Lesson 14 Quiz Buzzer System
In quiz shows, especially entertainment activities (e.g. competitive answering activities), organizers often apply a quiz buzzer system in order to accurately, fairly and visually determine the seat number of a responder. In this lesson, we will use some buttons, buzzers, and LEDs to make a quiz buzzer system.
Newly Added Components
Schematic Diagram
Button 2, 3 and 4 are answer buttons, and button 1 is the reset button. If button 2 is pressed first, the buzzer will beep, the corresponding LED will light up and all the other LEDs will go out. If you want to start another round, press button 1 to reset.
Build the Circuit
For C Language Users
Command
1. Go to the folder of the code.
cd /home/pi/electronic-kit/for-raspberry-pi/c/Lesson_14_AnswerMachine
2. Compile the code.
gcc 14_AnswerMachine.c -lwiringPi
3. Run the executable file.
Now, first press button 4 to get started. If you press button 1 first, you will see the corresponding LED light up and the buzzer will beep. Then press button 4 again to reset before you press other buttons.
If it does not work after running, or there is an error prompt: "wiringPi.h: No such file or directory", please refer to C code is not working?.
#include <wiringPi.h>
#include <stdio.h>
#define BeepPin 0
#define ResetBtnPin 1
const int BtnPin[] = {2,3,4};
const int LedPin[] = {21,22,23,24};
void Alarm()
for(int i=0;i<50;i++){
digitalWrite(BeepPin,HIGH); //the buzzer sound
delay(2); //delay 2ms
digitalWrite(BeepPin,LOW); //without sound
delay(2);
int main(void){
if(wiringPiSetup() == -1){ //when initialize wiring failed, print message to screen
pinMode(BeepPin, OUTPUT);
for(int j=1;j<4;j++)
pinMode(LedPin[j], OUTPUT);
digitalWrite(LedPin[j],LOW);
pinMode(LedPin[0], OUTPUT);
digitalWrite(LedPin[0],HIGH);
for(int k;k<3;k++)
pinMode(BtnPin[k], INPUT);
int flag = 1;
// if reset button is pressed
if(digitalRead(ResetBtnPin) == 1)
flag = 1;
digitalWrite(LedPin[0], HIGH);//Reset Led turns on
digitalWrite(LedPin[1],LOW);
digitalWrite(LedPin[2],LOW);
digitalWrite(LedPin[3],LOW);
if(flag==1)
//If the button1 press the first
if(digitalRead(BtnPin[0]) == 1)
flag = 0;
digitalWrite(LedPin[0],LOW);
Alarm(); //buzzer sound
digitalWrite(LedPin[1],HIGH);//turn the LED1 on only
while(digitalRead(ResetBtnPin));
if(digitalRead(BtnPin[1]) == 1)
flag = 0;
digitalWrite(LedPin[2],HIGH);//turn the LED2 on only
if(digitalRead(BtnPin[2]) == 1)
flag = 0;
digitalWrite(LedPin[3],HIGH);//turn the LED3 on only
Code Explanation
9. void Alarm()
10.{
11. for(int i=0;i<50;i++){
12. digitalWrite(BeepPin,HIGH); //the buzzer sound
13. delay(2);
14. digitalWrite(BeepPin,LOW); //without sound
15. delay(2);
16. }
17.}
Define a function to control the buzzer. The buzzer rings when this function is called in the main function.
38. int flag = 1;
Define a flag to judge whether the answer device is in the state of answering. When flag = 0, it indicates that someone is currently scrambling, and others cannot continue to answer first; when flag = 1, it means that the reset button has been pressed, and a new round of answer rush can be conducted.
42. if(digitalRead(ResetBtnPin) == 1)
43. {
44. flag = 1;
45. digitalWrite(LedPin[0], HIGH);//Reset Led turns on
46. digitalWrite(LedPin[1],LOW);
47. digitalWrite(LedPin[2],LOW);
48. digitalWrite(LedPin[3],LOW);
49. }
If the reset button is detected to have been pressed, it means that the answer begins. Now set flag to 1 and let the referee LED light up, the rest of the LED lights out.
53. if(digitalRead(BtnPin[0]) == 1)
54. {
55. flag = 0;
56. digitalWrite(LedPin[0],LOW);
57. Alarm(); //buzzer sound
58. digitalWrite(LedPin[1],HIGH);//turn the LED1 on only
59. digitalWrite(LedPin[2],LOW);
60. digitalWrite(LedPin[3],LOW);
61. while(digitalRead(ResetBtnPin));
62. }
In the process of quick answering, if the first button is recognized to have been pressed, the flag is set to 0, and then no other buttons are detected. At this time, the buzzer alarms, indicating that someone has successfully responsed, and the corresponding LED lights up. The identification codes of the remaining buttons are explained as above.
