1. Move
This is PiCrawler’s first project. Perform its most basic function - move.
Run the Code
cd ~/picrawler/examples
sudo python3 1_move.py
When the program starts, PiCrawler stands up and waits briefly.
It then continuously performs a movement cycle: forward, backward, turn left, turn right, small left turn, and small right turn.
Each action is separated by short delays for smoother movement.
Press Ctrl+C to stop the program. Before exiting, the crawler sits down safely.
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like picrawler\examples. After modifying the code, you can run it directly to see the effect.
from time import sleep
crawler = Picrawler() # Create PiCrawler object
def main():
speed = 80 # Movement speed
crawler.do_step('stand', 40) # Stand up
sleep(1.0)
crawler.do_action('forward', 1, speed) # Move forward
sleep(0.25)
crawler.do_action('backward', 1, speed) # Move backward
sleep(0.25)
crawler.do_action('turn left', 1, speed) # Turn left
sleep(0.25)
crawler.do_action('turn right', 1, speed) # Turn right
sleep(0.25)
crawler.do_action('turn left angle', 1, speed) # Small left turn
sleep(0.3)
crawler.do_action('turn right angle', 1, speed) # Small right turn
sleep(0.3)
sleep(0.5)
print("\nCtrl+C pressed...")
finally:
crawler.do_step('sit', 40) # Sit down before exit
sleep(1.0)
if __name__ == "__main__":
main()
How it works?
Import and Initialization
from picrawler import Picrawler from time import sleep crawler = Picrawler()
The script imports the required modules and creates a
Picrawlerobject, which is used to control all robot movements.Main Function and Setup
def main(): speed = 80 crawler.do_step('stand', 40) sleep(1.0)
The
main()function defines the movement speed. Before starting the loop, the robot stands up and stabilizes.Continuous Movement Loop
while True: crawler.do_action('forward', 1, speed) crawler.do_action('backward', 1, speed) crawler.do_action('turn left', 1, speed) crawler.do_action('turn right', 1, speed) crawler.do_action('turn left angle', 1, speed) crawler.do_action('turn right angle', 1, speed)
The robot continuously performs a predefined sequence of movement actions inside an infinite loop. Short delays between actions help smooth motion.
Safe Exit Handling
except KeyboardInterrupt: print("\nCtrl+C pressed...") finally: crawler.do_step('sit', 40)
The
try / except / finallystructure ensures: - Ctrl+C stops the loop safely. - The robot sits down before the program exits.Program Entry
if __name__ == "__main__": main()
This ensures that
main()runs only when the script is executed directly.
