4. Obstacle Avoidance
In this project, picrawler will use an ultrasonic module to detect obstacles in front. When PiCrawler detects an obstacle, it will send a signal and look for another direction to move forward.
Run the Code
cd ~/picrawler/examples
sudo python3 4_avoid.py
When the program starts, PiCrawler stands up.
It continuously measures the distance using the ultrasonic sensor and prints the value in the terminal.
If an obstacle is detected within 15 cm: - A warning sound is played. - The robot performs a small left turn.
If the path is clear: - The robot moves forward.
The robot keeps avoiding obstacles automatically until you press Ctrl+C.
Before exiting, it safely sits down.
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like picrawler\examples. After modifying the code, you can run it directly to see the effect.
from robot_hat import Music, Ultrasonic, Pin
import signal
music = Music()
crawler = Picrawler()
sonar = Ultrasonic(Pin("D2"), Pin("D3"))  # Ultrasonic trigger/echo pins
music.music_set_volume(100)  # Set speaker volume
alert_distance = 15  # Obstacle warning distance (cm)
speed = 80           # Movement speed
# Add hardware timeout to sonar.read()
# Prevent program from freezing
class Timeout(Exception):
def _alarm_handler(signum, frame):
    raise Timeout()
signal.signal(signal.SIGALRM, _alarm_handler)
# Read distance once with timeout protection
def safe_read_once(timeout_s=1):
        signal.alarm(timeout_s)
        d = sonar.read()
        signal.alarm(0)
        return d
    except Timeout:
        signal.alarm(0)
        return None
    except Exception:
        signal.alarm(0)
        return None
# Read multiple times and return median value (anti-noise)
def read_distance_filtered(n=5, gap=0.03, timeout_s=1):
    vals = []
    for _ in range(n):
        d = safe_read_once(timeout_s=timeout_s)
        if d is not None and d > 0:
            vals.append(d)
        time.sleep(gap)
    if not vals:
        return None
    vals.sort()
    return vals[len(vals)//2]  # Median filter
def main():
    distance = read_distance_filtered(n=5, gap=0.03, timeout_s=1)
    print("distance:", distance)
    if distance is None:
        time.sleep(0.15)  # Wait if read failed
        return
    if distance <= alert_distance:
        # Obstacle detected → play sound and turn
            music.sound_play_threading('./sounds/sign.wav', volume=100)
        except Exception as e:
            print("sound error:", e)
        crawler.do_action('turn left angle', 1, speed)
        time.sleep(0.5)  # Quiet window after movement
        # Path clear → move forward
        crawler.do_action('forward', 1, speed)
        time.sleep(0.4)
if __name__ == "__main__":
        crawler.do_step('stand', 40)  # Stand before starting
        time.sleep(1.0)
            main()
        print("\nStop.")
    finally:
            crawler.do_step('sit', 40)  # Sit before exit
            time.sleep(1.0)
        except Exception:
How it works?
  1. Initialization Block
    music = Music()
    alert_distance = 15
    speed = 80
    This block initializes the three main modules: - music: controls sound playback. - crawler: controls PiCrawler movement. - sonar: reads distance using the ultrasonic sensor.
    It also sets the speaker volume, the obstacle threshold (cm), and the movement speed.
  2. Timeout Setup Block (prevents sonar.read() from freezing)
        raise Timeout()
    The ultrasonic driver may block while waiting for the echo signal. This block installs a signal handler so the program can interrupt a stuck sonar.read() call and keep running.
  3. Function: safe_read_once()
            d = sonar.read()
            signal.alarm(0)
            return d
        except Timeout:
            signal.alarm(0)
            return None
        except Exception:
            signal.alarm(0)
            return None
    This function reads the ultrasonic distance once with timeout protection. - If the read succeeds, it returns the distance value. - If it times out or fails, it returns None instead of freezing.
  4. Function: read_distance_filtered()
        vals = []
        for _ in range(n):
                vals.append(d)
            time.sleep(gap)
        if not vals:
            return None
        vals.sort()
    This function improves reliability by reading multiple samples: - Invalid values (None or <= 0) are ignored. - The remaining values are sorted. - The median value is returned to reduce noise.
  5. Function: main() (core decision and action)
    def main():
        distance = read_distance_filtered(...)
            return
            music.sound_play_threading(...)
    This is the main control logic:
    • Reads a filtered distance value.
    • If reading fails, it skips this cycle.
    • If an obstacle is closer than alert_distance, it plays a warning sound and turns left.
    • Otherwise, it moves forward.
  6. Program Entry Block (continuous loop + safe exit)
                main()
            print("\nStop.")
        finally:
    This block controls the overall program flow: - The crawler stands up before starting. - The program runs main() repeatedly in an infinite loop. - Pressing Ctrl+C stops the loop. - The crawler sits down before the program exits.