Having executed the instruction of successful quick answer, it enters the loop to judge whether the button reset is pressed. Here, if the button reset is pressed, then the next round of quickfire answering begins.
For Python Language Users
Command
cd /home/pi/electronic-kit/for-raspberry-pi/python
2. Run the code.
sudo python3 14_AnswerMachine.py
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like electronic-kit/for-raspberry-pi/python. After modifying the code, you can run it directly to see the effect.
import RPi.GPIO as GPIO
BeepPin = 17
ResetBtnPin = 18
BtnPin =(27,22,23)
LedPin =(5,6,13,19)
def setup():
GPIO.setmode(GPIO.BCM)
GPIO.setup(BeepPin, GPIO.OUT, initial=GPIO.LOW)
GPIO.setup(ResetBtnPin, GPIO.IN)
GPIO.setup(LedPin[0], GPIO.OUT, initial=GPIO.HIGH)
for i in range(1,4):
GPIO.setup(LedPin[i], GPIO.OUT, initial=GPIO.LOW)
for i in range(0,3):
GPIO.setup(BtnPin[i], GPIO.IN)
def Alarm():
for i in range(0,50):
GPIO.output(BeepPin,GPIO.HIGH)
time.sleep(0.003)
GPIO.output(BeepPin,GPIO.LOW)
time.sleep(0.003)
def loop():
flag = 1
if GPIO.input(ResetBtnPin) == 1:
flag = 1
GPIO.output(LedPin[0],GPIO.HIGH)
GPIO.output(LedPin[1],GPIO.LOW)
GPIO.output(LedPin[2],GPIO.LOW)
GPIO.output(LedPin[3],GPIO.LOW)
if flag == 1:
if GPIO.input(BtnPin[0]) == 1:
flag = 0
GPIO.output(LedPin[0],GPIO.LOW)
Alarm()
GPIO.output(LedPin[1],GPIO.HIGH)
elif GPIO.input(BtnPin[1]) == 1:
flag = 0
Alarm()
GPIO.output(LedPin[2],GPIO.HIGH)
elif GPIO.input(BtnPin[2]) == 1:
flag = 0
Alarm()
GPIO.output(LedPin[3],GPIO.HIGH)
def destroy():
# Turn off buzzer
GPIO.output(BeepPin, GPIO.LOW)
# Release resource
GPIO.cleanup()
if __name__ == '__main__':
setup()
loop()
# When 'Ctrl+C' is pressed, the child program
# destroy() will be executed.
destroy()
Code Explanation
19.def Alarm():
20. for i in range(0,50):
21. GPIO.output(BeepPin,GPIO.HIGH)
22. time.sleep(0.003)
23. GPIO.output(BeepPin,GPIO.LOW)
24. time.sleep(0.003)
Define a function to control the buzzer. The buzzer rings when this function is called in the function main.
27. flag = 1
Define a flag bit to judge whether the responder is in the state of answering. When flag = 0, it indicates that someone is currently scrambling, and others cannot continue to answer first; when flag = 1, it means that the reset button has been pressed, and a new round of answer rush can be conducted.
29. if GPIO.input(ResetBtnPin) == 1:
30. flag = 1
31. GPIO.output(LedPin[0],GPIO.HIGH)
32. GPIO.output(LedPin[1],GPIO.LOW)
33. GPIO.output(LedPin[2],GPIO.LOW)
34. GPIO.output(LedPin[3],GPIO.LOW)
If the recognition that reset button has been pressed is done, it means that answer begins. Now, set flag to 1, and let the referee LED light up, other LEDs light out.
36. if GPIO.input(BtnPin[0]) == 1:
37. flag = 0
38. GPIO.output(LedPin[0],GPIO.LOW)
39. Alarm()
40. GPIO.output(LedPin[1],GPIO.HIGH)
41. GPIO.output(LedPin[2],GPIO.LOW)
42. GPIO.output(LedPin[3],GPIO.LOW)
In the process of quick answering, if the first button is recognized to have been pressed, the flag is set to 0, and then no other buttons are detected. At this time, the buzzer alarms, indicating that there is a successful response, and the corresponding LED lights up. The identification codes of the remaining buttons are explained as above.
Phenomenon Picture
