.. note:: Hello, welcome to the SunFounder Raspberry Pi & Arduino & ESP32 Enthusiasts Community on Facebook! Dive deeper into Raspberry Pi, Arduino, and ESP32 with fellow enthusiasts. **Why Join?** - **Expert Support**: Solve post-sale issues and technical challenges with help from our community and team. - **Learn & Share**: Exchange tips and tutorials to enhance your skills. - **Exclusive Previews**: Get early access to new product announcements and sneak peeks. - **Special Discounts**: Enjoy exclusive discounts on our newest products. - **Festive Promotions and Giveaways**: Take part in giveaways and holiday promotions. 👉 Ready to explore and create with us? Click [|link_sf_facebook|] and join today! Lesson 2 Flowing LED Lights ================================= **Introduction** ------------------ In this lesson, we will learn how to make eight LEDs blink as flowing water based on Raspberry Pi. **Newly Added Components** ----------------------------- .. image:: media_pi/image200.png :width: 800 :align: center **Schematic Diagram** ------------------------- In this experiment, connect **220Ω**\ resistors to the anode (the longer pin of the LED) respectively, then the resistors to Pin **11, 12, 13, 15, 16, 18, 22** and **24** of Raspberry Pi, and connect the cathode (the short pin) of the LEDs to **GND**. We can see from the schematic diagram that the anode of LED connect to a current-limiting resistor and then to Raspberry Pi. Therefore, to turn on an LED, we need to make pins high level. This process can be realized by programming. .. image:: media_pi/image201.png :width: 800 :align: center **Build the Circuit** ----------------------- .. image:: media_pi/image202.png :width: 800 :align: center **For C Language Users:** -------------------------- **Command** ^^^^^^^^^^^^^ **1.** Go to the folder of the code. .. raw:: html .. code-block:: cd /home/pi/electronic-kit/for-raspberry-pi/c/Lesson_2_FlowingLedLights **2.** Compile the code. .. raw:: html .. code-block:: gcc 2_FlowingLedLights.c -lwiringPi .. note:: When using the gcc command, if you do not use -o, it will automatically output as a.out. **3.** Run the executable file. .. raw:: html .. code-block:: sudo ./a.out Now, you will see these 8 LEDs are lit one by one from left to right, and then one by one from right to left. .. note:: If it does not work after running, or there is an error prompt: \"wiringPi.h: No such file or directory\", please refer to :ref:`C code is not working?`. **Code** ^^^^^^^^^^^^ .. code-block:: C #include #include const int LedPin[]={0,1,2,3,4,5,6,10}; //Define 8 LED pin int main(void) { // When initialize wiring failed, print message to screen if(wiringPiSetup() == -1){ printf("setup wiringPi failed !"); return 1; } for(int j=0;j<8;j++) { pinMode(LedPin[j], OUTPUT);// Set LedPin as output to write value to it. digitalWrite(LedPin[j], LOW); } while(1){ for(int i=0;i<8;i++) { // LED on digitalWrite(LedPin[i], HIGH); delay(100); } for(int i=7;i>-1;i--) { // LED off digitalWrite(LedPin[i], LOW); delay(100); } } return 0; } **Code Explanation** ^^^^^^^^^^^^^^^^^^^^^^^^^^^^ .. code-block:: C 4.const int LedPin[]={0,1,2,3,4,5,6,10}; Create an array, **LedPin** to define the eight LEDs then connect them to **GPIO0** ~ **GPIO6**, **GPIO10** respectively. .. code-block:: C 14. for(int j=0;j<8;j++) 15. { 16. pinMode(LedPin[j], OUTPUT); 17. digitalWrite(LedPin[j], LOW); 18. } Use a **for** loop to set all 8 pins connected to LEDs to **OUTPUT** mode and **LOW** level. .. code-block:: c 21. for(int i=0;i<8;i++) 22. { 23. // LED on 24. digitalWrite(LedPin[i], HIGH); 25. delay(100); 26. } Light up the LEDs in GPIO0~6 and GPIO10 successively. i increases progressively from **0** to **7**, LED0 to LED7 changes accordingly, making it like a flowing LED light from left to right. .. code-block:: c 27. for(int i=7;i>-1;i--) 28. { 29. // LED off 30. digitalWrite(LedPin[i], LOW); 31. delay(100); 32. } Close the LEDs in GPIO0~6 and GPIO10 successively. i increases progressively from **7** to **0**, LED0 to LED7 changes accordingly, making it like a flowing LED light from right to left. **For Python Language Users** --------------------------------- **Command** ^^^^^^^^^^^^^ **1.** Go to the folder of the code .. raw:: html .. code-block:: cd /home/pi/electronic-kit/for-raspberry-pi/python **2.** Run the code. .. raw:: html .. code-block:: sudo python3 2_FlowingLed.py Now, you will see these 8 LEDs are lit one by one from left to right, and then one by one from right to left. **Code** ^^^^^^^^^^ .. note:: You can **Modify/Reset/Copy/Run/Stop** the code below. But before that, you need to go to source code path like ``electronic-kit/for-raspberry-pi/python``. After modifying the code, you can run it directly to see the effect. .. raw:: html .. code-block:: python import RPi.GPIO as GPIO import time pins = [17,18,27,22,23,24,25,8] # Define a setup function for some setup def setup(): GPIO.setmode(GPIO.BCM) for i in range(0, 8, 1): GPIO.setup(pins[i], GPIO.OUT, initial=GPIO.LOW) # Define a main function for main process def main(): while True: # print ('...LED ON') # Turn on LED for i in range(0, 8, 1): GPIO.output(pins[i], GPIO.HIGH) time.sleep(0.1) # print ('LED OFF...') # Turn off LED for i in range(7, -1, -1): GPIO.output(pins[i], GPIO.LOW) time.sleep(0.1) # Define a destroy function for clean up everything after the script finished def destroy(): # Turn off LED for i in range(0, 8, 1): GPIO.output(pins[i], GPIO.LOW) # Release resource GPIO.cleanup() # If run this script directly, do: if __name__ == '__main__': setup() try: main() # When 'Ctrl+C' is pressed, the child program # destroy() will be executed. except KeyboardInterrupt: destroy() **Code Explanation** ^^^^^^^^^^^^^^^^^^^^^^ .. code-block:: 9. for i in range(0, 8, 1): 10. GPIO.setup(pins[i], GPIO.OUT, initial=GPIO.LOW) Use a **for** loop to set all 8 pins connected to LEDs to output mode and LOW level. .. code-block:: 17. for i in range(0, 8, 1): 18. GPIO.output(pins[i], GPIO.HIGH) 19. time.sleep(0.1) Variable **i** increases progressively from **0** to **8**, increasing by 1 every time. Accordingly, set the pins in the array **pins[i]** to **HIGH** respectively to light up the LEDs and the lighting time is **0.1**\ s. Then, you will see 8 LEDs light up one by one. .. code-block:: 23. for i in range(7, -1, -1): 24. GPIO.output(pins[i], GPIO.LOW) 25. time.sleep(0.1) Variable **i** decreases progressively from **7** to **-1**, decreasing by 1 every time. Then LED0~LED7 change accordingly, making it like a flowing LED light from right to left. **Phenomenon Picture** ----------------------------- .. image:: media_pi/image203.png :width: 800 :align: center
