2. Keyboard Control
In this project, we will learn how to use the keyboard to remotely control the PiCrawler. You can control the PiCrawler to move forward, backward, left, and right.
Run the Code
cd ~/picrawler/examples
sudo python3 2_keyboard_control.py
When the program starts, PiCrawler initializes and a keyboard control interface is displayed in the terminal.
Press keys on keyboard to control PiCrawler!
  • w: Forward
  • a: Turn left
  • s: Backward
  • d: Turn right
  • Ctrl+C: Quit
The current speed is shown and can be adjusted using:
    • / ] to increase speed
    • / [ to decrease speed
After each action, a short delay is applied for stability.
Press Ctrl+C to exit. Before shutting down, the crawler performs a safe “sit” action.
from time import sleep
import readchar
crawler = Picrawler()
SPEED_MIN = 20
SPEED_MAX = 70
speed = 60
STEP = 1            # Number of action steps per key press
ACTION_GAP = 0.25   # Delay after each action to reduce current spikes
manual = """
Keyboard Control - PiCrawler
Movement:
W: Forward
A: Turn left
S: Backward
D: Turn right
Speed Control:
+ / ] : Increase speed
- / [ : Decrease speed
Other:
Space  : Stop (no action)
Ctrl+C : Quit (auto sit)
def clamp(value, min_value, max_value):
    """Limit value within a specified range."""
    return max(min_value, min(max_value, value))
def show_info():
    """Clear terminal and display control instructions."""
    print("\033[H\033[J", end="")  # Clear terminal screen
    print(manual)
    print(f"Current speed: {speed}  (range {SPEED_MIN}-{SPEED_MAX})")
    print(f"Action gap: {ACTION_GAP:.2f}s")
def do_move(action_name):
    """Execute movement action with safety delay."""
    crawler.do_action(action_name, STEP, speed)
    sleep(ACTION_GAP)
def safe_sit():
    """Safely sit down before program exit."""
        crawler.do_step("sit", clamp(speed, 20, 40))
        sleep(1.0)
    except Exception:
def main():
    show_info()
            key = readchar.readkey()
            k = key.lower()
            if k == "w":
                do_move("forward")
            elif k == "s":
                do_move("backward")
            elif k == "a":
                do_move("turn left")
            elif k == "d":
                do_move("turn right")
            # Speed increase
            elif k in ("+", "]"):
                global speed
                speed = clamp(speed + 5, SPEED_MIN, SPEED_MAX)
            # Speed decrease
            elif k in ("-", "["):
                speed = clamp(speed - 5, SPEED_MIN, SPEED_MAX)
            # Stop (no movement)
            elif k == " ":
            # Quit using readchar special key
            elif key == readchar.key.CTRL_C:
                print("\nQuit.")
                break
            show_info()
            sleep(0.02)
        print("\nQuit (KeyboardInterrupt).")
    finally:
        safe_sit()
if __name__ == "__main__":
    main()
How it works?
  1. Creating the Robot Object
    This line creates a Picrawler object. It allows the program to control the robot’s movements.
  2. Defining Safe Speed Range
    SPEED_MIN = 20
    SPEED_MAX = 70
    speed = 60
    These variables define the allowed speed range. speed stores the current movement speed. The robot will not move faster than the maximum value.
  3. Limiting Speed with clamp()
    This function ensures that speed stays within the safe range. It prevents unstable movement caused by extreme values.
  4. Executing a Movement
        sleep(ACTION_GAP)
    This function sends a movement command to the robot. ACTION_GAP adds a short delay to improve stability.
  5. Reading Keyboard Input
    k = key.lower()
    The program waits for a key press. The key is converted to lowercase for consistency.
  6. Movement Control Logic
    if k == "w":
        do_move("forward")
    elif k == "s":
        do_move("backward")
    When a key is pressed, the corresponding movement is executed immediately. Pressing Enter is not required.
  7. Safe Exit
    finally:
        safe_sit()
    Before the program exits, the robot performs a safe “sit” action. This prevents unstable posture or sudden shutdown.
