12. Twist
We already know how to make PiCrawler assume a specific pose, the next step is to combine the poses to form a continuous action.
Here, PiCrawler’s four feet are up and down in twos, jumping with the music.
Run the Code
cd ~/picrawler/examples
sudo python3 12_twist.py
After the program starts, the robot first stands up slowly to reach a stable posture.
Once standing, background music begins to play. At the same time, the robot performs a continuous twisting dance movement. During this motion, the four legs alternately rise and lower, creating a rhythmic twisting effect. The legs move in coordinated pairs so the body appears to sway from side to side.
A short delay between each step makes the motion smoother and more stable rather than abrupt or overly fast.
The robot continues dancing while the music plays. When Ctrl+C is pressed, the program stops and the robot safely returns to a sitting position before exiting.
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like picrawler\examples. After modifying the code, you can run it directly to see the effect.
from robot_hat import Music
from time import sleep
music = Music()
crawler = Picrawler()
def twist(speed):
new_step = [[50, 50, -80], [50, 50, -80], [50, 50, -80], [50, 50, -80]]
for i in range(4):
for inc in range(30, 60, 5):
rise = [50, 50, (-80 + inc * 0.5)]
drop = [50, 50, (-80 - inc)]
new_step[i] = rise
new_step[(i + 2) % 4] = drop
new_step[(i + 1) % 4] = rise
new_step[(i - 1) % 4] = drop
crawler.do_step(new_step, speed)
sleep(0.03) # small delay to make motion smoother and less "crazy"
def main():
# Stand up slowly first
crawler.do_step('stand', 40)
sleep(1.0)
# Start music
music.music_play('./musics/sports-Ahjay_Stelino.mp3')
music.music_set_volume(20)
twist(speed=100)
print("\nCtrl+C detected, exiting...")
finally:
# Sit down safely before exit
crawler.do_step('sit', 40)
sleep(1.0)
except Exception:
if __name__ == "__main__":
main()
How it works?
In this code, you need to pay attention to this part:
def twist(speed):
for i in range(4):
new_step[i] = rise
Simply put, it uses two layers of for loops to make the new_step array produce continuous and regular changes, and at the same time, crawler.do_step() executes the posture to form a continuous action.
You can intuitively get the coordinate value array corresponding to each pose from 10. Adjust Posture.
In addition, the example also played background music. The implementation method is as follows.
Play music by importing the following libraries.
Declare a Music object.
music = Music()
Play the background music in the picrawler/examples/musics directory and set the volume to 20. You can also add music to the musics folder via FileZilla Software.
