πŸ‘‰ Ready to explore and create with us? Click [here] and join today!
6. Record Video
This example will guide you how to use the recording function.
Run the Code
cd ~/picrawler/examples
sudo python3 6_record_video.py
After the code runs, you can enter http://<your IP>:9000/mjpg in the browser to view the video screen. such as: http://192.168.18.113:9000/mjpg
../_images/display.png
Recording can be stopped or started by pressing the keys on the keyboard.
  • Press q to begin recording or pause/continue, e to stop recording or save.
  • If you want to exit the program, press Ctrl+C.
from time import sleep, strftime, localtime
from vilib import Vilib
import readchar
from os import getlogin
import os
USERNAME = getlogin()
VIDEO_PATH = f"/home/{USERNAME}/Videos/"
MANUAL = '''
Press keys on keyboard to control recording:
    Q: record/pause/continue
    E: stop
    Ctrl+C: Quit
def print_overwrite(msg, end='', flush=True):
    """Overwrite the current terminal line."""
    print('\r\033[2K', end='', flush=True)
    print(msg, end=end, flush=True)
def safe_stop_recording():
    """Stop recording safely (avoid exceptions during exit)."""
        Vilib.rec_video_stop()
    except Exception:
def safe_close_camera():
    """Close camera safely (avoid exceptions during exit)."""
        Vilib.camera_close()
    except Exception:
def main():
    rec_flag = 'stop'  # Possible states: start, pause, stop
    vname = None
    # Ensure the video directory exists
    os.makedirs(VIDEO_PATH, exist_ok=True)
    # Set save path for recorded videos
    Vilib.rec_video_set["path"] = VIDEO_PATH
    # Start camera and preview
    Vilib.camera_start(vflip=False, hflip=False)
    Vilib.display(local=False, web=True)
    sleep(0.8)  # Wait for camera startup
    print(MANUAL)
            # Read keyboard input (no Enter needed)
            key = readchar.readkey().lower()
            # Q: start / pause / continue
            if key == 'q':
                if rec_flag == 'stop':
                    rec_flag = 'start'
                    # Generate filename based on timestamp
                    vname = strftime("%Y-%m-%d-%H.%M.%S", localtime())
                    Vilib.rec_video_set["name"] = vname
                    # Start recording
                    Vilib.rec_video_run()
                    Vilib.rec_video_start()
                    print_overwrite('rec start ...')
                elif rec_flag == 'start':
                    rec_flag = 'pause'
                    Vilib.rec_video_pause()
                    print_overwrite('pause')
                elif rec_flag == 'pause':
                    rec_flag = 'start'
                    print_overwrite('continue')
            # E: stop recording
            elif key == 'e' and rec_flag != 'stop':
                rec_flag = 'stop'
                print_overwrite(
                    "The video saved as %s%s.avi" % (Vilib.rec_video_set["path"], vname),
                    end='\n'
            # Ctrl+C (readchar special key): quit
            elif key == readchar.key.CTRL_C:
                print('\nquit')
                break
            sleep(0.1)
        # Handle Ctrl+C from terminal as well
        print('\nquit')
    finally:
        # If recording is still active, stop it before closing camera
        if rec_flag != 'stop':
        safe_close_camera()
        sleep(0.1)
if __name__ == "__main__":
    main()
How it works?
  1. What This Program Does
    This program allows you to control video recording using your keyboard.
    • Q β†’ Start / Pause / Continue recording
    • E β†’ Stop recording
    • Ctrl+C β†’ Quit the program
    The recorded video will be saved in the Videos folder.
  2. Prepare the Video Folder
    The program finds your current username and creates a Videos folder if it does not already exist.
    All recorded videos will be saved here.
  3. Start the Camera
    sleep(0.8)
    The camera is turned on. Web preview is enabled so you can watch the live stream in your browser.
    The short delay allows the camera to start properly.
  4. Recording State Setup
    rec_flag = 'stop'
    vname = None
    The program uses a variable called rec_flag to remember the current recording state:
    • stop β†’ not recording
    • start β†’ recording
    • pause β†’ paused
  5. Wait for Keyboard Input
    The program waits for a key press.
  6. Press Q to Start Recording
    When you press Q for the first time:
    • A filename is generated using the current date and time
    • Recording starts immediately
    Example filename: 2026-03-03-15.30.21.avi
  7. Press Q Again to Pause
    If recording is already running, pressing Q will pause the recording.
  8. Press Q Again to Continue
    If recording is paused, pressing Q again will continue recording.
  9. Press E to Stop Recording
    Pressing E will completely stop the recording.
    The video file will be saved in: /home/your_username/Videos/
  10. Exit the Program Safely
    finally:
    When the program exits:
    • Recording is stopped (if still running)
    • The camera is closed safely
    This prevents broken video files or camera errors.
