Lesson 20 Traffic Lightο
Introductionο
In last lesson, we learned how to use a 74HC595 chip to drive a 7-Segment Display. Based on that, we can apply it more widely now, such as making a simple traffic light. Now letβs get started!
Newly Added Componentsο
Schematic Diagramο
Build the Circuitο
For C Language Usersο
Commandο
1. Go to the folder of the code.
cd /home/pi/electronic-kit/for-raspberry-pi/c/Lesson_20_TrafficLight
2. Compile the code.
gcc 20_TrafficLight.c -lwiringPi
3. Run the executable file.
You can see the following phenomenon of traffic lights. The red LED lights up for 9 seconds, green LED for 5s, and yellow LED for 3s.
If it does not work after running, or there is an error prompt: "wiringPi.h: No such file or directory", please refer to C code is not working?.
Codeο
#include <wiringPi.h>
#include <stdio.h>
#include <wiringShift.h>
#include <signal.h>
#include <unistd.h>
#define SDI 0 //serial data input(DS)
#define RCLK 1 //memory clock input(STCP)
#define SRCLK 2 //shift register clock input(SHCP)
const int ledPin[]={3,4,5}; //Define 3 LED pin(Red, Green, Yellow)
unsigned char SegCode[17] = {0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71,0x80};
int greentime = 5;
int yellowtime = 3;
int redtime = 9;
int colorState = 0;
char *lightColor[]={"Red","Green","Yellow"};
int counter = 9;
void init(void){
pinMode(SDI, OUTPUT);
pinMode(RCLK, OUTPUT);
pinMode(SRCLK, OUTPUT);
digitalWrite(SDI, 0);
digitalWrite(RCLK, 0);
digitalWrite(SRCLK, 0);
for(int i=0;i<3;i++){
pinMode(ledPin[i],OUTPUT);
digitalWrite(ledPin[i],LOW);
void hc595_shift(unsigned char dat){
int i;
for(i=0;i<8;i++){
digitalWrite(SDI, 0x80 & (dat << i));
digitalWrite(SRCLK, 1);
delay(1);
digitalWrite(RCLK, 1);
delay(1);
void timer(int sig){ //Timer function
if(sig == SIGALRM){
counter --;
alarm(1);
if(counter == 0){
if(colorState == 0) counter = greentime;
if(colorState == 1) counter = yellowtime;
if(colorState == 2) counter = redtime;
colorState = (colorState+1)%3;
printf("counter : %d \t light color: %s \n",counter,lightColor[colorState]);
void display(int num)
hc595_shift(SegCode[num%10]);
delay(1);
void lightup(int state)
digitalWrite(ledPin[state],HIGH);
int main(void)
int i;
init();
signal(SIGALRM,timer); //configure the timer
alarm(1); //set the time of timer to 1s
display(counter);
lightup(colorState);
Code Explanationο
12.int greentime = 5;
13.int yellowtime = 3;
14.int redtime = 9;
Define the duration of lighting of three LEDs. Since what we use is a 7-Segment Display here, we shorten the length of seconds of lighting of traffic lights, setting the green LED to light up for 5 seconds, the yellow LED to 3 seconds, and the red LED to 9 seconds.
15.int colorState = 0;
16.int counter = 9;
The variable colorState corresponds to the state of the traffic lights, and we only need to do a simple calculation of colorState to indicate the order change of the state of the traffic lights. The Variable counter is used to count down the time to each traffic light status and will be output on a 7-Segment Display.
19.void init(void){
20. pinMode(SDI, OUTPUT);
21. pinMode(RCLK, OUTPUT);
22. pinMode(SRCLK, OUTPUT);
23.
24. digitalWrite(SDI, 0);
25. digitalWrite(RCLK, 0);
26. digitalWrite(SRCLK, 0);
27.
28. for(int i=0;i<3;i++){
29. pinMode(ledPin[i],OUTPUT);
30. digitalWrite(ledPin[i],LOW);
31. }
32.}
Initialize pins. Set all control pins of 74HC595 to output mode and initialize them to low level. At the same time, the LEDs are set to output mode, default low level.
47.void timer(int sig){
48. if(sig == SIGALRM){
49. counter --;
50. alarm(1);
51. if(counter == 0){
52. if(colorState == 0) counter = greentime;
53. if(colorState == 1) counter = yellowtime;
54. if(colorState == 2) counter = redtime;
55. colorState = (colorState+1)%3;
56. }
57. printf("counter : %d \t light color: %s \n",counter,lightColor[colorState]);
58. }
59.}
On this timer, counter decreases gradually with every second passing, and when it goes to 0, the state of the traffic light changes accordingly.
