7. Bull Fight
Make PiCrawler an angry bull! Use its camera to track and rush the red cloth!
Run the Code
cd ~/picrawler/examples
sudo python3 7_bull_fight.py
View the Image
After the code runs, the terminal will display the following prompt:
No desktop !
* Environment: production
* Debug mode: off
Then you can enter http://<your IP>:9000/mjpg in the browser to view the video screen. such as: https://192.168.18.113:9000/mjpg
../_images/display.png
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like picrawler\examples. After modifying the code, you can run it directly to see the effect.
from time import sleep, time
from robot_hat import Music
from vilib import Vilib
# Create robot and audio controller objects
crawler = Picrawler()
music = Music()
def main():
    # Start camera and enable preview window
    Vilib.camera_start(vflip=False, hflip=False)
    Vilib.display(local=False, web=True)
    # Enable red color detection
    Vilib.color_detect("red")
    speed = 80                  # Movement speed
    last_seen = False           # Indicates whether the red target was detected in previous loop
    last_beep = 0               # Timestamp of last sound playback
    BEEP_COOLDOWN = 1.0         # Minimum interval between sound effects (seconds)
    # Stand once before starting tracking
    crawler.do_step('stand', 40)
    sleep(1.0)
            # Read detection result
            if Vilib.detect_obj_parameter.get('color_n', 0) != 0:
                # Get horizontal coordinate of detected red object
                coordinate_x = Vilib.detect_obj_parameter.get('color_x', 0)
                # Play sound effect with cooldown to avoid spamming
                now = time()
                if now - last_beep >= BEEP_COOLDOWN:
                        music.sound_play_threading('./sounds/talk1.wav')
                    except Exception:
                    last_beep = now
                # Steering logic based on horizontal position
                # Left side of image
                if coordinate_x < 100:
                    crawler.do_action('turn left', 1, speed)
                # Right side of image
                elif coordinate_x > 220:
                    crawler.do_action('turn right', 1, speed)
                # Center area → move forward
                    crawler.do_action('forward', 2, speed)
                last_seen = True
                sleep(0.05)
                # No red target detected
                # Stop movement only once when target is lost
                # This prevents repeated stand() calls that cause "push-up" effect
                if last_seen:
                    last_seen = False
                sleep(0.15)
        # Stop program safely when Ctrl+C is pressed
        print("\nStop.")
    finally:
        # Cleanup section to avoid exit errors
        # Disable color detection
            Vilib.color_detect("close")
        except Exception:
        # Close camera safely
            Vilib.camera_close()
        except Exception:
        # Make the robot sit before exit
            crawler.do_step('sit', 40)
            sleep(1.0)
        except Exception:
if __name__ == "__main__":
    main()
How it works?
  1. Camera Initialization
    The camera is started and web preview is enabled. Red color detection is activated. Vilib continuously processes frames in the background and stores detection results in detect_obj_parameter.
  2. Robot Preparation
    sleep(1.0)
    The robot performs a stand action before tracking begins. A short delay ensures the posture is stable.
  3. Detecting the Target
    The program checks whether a red object is detected. If detected, it reads the horizontal center coordinate (x position) of the red object in the image.
  4. Steering Decision Logic
    The image is divided into three horizontal zones: left, center, and right.
    • Left zone → turn left
    • Right zone → turn right
    • Center zone → move forward
    This allows the robot to track and follow the red object.
  5. Sound Cooldown Mechanism
    now = time()
        last_beep = now
    A cooldown timer prevents repeated sound playback. The sound effect plays at most once per second even if the object remains detected.
  6. Target Lost Handling
    if last_seen:
        last_seen = False
    When the red object disappears, the robot stops and returns to a stable stand position.
    The last_seen flag ensures stand() is called only once. This prevents repeated posture reset that may cause shaking.
  7. Safe Exit and Cleanup
    finally:
    When the program exits (for example, Ctrl+C), color detection is disabled, the camera is closed safely, and the robot performs a sit action.
    This prevents camera errors and unstable shutdown behavior.
