Lesson 2 Flowing LED Lights
In this lesson, we will learn how to make eight LEDs blink as flowing water based on Raspberry Pi.
Newly Added Components
Schematic Diagram
In this experiment, connect 220Ωresistors to the anode (the longer pin of the LED) respectively, then the resistors to Pin 11, 12, 13, 15, 16, 18, 22 and 24 of Raspberry Pi, and connect the cathode (the short pin) of the LEDs to GND. We can see from the schematic diagram that the anode of LED connect to a current-limiting resistor and then to Raspberry Pi. Therefore, to turn on an LED, we need to make pins high level. This process can be realized by programming.
Build the Circuit
For C Language Users:
Command
1. Go to the folder of the code.
cd /home/pi/electronic-kit/for-raspberry-pi/c/Lesson_2_FlowingLedLights
2. Compile the code.
gcc 2_FlowingLedLights.c -lwiringPi
When using the gcc command, if you do not use -o, it will automatically output as a.out.
3. Run the executable file.
Now, you will see these 8 LEDs are lit one by one from left to right, and then one by one from right to left.
If it does not work after running, or there is an error prompt: "wiringPi.h: No such file or directory", please refer to C code is not working?.
#include <wiringPi.h>
#include <stdio.h>
const int LedPin[]={0,1,2,3,4,5,6,10}; //Define 8 LED pin
int main(void)
// When initialize wiring failed, print message to screen
if(wiringPiSetup() == -1){
for(int j=0;j<8;j++)
pinMode(LedPin[j], OUTPUT);// Set LedPin as output to write value to it.
digitalWrite(LedPin[j], LOW);
for(int i=0;i<8;i++)
// LED on
digitalWrite(LedPin[i], HIGH);
delay(100);
for(int i=7;i>-1;i--)
// LED off
digitalWrite(LedPin[i], LOW);
delay(100);
Code Explanation
4.const int LedPin[]={0,1,2,3,4,5,6,10};
Create an array, LedPin to define the eight LEDs then connect them to GPIO0 ~ GPIO6, GPIO10 respectively.
14. for(int j=0;j<8;j++)
15. {
16. pinMode(LedPin[j], OUTPUT);
17. digitalWrite(LedPin[j], LOW);
18. }
Use a for loop to set all 8 pins connected to LEDs to OUTPUT mode and LOW level.
21. for(int i=0;i<8;i++)
22. {
23. // LED on
24. digitalWrite(LedPin[i], HIGH);
25. delay(100);
26. }
Light up the LEDs in GPIO0~6 and GPIO10 successively. i increases progressively from 0 to 7, LED0 to LED7 changes accordingly, making it like a flowing LED light from left to right.
27. for(int i=7;i>-1;i--)
28. {
29. // LED off
30. digitalWrite(LedPin[i], LOW);
31. delay(100);
32. }
Close the LEDs in GPIO0~6 and GPIO10 successively. i increases progressively from 7 to 0, LED0 to LED7 changes accordingly, making it like a flowing LED light from right to left.
For Python Language Users
Command
cd /home/pi/electronic-kit/for-raspberry-pi/python
2. Run the code.
sudo python3 2_FlowingLed.py
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like electronic-kit/for-raspberry-pi/python. After modifying the code, you can run it directly to see the effect.
import RPi.GPIO as GPIO
pins = [17,18,27,22,23,24,25,8]
# Define a setup function for some setup
def setup():
GPIO.setmode(GPIO.BCM)
for i in range(0, 8, 1):
GPIO.setup(pins[i], GPIO.OUT, initial=GPIO.LOW)
# Define a main function for main process
def main():
# print ('...LED ON')
# Turn on LED
GPIO.output(pins[i], GPIO.HIGH)
time.sleep(0.1)
# print ('LED OFF...')
# Turn off LED
for i in range(7, -1, -1):
GPIO.output(pins[i], GPIO.LOW)
time.sleep(0.1)
# Define a destroy function for clean up everything after the script finished
def destroy():
# Turn off LED
# Release resource
GPIO.cleanup()
if __name__ == '__main__':
setup()
main()
# When 'Ctrl+C' is pressed, the child program
# destroy() will be executed.
destroy()
Code Explanation
9. for i in range(0, 8, 1):
10. GPIO.setup(pins[i], GPIO.OUT, initial=GPIO.LOW)
Use a for loop to set all 8 pins connected to LEDs to output mode and LOW level.
17. for i in range(0, 8, 1):
18. GPIO.output(pins[i], GPIO.HIGH)
19. time.sleep(0.1)
Variable i increases progressively from 0 to 8, increasing by 1 every time. Accordingly, set the pins in the array pins[i] to HIGH respectively to light up the LEDs and the lighting time is 0.1s. Then, you will see 8 LEDs light up one by one.
23. for i in range(7, -1, -1):
24. GPIO.output(pins[i], GPIO.LOW)
25. time.sleep(0.1)
Variable i decreases progressively from 7 to -1, decreasing by 1 every time. Then LED0~LED7 change accordingly, making it like a flowing LED light from right to left.
Phenomenon Picture
