RGB Controll
Kit purchase
../_images/esp32_kit1.png
Includes ESP32 board
PURCHASE LINK
ESP32 Ultimate Starter Kit
ESP32 WROOM 32E +
Universal Maker Sensor Kit
Course Introduction
In this lesson, you’ll learn how to use a potentiometer with the Arduino Nano ESP32 to control an RGB LED.
As you turn the knob, the LED color smoothly transitions through red, yellow, green, and blue, creating a dynamic color blending effect.
If this is your first time working with an ESP32 project, we recommend downloading and reviewing the basic materials first.
SN
COMPONENT INTRODUCTION
QUANTITY
PURCHASE LINK
Arduino Nano ESP32
USB Type-C cable
Wires
Several
Potentiometer
RGB LED
../_images/RGB_color_bb1.png
Common Connections:
  • RGB LED
    • R: Connect to D9 on the ESP32.
    • Y: Connect to D10 on the ESP32.
    • G: Connect to D11 on the ESP32.
  • Potentiometer
    • OUT: Connect to A0 on the ESP32.
    • VCC: Connect to 3.3V on the ESP32 Extension Board.
Writing the Code
  • Don’t forget to select the board(Arduino Nano ESP32) and the correct port before clicking the Upload button.
  Arduino Nano ESP32 (ESP32-S3)
  RGB LED color blending with potentiometer (LEDC PWM)
// RGB LED pins (use Dx labels)
const int redPin   = D9;
const int greenPin = D10;
const int bluePin  = D11;
// Potentiometer pin (ADC)
const int potPin = A0;
// PWM settings
const int PWM_FREQ = 5000;     // 5 kHz
const int PWM_RES  = 8;        // 8-bit resolution (0~255)
  Serial.begin(115200);
  delay(200);
  // Attach PWM to pins (Arduino-ESP32 3.x style)
  ledcAttach(redPin,   PWM_FREQ, PWM_RES);
  ledcAttach(greenPin, PWM_FREQ, PWM_RES);
  ledcAttach(bluePin,  PWM_FREQ, PWM_RES);
  // Optional: Set ADC behavior (not required, but helps stability)
  analogReadResolution(12); // ESP32 ADC default is typically 12-bit (0~4095)
  // Read potentiometer value (ESP32 ADC: 0~4095)
  int potValue = analogRead(potPin);
  Serial.println(potValue);
  // Map ADC value to 0~765 for color blending
  int range = map(potValue, 0, 4095, 0, 765);
  int r = 0, g = 0, b = 0;
  // Blend RGB colors based on range
  if (range <= 255) {
    r = 255;
    g = range;
    b = 0;
  } else if (range <= 510) {
    r = 510 - range;
    g = 255;
    b = range - 255;
  } else {
    r = 0;
    g = 765 - range;
    b = 255;
  // Output PWM (inverted for common-anode RGB LED)
  // If you are using common-cathode, remove the "255 -" inversion.
  ledcWrite(redPin,   255 - r);
  ledcWrite(greenPin, 255 - g);
  ledcWrite(bluePin,  255 - b);
  delay(20);
