Play with Python
Learn how to set up your Raspberry Pi environment: install Raspberry Pi OS, configure Wi-Fi, and enable remote access so you can run Python code easily. If you already know how to use Raspberry Pi and access its command line, you may skip directly to the later parts.
Quick Guide on Python
Calibrating PiCrawler
As soon as the assembly is completed, you need to calibrate the PiCrawler to prevent it from damaging the servo if there is a slight deviation in the assembly.
Hands-on Python Projects
In this section, you will explore practical Python projects to control and extend PiCrawler. These examples demonstrate movement control, sensor-based interaction, sound effects, and computer vision features, helping you learn how to build your own PiCrawler applications.
