Speed Meter
Kit purchase
../_images/esp32_kit1.png
Includes ESP32 board
PURCHASE LINK
ESP32 Ultimate Starter Kit
ESP32 WROOM 32E +
Universal Maker Sensor Kit
Course Introduction
In this lesson, you’ll learn how to use an L9110 Motor Driver Module, a TT motor, and an OLED display with the Arduino Nano ESP32 to build a simple Motor Speed Control system.
A button press cycles through multiple speed levels, and the motor speed is displayed on the OLED as both a numeric RPM value and a bar graph.
SN
COMPONENT INTRODUCTION
QUANTITY
PURCHASE LINK
Arduino Nano ESP32
USB Cable
Wires
Several
OLED Display Module
TT Motor
Button
../_images/Smart_speed_bb.png
Common Connections:
  • OLED Display Module
    • SDA: Connect to A4 on the ESP32.
    • SCK: Connect to A5 on the ESP32.
  • Button
    • Connect to breadboard’s negative power bus.
    • Connect to D2 on the ESP32.
  • TT Motor
    • Connect to MOTOR A on the L9110 Motor Driver Module.
  • L9110 Motor Driver Module
    • A-1B: Connect to D5 on the Arduino.
    • A-1A: Connect to D6 on the Arduino.
Writing the Code
  • To install the library, use the Arduino Library Manager and search for Adafruit SSD1306 and Adafruit GFX and install it.
  • Don’t forget to select the board(Arduino UNO R4) and the correct port before clicking the Upload button.
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
// -------------------- OLED Settings --------------------
#define SCREEN_WIDTH 128
#define SCREEN_HEIGHT 64
#define OLED_RESET    -1
#define OLED_ADDR     0x3C
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
// -------------------- Motor Pins (L9110) --------------------
#define MOTOR_PIN1 5
#define MOTOR_PIN2 6
// -------------------- Button Pin --------------------
#define BUTTON_PIN 2
// -------------------- Motor Speed Levels --------------------
// PWM duty values (0..255)
int speedLevels[5] = {0, 190, 200, 230, 255};
int currentLevel = 0;
// -------------------- Button Debounce --------------------
bool lastButtonState = HIGH;
unsigned long lastDebounceTime = 0;
const unsigned long debounceDelay = 200;
// -------------------- ESP32 PWM (LEDC) Settings --------------------
// New ESP32 core supports ledcAttach(pin, freq, resolutionBits)
const uint32_t PWM_FREQ = 20000;   // 20kHz
const uint8_t  PWM_RES  = 8;       // 8-bit => duty 0..255
// -------------------- Helper: set motor duty --------------------
void setMotorPWM(int duty1, int duty2) {
  // Clamp to 0..255
  if (duty1 < 0) duty1 = 0;
  if (duty1 > 255) duty1 = 255;
  if (duty2 < 0) duty2 = 0;
  if (duty2 > 255) duty2 = 255;
  // Write PWM duty by pin (ESP32 new API)
  ledcWrite(MOTOR_PIN1, duty1);
  ledcWrite(MOTOR_PIN2, duty2);
  pinMode(BUTTON_PIN, INPUT_PULLUP);
  // -------------------- Setup ESP32 PWM --------------------
  // Attach PWM to both motor pins
  ledcAttach(MOTOR_PIN1, PWM_FREQ, PWM_RES);
  ledcAttach(MOTOR_PIN2, PWM_FREQ, PWM_RES);
  // Motor stop at boot
  setMotorPWM(0, 0);
  // -------------------- Initialize OLED --------------------
  if (!display.begin(SSD1306_SWITCHCAPVCC, OLED_ADDR)) {
    while (true) { delay(1000); } // Stop if OLED not found
  display.clearDisplay();
  display.display();
  handleButton();
  updateMotor();
  drawSpeed();
  delay(50);
void handleButton() {
  bool buttonState = digitalRead(BUTTON_PIN);
  // Detect falling edge with debounce
  if (buttonState == LOW && lastButtonState == HIGH &&
      (millis() - lastDebounceTime) > debounceDelay) {
    currentLevel++;
    if (currentLevel > 4) currentLevel = 0; // Loop back to stop
    lastDebounceTime = millis();
  lastButtonState = buttonState;
void updateMotor() {
  int speed = speedLevels[currentLevel];
  // Forward: IN1 = PWM, IN2 = 0
  // Stop: both 0
  if (speed == 0) {
    setMotorPWM(0, 0);
  } else {
    setMotorPWM(speed, 0);
void drawSpeed() {
  int pwm = speedLevels[currentLevel];
  // Approximate RPM display (just a rough mapping)
  float rpm = (pwm / 255.0f) * 200.0f;
  // Bar length (max 100px)
  int barLength = map(pwm, 0, 255, 0, 100);
  // --- Display numeric speed (big font) ---
  display.setTextSize(2);
  display.setTextColor(SSD1306_WHITE);
  display.setCursor(0, 0);
  display.print("RPM");
  display.setCursor(0, 20);
  display.print((int)rpm);
  // --- Draw bar graph ---
  display.drawRect(10, 50, 100, 10, SSD1306_WHITE);
  display.fillRect(10, 50, barLength, 10, SSD1306_WHITE);
  display.display();
