9. Pose
PiCrawler can assume a specific posture by writing a coordinate array. Here it assumes a raised right rear foot posture.
../_images/4cood.A.png
Run the Code
cd ~/picrawler/examples
sudo python3 9_do_step.py
After running the program, the robot first stands up slowly to reach a stable posture.
Once standing, the robot repeatedly performs two actions in a loop. It first moves into a standing step posture and holds the position for a few seconds, then switches to a custom step where the legs move to different coordinates. This creates a repeating posture-changing motion.
The robot continues alternating between these two poses until the program is stopped. If Ctrl+C is pressed, the program exits safely and the robot returns to a sitting position.
from time import sleep
# Create Picrawler instance
crawler = Picrawler()
# Leg order:
# [right front], [left front], [left rear], [right rear]
new_step = [[45, 45, -75], [45, 0, -75], [45, 0, -30], [45, 45, -75]]
# Get the default stand step from the move list
stand_step = crawler.move_list['stand'][0]
def main():
    action_speed = 80  # Speed for movement actions
        # Stand up slowly at 40% speed to reduce current spikes
        crawler.do_step('stand', 40)
        sleep(1.0)
        # Continuous action loop
            crawler.do_step(stand_step, action_speed)
            sleep(3)
            crawler.do_step(new_step, action_speed)
            sleep(3)
        # Handle Ctrl+C for safe exit
        print("\nExiting safely...")
    finally:
        # Return to sitting position before shutting down
            crawler.do_step('sit', 40)
            sleep(1.0)
        except Exception:
if __name__ == "__main__":
    main()
How it works?
In this code, the code you need to pay attention to is this crawler.do_step().
Similar to do_action(), do_step() can also manipulate PiCrawler’s behavior. The difference is that the former can perform the continuous behavior of move forward, while the latter can be used to make separate gestures of stand and sit.
It has two uses:
One: It can write strings, directly use the step_list dictionary in the picrawler library.
crawler.do_step('stand',speed)
# "speed" indicates the speed of the step, the range is 0~100.
Second: It can also write an array of 4 coordinate values.
new_step=[[45, 45, -75], [45, 0, -75], [45, 0, -30], [45, 45, -75]]
# These four coordinates are used to control the four legs of right front, left front, left rear, and left rear respectively.
Each foot has an independent coordinate system. As shown below:
../_images/4cood.png
You need to measure the coordinates of each toe individually. As shown below:
../_images/1cood.png
By the way: the step_list called in the first method also consists of an array containing 4 coordinate values.
step_list = {
    "stand":[
        [45, 45, -50],
        [45, 45, -50],
        [45, 45, -50],
        [45, 45, -50]
    "sit":[
        [45, 45, -30],
        [45, 45, -30],
        [45, 45, -30],
        [45, 45, -30]