67.void lightup(int state)
68.{
69. for(int i=0;i<3;i++){
70. digitalWrite(ledPin[i],LOW);
71. }
72. digitalWrite(ledPin[state],HIGH);
73.}
The function is to turn off all the lights first, and then light up the corresponding LED according to the value of the traffic light state.
For Python Language Usersο
Commandο
cd /home/pi/electronic-kit/for-raspberry-pi/python
2. Run the code.
sudo python3 20_TrafficLight.py
Codeο
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like electronic-kit/for-raspberry-pi/python. After modifying the code, you can run it directly to see the effect.
import RPi.GPIO as GPIO
import threading
#define the pins connect to 74HC595
SDI = 17 #serial data input(DS)
RCLK = 18 #memory clock input(STCP)
SRCLK = 27 #shift register clock input(SHCP)
number = (0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71,0x80)
ledPin =(22,23,24)
greenLight = 5
yellowLight = 3
redLight = 9
lightColor=("Red","Green","Yellow")
colorState=0
counter = 9
t = 0
def setup():
GPIO.setmode(GPIO.BCM)
GPIO.setup(SDI, GPIO.OUT)
GPIO.setup(RCLK, GPIO.OUT)
GPIO.setup(SRCLK, GPIO.OUT)
for pin in ledPin:
GPIO.setup(pin,GPIO.OUT)
def hc595_shift(dat):
for bit in range(0, 8):
GPIO.output(SDI, 0x80 & (dat << bit))
GPIO.output(SRCLK, GPIO.HIGH)
GPIO.output(SRCLK, GPIO.LOW)
GPIO.output(RCLK, GPIO.HIGH)
GPIO.output(RCLK, GPIO.LOW)
def display(num):
hc595_shift(0xff)
hc595_shift(number[num%10])
time.sleep(0.003)
def timer(): #timer function
global counter
global colorState
global t
t = threading.Timer(1.0,timer)
t.start()
counter-=1
if (counter is 0):
if(colorState is 0):
counter= greenLight
if(colorState is 1):
counter=yellowLight
if (colorState is 2):
counter=redLight
colorState=(colorState+1)%3
print ("counter : %d color: %s "%(counter,lightColor[colorState]))
def lightup(state):
for i in range(0,3):
GPIO.output(ledPin[i], GPIO.LOW)
GPIO.output(ledPin[state], GPIO.HIGH)
def loop():
global t
global counter
global colorState
t.start()
display(counter)
lightup(colorState)
def destroy(): # When "Ctrl+C" is pressed, the function is executed.
global t
GPIO.cleanup()
t.cancel() #cancel the timer
if __name__ == '__main__': # Program starting from here
setup()
loop()
destroy()
Code Explanationο
13.greenLight = 5
14.yellowLight = 3
15.redLight = 9
Define the duration of lighting of three LEDs. Since what we use is a 7-Segment Display here, we shorten the length of seconds of lighting of traffic LEDs, setting the green LED to light up for 5 seconds, the yellow LED to 3 seconds, and the red LED to 9 seconds.
18.colorState=0
19.counter = 9
The variable colorState corresponds to the state of the traffic LEDs, and we only need to do a simple calculation of colorState to indicate the order change of the state of the traffic LEDs.
counter is used to count down the time to each traffic LED status and will be output on a 7-Segment Display.
45.def timer(): #timer function
46. global counter
47. global colorState
48. global t
49. t = threading.Timer(1.0,timer)
50. t.start()
51. counter-=1
52. if (counter is 0):
53. if(colorState is 0):
54. counter= greenLight
55. if(colorState is 1):
56. counter=yellowLight
57. if (colorState is 2):
58. counter=redLight
59. colorState=(colorState+1)%3
60. print ("counter : %d color: %s "%(counter,lightColor[colorState]))
On this timer, counter decreases gradually with every second passing, and when it goes to 0, the state of the traffic LED changes accordingly.
62.def lightup(state):
63. for i in range(0,3):
64. GPIO.output(ledPin[i], GPIO.LOW)
65. GPIO.output(ledPin[state], GPIO.HIGH)
The function is to turn off all the LEDs first, and then light up the corresponding LED according to the value of the traffic LED state.
Phenomenon Pictureο
