13. Emotional Robot
This example shows several interesting custom actions of PiCrawler.
Run the Code
cd ~/picrawler/examples
sudo python3 13_emotional_robot.py
After running the program, the robot first stands up slowly to reach a stable posture.
It then performs a series of motions, including swimming-like movements, push-ups, waving gestures with the front legs, and a twisting dance. These actions are executed sequentially, creating a dynamic and expressive behavior.
If Ctrl+C is pressed, the program exits safely and the robot returns to a sitting position.
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like picrawler\examples. After modifying the code, you can run it directly to see the effect.
from time import sleep
crawler = Picrawler()
def get_sit_step():
# Get a valid sit step used as the base pose for hand actions
return crawler.move_list['sit'][0]
except Exception:
return None
def handwork(speed):
base = get_sit_step()
# If a valid sit step cannot be retrieved, just perform a sit action
if not base or len(base) < 4:
crawler.do_step('sit', speed)
sleep(0.6)
return
# Generate hand poses by modifying the sit step
left_hand = crawler.mix_step(base, 0, [0, 50, 80])
right_hand = crawler.mix_step(base, 1, [0, 50, 80])
two_hand = crawler.mix_step(left_hand, 1, [0, 50, 80])
sleep(0.6)
crawler.do_step(left_hand, speed)
sleep(0.6)
crawler.do_step(two_hand, speed)
sleep(0.6)
crawler.do_step(right_hand, speed)
sleep(0.6)
sleep(0.6)
def twist(speed):
# Initialize the base position for all four legs
new_step = [[50, 50, -80], [50, 50, -80], [50, 50, -80], [50, 50, -80]]
# Create a twisting motion by alternating rise and drop movements
for i in range(4):
for inc in range(30, 60, 5):
rise = [50, 50, (-80 + inc * 0.5)]
drop = [50, 50, (-80 - inc)]
new_step[i] = rise
new_step[(i + 2) % 4] = drop
new_step[(i + 1) % 4] = rise
new_step[(i - 1) % 4] = drop
crawler.do_step(new_step, speed)
sleep(0.02)
def pushup(speed):
# Two poses used to simulate a push-up motion
up = [[80, 0, -100], [80, 0, -100], [0, 120, -60], [0, 120, -60]]
down = [[80, 0, -30], [80, 0, -30], [0, 120, -60], [0, 120, -60]]
crawler.do_step(up, speed)
sleep(0.6)
crawler.do_step(down, speed)
sleep(0.6)
def swimming(speed, loops=100):
# Simulate a swimming-like motion by gradually adjusting leg coordinates
for i in range(loops):
crawler.do_step(
[100 - i, i, 0],
[100 - i, i, 0],
[0, 120, -60 + i / 5],
[0, 100, -40 - i / 5]
speed
sleep(0.01)
def main():
speed = 100
# Stand up slowly before performing actions
crawler.do_step('stand', 40)
sleep(1.0)
swimming(speed)
pushup(speed)
handwork(speed)
twist(speed)
print("\nCtrl+C detected, exiting...")
finally:
# Return to a sitting posture before exiting
crawler.do_step('sit', 40)
sleep(1.0)
except Exception:
if __name__ == "__main__":
main()
How it works?
When the program starts, the robot first stands up slowly to reach a stable posture.
crawler.do_step('stand', 40) sleep(1.0)
After standing, the program executes several predefined motions in sequence.
Swimming Motion
The robot performs a swimming-like movement by gradually adjusting the leg coordinates.
for i in range(loops): crawler.do_step([ [100-i, i, 0], [100-i, i, 0], [0,120,-60+i/5], [0,100,-40-i/5] ], speed)
Push-up Motion
Two poses are defined to simulate a push-up movement.
up = [[80,0,-100],[80,0,-100],[0,120,-60],[0,120,-60]] down = [[80,0,-30],[80,0,-30],[0,120,-60],[0,120,-60]] crawler.do_step(up, speed) crawler.do_step(down, speed)
Handwork Motion
The program modifies the coordinates of the front legs using
mix_step()to create a waving gesture.left_hand = crawler.mix_step(base,0,[0,50,80]) right_hand = crawler.mix_step(base,1,[0,50,80])
Twist Motion
The robot twists its body by raising and lowering diagonal legs.
rise = [50,50,(-80+inc*0.5)] drop = [50,50,(-80-inc)] crawler.do_step(new_step, speed)
