Kit purchase
Includes ESP32 board |
PURCHASE LINK |
ESP32 Ultimate Starter Kit |
ESP32 WROOM 32E + |
Universal Maker Sensor Kit |
Course Introduction
This program uses an Nano ESP32 board with Ultrasonic Sensor Module and a water pump.
The sensor is used to detect the presence of an object.
When an object is detected, the water pump is activated to dispense liquid .
If this is your first time working with an ESP32 project, we recommend downloading and reviewing the basic materials first.
SN |
COMPONENT INTRODUCTION |
QUANTITY |
PURCHASE LINK |
Arduino Nano ESP32 |
USB Type-C cable |
Breadboard |
Wires |
Several |
Power Supply |
Ultrasonic Sensor Module |
7 |
TA6586 - Motor Driver Chip |
8 |
Centrifugal Pump |
Common Connections:
Trig: Connect to D3 on the ESP32.
Echo: Connect to D4 on the ESP32.
GND: Connect to GND on the ESP32.
VCC: Connect to 3.3V on the ESP32.
BI: Connect to D9 on the ESP32.
FI: Connect to D10 on the ESP32.
Centrifugal Pump
Connect to TA6586 B0.
Connect to TA6586 F0.
Writing the Code
Don’t forget to select the board(Arduino Nano ESP32) and the correct port before clicking the Upload button.
#include <Arduino.h>
#include <math.h>
Arduino Nano ESP32 + Ultrasonic (Echo=D4, Trig=D3) + TA6586 Pump Control
Behavior:
- Turn pump ON when distance < ON_THRESHOLD_CM
- Turn pump OFF when distance > OFF_THRESHOLD_CM (hysteresis)
- Median-of-5 sampling; pulseIn timeout
- Min ON/OFF hold times to avoid chattering
// -------- Pins --------
// Ultrasonic: Echo -> D4, Trig -> D3
const uint8_t ECHO_PIN = D4;
const uint8_t TRIG_PIN = D3;
// TA6586 motor driver pins (change if you wired differently)
const uint8_t MOTOR_BI = D9; // IN1
const uint8_t MOTOR_FI = D10; // IN2
// -------- Tuning --------
const float ON_THRESHOLD_CM = 10.0f; // pump ON below this
const float OFF_THRESHOLD_CM = 12.0f; // pump OFF above this (hysteresis)
const uint8_t SAMPLES = 5; // median-of-5
const uint32_t PULSE_TIMEOUT_US = 30000UL; // 30ms timeout
// Minimum hold times to protect the pump from rapid toggling
const uint32_t MIN_ON_HOLD_MS = 1500;
const uint32_t MIN_OFF_HOLD_MS = 800;
// Optional: ambient temperature (°C) for speed-of-sound correction
const float AMBIENT_TEMP_C = 20.0f;
// -------- State --------
enum PumpState { PUMP_OFF = 0, PUMP_ON = 1 };
PumpState pumpState = PUMP_OFF;
uint32_t lastToggleMs = 0;
// -------- Pump helpers --------
void pumpForward() {
// Direction depends on your wiring; swap HIGH/LOW or use pumpReverse() if needed.
digitalWrite(MOTOR_FI, LOW);
digitalWrite(MOTOR_BI, HIGH);
void pumpReverse() {
digitalWrite(MOTOR_BI, LOW);
digitalWrite(MOTOR_FI, HIGH);
void pumpStop() {
// Stop (coast). If your driver supports brake mode, follow its datasheet.
// -------- Ultrasonic helpers --------
float usPerCm() {
// Speed of sound (m/s) ≈ 331.4 + 0.6*T(°C)
float v = 331.4f + 0.6f * AMBIENT_TEMP_C; // m/s
float us_per_m = 1e6f / v; // µs per meter (one-way)
return (us_per_m * 0.01f) * 2.0f; // round-trip µs per cm
float measureOnceCm() {
// Send 10us trigger pulse
digitalWrite(TRIG_PIN, LOW);
delayMicroseconds(2);
digitalWrite(TRIG_PIN, HIGH);
delayMicroseconds(10);
// Read echo pulse width with timeout
unsigned long dur = pulseIn(ECHO_PIN, HIGH, PULSE_TIMEOUT_US);
if (dur == 0) return NAN; // timeout -> invalid reading
return dur / usPerCm(); // convert to cm
float readDistanceMedianCm() {
float vals[SAMPLES];
for (uint8_t i = 0; i < SAMPLES; i++) {
vals[i] = measureOnceCm();
delay(5); // small gap between pings
// Insertion sort for small N; push NANs to the end
for (uint8_t i = 1; i < SAMPLES; i++) {
float key = vals[i];
int j = i - 1;
while (j >= 0 && (isnan(vals[j]) || vals[j] > key)) {
vals[j + 1] = vals[j];
j--;
vals[j + 1] = key;
return vals[SAMPLES / 2]; // median
// -------- Setup / Loop --------
// Ultrasonic
pinMode(ECHO_PIN, INPUT);
pinMode(TRIG_PIN, OUTPUT);
// Pump driver
pinMode(MOTOR_BI, OUTPUT);
pinMode(MOTOR_FI, OUTPUT);
pumpStop(); // safe default
// Debug serial
Serial.begin(115200);
delay(300);
Serial.println("Nano ESP32: Ultrasonic + Pump (Echo=D4, Trig=D3) ready.");
float d = readDistanceMedianCm();
uint32_t now = millis();
bool valid = !isnan(d);
// State machine with hysteresis + min hold times
switch (pumpState) {
case PUMP_OFF:
if (valid && d < ON_THRESHOLD_CM && (now - lastToggleMs >= MIN_OFF_HOLD_MS)) {
pumpForward(); // switch to pumpReverse() if direction is wrong
pumpState = PUMP_ON;
lastToggleMs = now;
Serial.println("Pump -> ON");
break;
case PUMP_ON:
if (valid && d > OFF_THRESHOLD_CM && (now - lastToggleMs >= MIN_ON_HOLD_MS)) {
pumpStop();
lastToggleMs = now;
Serial.println("Pump -> OFF");
break;
// Debug print
if (valid) {
Serial.print("Distance(cm): ");
Serial.print(d, 1);
Serial.print(" | State: ");
Serial.println(pumpState == PUMP_ON ? "ON" : "OFF");
} else {
Serial.println("Distance: INVALID (timeout)");
delay(60);
