5. Computer Vision
This project will officially enter the field of computer vision!
Run the Code
cd ~/picrawler/examples
sudo python3 5_display.py
View the Image
After the code runs, the terminal will display the following prompt:
No desktop !
* Environment: production
* Debug mode: off
Then you can enter http://<your IP>:9000/mjpg in the browser to view the video screen. such as: http://192.168.18.113:9000/mjpg
After the program runs, you will see the following information in the final:
Input key to call the function!
q: Take photo1: Color detect : red2: Color detect : orange3: Color detect : yellow4: Color detect : green5: Color detect : blue6: Color detect : purple0: Switch off Color detectr: Scan the QR codef: Switch ON/OFF face detects: Display detected object information
Please follow the prompts to activate the corresponding functions.
Take Photo
Type
qin the terminal. The picture currently seen by the camera will be saved (if the color detection function is turned on, the mark box will also appear in the saved picture). You can see these photos from the~/Pictures/PiCrawler/directory of the Raspberry Pi. You can use tools such as FileZilla Software to transfer photos to your PC.Color Detect
Entering a number between
1~6will detect one of the colors in “red, orange, yellow, green, blue, purple”. Enter0to turn off color detection.![]()
You can download and print the
PDF Color Cardsfor color detection.Face Detect
Type
fto turn on face detection.![]()
QR Code Detect
Enter
rto open the QR code recognition. No other operations can be performed before the QR code is recognized. The decoding information of the QR code will be printed in the terminal.![]()
Display Information
Entering
swill print the information of the face detection (and color detection) target in the terminal. Including the center coordinates (X, Y) and size (Weight, height) of the measured object.
from vilib import Vilib
from time import sleep, time, strftime, localtime
import threading
import readchar
from os import getlogin
USERNAME = getlogin()
PICTURE_PATH = f"/home/{USERNAME}/Pictures/"
flag_face = False
flag_color = False
qr_code_flag = False
MANUAL = '''
Press a key to call the function:
q: Take photo
r: Scan the QR code (toggle)
Ctrl+C: Quit
color_list = ['close', 'red', 'orange', 'yellow', 'green', 'blue', 'purple']
def face_detect(flag):
print("Face Detect:", flag)
Vilib.face_detect_switch(flag)
def qrcode_detect():
global qr_code_flag
Vilib.qrcode_detect_switch(True)
print("Waiting for QR code...")
text = None
while qr_code_flag:
temp = Vilib.detect_obj_parameter.get('qr_data', "None")
if temp != "None" and temp != text:
text = temp
print("QR code:", text)
sleep(0.2)
Vilib.qrcode_detect_switch(False)
def take_photo():
_time = strftime('%Y-%m-%d-%H-%M-%S', localtime(time()))
name = f'photo_{_time}'
Vilib.take_photo(name, PICTURE_PATH)
print(f'Photo saved as {PICTURE_PATH}{name}.jpg')
def object_show():
global flag_color, flag_face
if flag_color:
if Vilib.detect_obj_parameter.get('color_n', 0) == 0:
print('Color Detect: None')
x = Vilib.detect_obj_parameter.get('color_x')
y = Vilib.detect_obj_parameter.get('color_y')
w = Vilib.detect_obj_parameter.get('color_w')
h = Vilib.detect_obj_parameter.get('color_h')
print("[Color Detect] Coordinate:", (x, y), "Size:", (w, h))
if flag_face:
if Vilib.detect_obj_parameter.get('human_n', 0) == 0:
print('Face Detect: None')
x = Vilib.detect_obj_parameter.get('human_x')
y = Vilib.detect_obj_parameter.get('human_y')
w = Vilib.detect_obj_parameter.get('human_w')
h = Vilib.detect_obj_parameter.get('human_h')
print("[Face Detect] Coordinate:", (x, y), "Size:", (w, h))
def main():
global flag_face, flag_color, qr_code_flag
qrcode_thread = None
Vilib.camera_start(vflip=False, hflip=False)
Vilib.display(local=True, web=True)
print(MANUAL)
key = readchar.readkey().lower()
if key == 'q':
take_photo()
elif key in '0123456':
index = int(key)
if index == 0:
flag_color = False
Vilib.color_detect('close')
flag_color = True
Vilib.color_detect(color_list[index])
print('Color detect:', color_list[index])
elif key == 'f':
flag_face = not flag_face
face_detect(flag_face)
elif key == 'r':
qr_code_flag = not qr_code_flag
if qr_code_flag:
if qrcode_thread is None or not qrcode_thread.is_alive():
qrcode_thread = threading.Thread(target=qrcode_detect, daemon=True)
qrcode_thread.start()
print('QRcode Detect: close')
elif key == 's':
object_show()
sleep(0.05)
print("\nQuit.")
finally:
# Stop QR thread and switches
except Exception:
except Exception:
Vilib.face_detect_switch(False)
except Exception:
# Close camera
Vilib.camera_close()
except Exception:
if __name__ == "__main__":
main()
How it works?
The first thing you need to pay attention to here is the following function. These two functions allow you to start the camera.
Vilib.camera_start()
Vilib.display()
Functions related to “object detection”:
Vilib.face_detect_switch(True): Switch ON/OFF face detectionVilib.color_detect(color): For color detection, only one color detection can be performed at the same time. The parameters that can be input are:"red","orange","yellow","green","blue","purple"Vilib.color_detect_switch(False): Switch OFF color detectionVilib.qrcode_detect_switch(False): Switch ON/OFF QR code detection, Returns the decoded data of the QR code.Vilib.gesture_detect_switch(False): Switch ON/OFF gesture detectionVilib.traffic_sign_detect_switch(False): Switch ON/OFF traffic sign detection
The information detected by the target will be stored in the detect_obj_parameter = Manager().dict() dictionary.
In the main program, you can use it like this:
Vilib.detect_obj_parameter['color_x']
The keys of the dictionary and their uses are shown in the following list:
color_x: the x value of the center coordinate of the detected color block, the range is 0~320color_y: the y value of the center coordinate of the detected color block, the range is 0~240color_w: the width of the detected color block, the range is 0~320color_h: the height of the detected color block, the range is 0~240color_n: the number of detected color patcheshuman_x: the x value of the center coordinate of the detected human face, the range is 0~320human_y: the y value of the center coordinate of the detected face, the range is 0~240human_w: the width of the detected human face, the range is 0~320human_h: the height of the detected face, the range is 0~240human_n: the number of detected facestraffic_sign_x: the center coordinate x value of the detected traffic sign, the range is 0~320traffic_sign_y: the center coordinate y value of the detected traffic sign, the range is 0~240traffic_sign_w: the width of the detected traffic sign, the range is 0~320traffic_sign_h: the height of the detected traffic sign, the range is 0~240traffic_sign_t: the content of the detected traffic sign, the value list is [‘stop’,’right’,’left’,’forward’]gesture_x: The center coordinate x value of the detected gesture, the range is 0~320gesture_y: The center coordinate y value of the detected gesture, the range is 0~240gesture_w: The width of the detected gesture, the range is 0~320gesture_h: The height of the detected gesture, the range is 0~240gesture_t: The content of the detected gesture, the value list is [“paper”,”scissor”,”rock”]qr_date: the content of the QR code being detectedqr_x: the center coordinate x value of the QR code to be detected, the range is 0~320qr_y: the center coordinate y value of the QR code to be detected, the range is 0~240qr_w: the width of the QR code to be detected, the range is 0~320qr_h: the height of the QR code to be detected, the range is 0~320
