3. Sound Effect
In this example, we use PiCrawler’s (to be precise, Robot HAT’s) sound effects. It consists of three parts, namely Muisc, Sound, Text to Speech.
Install i2samp
Before using that functions, first activate the speaker so that it will be enabled and can make sounds.
Run i2samp.sh in, and this script will install everything needed to use i2s amplifier.
cd ~/picrawler/
sudo bash i2samp.sh
There will be several prompts asking to confirm the request. Respond to all prompts with a Y. After the changes have been made to the Raspberry Pi system, the computer will need to reboot for these changes to take effect.
After rebooting, run the i2samp.sh script again to test the amplifier. If a sound successfully plays from the speaker, the configuration is complete.
Run the Code
cd ~/picrawler/examples
sudo python3 3_sound_effect.py
When the program starts, a control menu is displayed in the terminal.
Pressing a key immediately triggers the corresponding function.
q: Toggles background music on or off.1: Plays several sound effects one after another (blocking mode).2: Plays the same sound effects using threading (non-blocking).t: The system speaks the word “Hello” using text-to-speech.
The program runs continuously and waits for key input.
Press Ctrl+C to stop the program. Before exiting, any background music is stopped automatically.
from time import sleep
import readchar
from robot_hat import Music, TTS
music = Music()
tts = TTS()
manual = '''
Press a key to trigger actions (no Enter needed):
q: Play/Stop background music
1: Play sound effect (blocking)
2: Play sound effect (threading)
t: Text to speak
Ctrl^C: quit
def main():
print(manual)
flag_bgm = False
music.music_set_volume(20)
tts.lang("en-US")
# Real-time key input (no Enter required)
key = readchar.readkey().lower()
if key == "q":
flag_bgm = not flag_bgm
if flag_bgm:
music.music_play('./musics/sports-Ahjay_Stelino.mp3')
music.music_stop()
elif key == "1":
music.sound_play('./sounds/talk1.wav')
sleep(0.05)
music.sound_play('./sounds/talk3.wav')
sleep(0.05)
music.sound_play('./sounds/sign.wav')
sleep(0.5)
elif key == "2":
music.sound_play_threading('./sounds/talk1.wav')
sleep(0.05)
music.sound_play_threading('./sounds/talk3.wav')
sleep(0.05)
music.sound_play_threading('./sounds/sign.wav')
sleep(0.5)
elif key == "t":
tts.say("Hello")
print("\nquit")
finally:
# Stop music before exit to reduce error messages
music.music_stop()
except Exception:
if __name__ == "__main__":
main()
How it works?
Functions related to background music include these:
music = Music(): Declare the object.music.music_set_volume(20): Set the volume, the range is 0~100.music.music_play(./musics/sports-Ahjay_Stelino.mp3): Play music files, here is the sports-Ahjay_Stelino.mp3 file under the./musicspath.music.music_stop(): Stop playing background music.
You can add different sound effects or music to musics or sounds folder via FileZilla Software.
Functions related to sound effects include these:
music = Music()music.sound_play('./sounds/talk1.wav'): Play the sound effect file, here is the talk1.wav file under the./musicspath.music.sound_play_threading('./sounds/talk1.wav'): Play the sound effect file in a new thread mode without suspending the main thread.
Functions related to Text to Speech include these:
tts = TTS()tts.say(words): Text audio.tts.lang("en-US"): Set the language.
Set the language by setting the parameters of lang("") with the following characters.
zh-CN |
Mandarin (Chinese) |
en-US |
English-United States |
en-GB |
English-United Kingdom |
de-DE |
Germany-Deutsch |
es-ES |
España-Español |
fr-FR |
France-Le français |
it-IT |
Italia-lingua italiana |
