Lesson 6 Tilt Switch
In this lesson, we’ll learn a new switch component, tilt switch. Here we apply two LEDs to indicate the current state of tilt switch. You can also use this kind of switch to make a sense light with the clamshell box.
Newly Added Components
Principle
The principle is very simple. When the switch is tilted in a certain angle, the ball inside rolls down and touches the two contacts connected to the pins outside, thus triggering circuits. Otherwise the ball will stay away from the contacts, thus breaking the circuits.
Schematic Diagram
Build the Circuit
For C Language Users
Command
1. Go to the folder of the code.
cd /home/pi/electronic-kit/for-raspberry-pi/c/Lesson_6_TiltSwitch
2. Compile the code.
gcc 6_Tilt.c -lwiringPi
3. Run the executable file.
When the tilt switch is level, the green LED turns on. If you tilt the switch, the red LED will turn on.
If it does not work after running, or there is an error prompt: "wiringPi.h: No such file or directory", please refer to C code is not working?.
#include <wiringPi.h>
#include <stdio.h>
#define TiltPin 0
#define Gpin 2
#define Rpin 3
int main(void)
pinMode(TiltPin, INPUT);
pinMode(Gpin, OUTPUT);
pinMode(Rpin, OUTPUT);
if(1 == digitalRead(TiltPin)){
delay(10);
digitalWrite(Rpin, HIGH);
digitalWrite(Gpin, LOW);
printf("RED\n");
else if(0 == digitalRead(TiltPin)){
delay(10);
while(!digitalRead(TiltPin));
digitalWrite(Rpin, LOW);
digitalWrite(Gpin, HIGH);
printf("GREEN\n");
Code Explanation
15. pinMode(TiltPin, INPUT);
16. pinMode(Gpin, OUTPUT);
17. pinMode(Rpin, OUTPUT);
Initialize pins, then set the pin of tilt switch to INPUT mode, and LEDs to OUTPUT mode.
21. if(1 == digitalRead(TiltPin)){
It is used to judge whether the tilt switch is tilted or not. The value of TiltPin is firstly read, if it is equal to 1, the codes inside the if() statement run; otherwise, the codes of if are skipped.
22. delay(10);
23. if(1 == digitalRead(TiltPin)){
24. digitalWrite(Rpin, HIGH);
25. digitalWrite(Gpin, LOW);
26. printf("RED\n");
27. }
28. }
When the tilt is tilted, the tilt switch is on; the Raspberry Pi reads a high level at the tilt pin, so the red LED is on and green LED off.
29. else if(0 == digitalRead(TiltPin)){
30. delay(10);
31. if(0 == digitalRead(TiltPin)){
32. while(!digitalRead(TiltPin));
33. digitalWrite(Rpin, LOW);
34. digitalWrite(Gpin, HIGH);
35. printf("GREEN\n");
36. }
37. }
When the tilt is level, the tilt switch is off; the Raspberry Pi reads a low level at the tilt pin, so the red LED is off and green LED on.
For Python Language Users
Command
cd /home/pi/electronic-kit/for-raspberry-pi/python
2. Run the code.
sudo python3 6_Tilt.py
code
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like electronic-kit/for-raspberry-pi/python. After modifying the code, you can run it directly to see the effect.
import RPi.GPIO as GPIO
TiltPin = 17
Gpin = 27
Rpin = 22
def setup():
GPIO.setmode(GPIO.BCM)
GPIO.setup(Gpin, GPIO.OUT,initial=GPIO.HIGH)
GPIO.setup(Rpin, GPIO.OUT,initial=GPIO.LOW)
GPIO.setup(TiltPin, GPIO.IN)
GPIO.add_event_detect(TiltPin, GPIO.BOTH, callback=detect, bouncetime=200)
def Led(x):
if x == 0:
GPIO.output(Rpin, 1)
GPIO.output(Gpin, 0)
if x == 1:
GPIO.output(Rpin, 0)
GPIO.output(Gpin, 1)
def Print(x):
if x == 0:
print (' *************')
print (' * Tilt! *')
def detect(chn):
Led(GPIO.input(TiltPin))
Print(GPIO.input(TiltPin))
def loop():
def destroy():
GPIO.output(Gpin, GPIO.LOW) # Green LED off
GPIO.output(Rpin, GPIO.LOW) # Red LED off
GPIO.cleanup() # Release resource
setup()
loop()
# When 'Ctrl+C' is pressed, the child program destroy() will be executed.
destroy()
Code Explanation
12. GPIO.add_event_detect(TiltPin, GPIO.BOTH, callback=detect, bouncetime=200)
Set up a falling detect on TiltPin, and callback function to detect. Here bouncetime is to add rise threshold detection on the channel and ignore edge operations less than 200ms caused by switch jitter.
13.def Led(x):
14. if x == 0:
15. GPIO.output(Rpin, 1)
16. GPIO.output(Gpin, 0)
17. if x == 1:
18. GPIO.output(Rpin, 0)
19. GPIO.output(Gpin, 1)
Define a Led() function to set the mode of the two LEDs. When x = 0, the red LED goes on and the green light goes off; when x = 1, the red LED goes off, the green LED goes on. When the function is called, the mode of the LED can be set directly with the statement Led(1) or Led(0).
28.def detect(chn):
29. Led(GPIO.input(TiltPin))
30. Print(GPIO.input(TiltPin))
This is a callback function that executes when a trigger is detected. Assign the current TiltPin state (0 or 1) to the Led function, that is, pass parameters to the Led function. The Led function then performs the corresponding operation on the LEDs.
Phenomenon Picture
