Lesson 16 Servoο
Introductionο
Servo is a type of geared motor that can only rotate 180 degrees. It is controlled by sending electrical pulses from your board. These pulses tell the servo what position it should move to.
A servo has three wires: the brown wire is GND, the red one is VCC, and the orange one is signal line.
Newly Added Componentsο
Principleο
Servo
A servo is generally composed of the following parts: case, shaft, gear system, potentiometer, DC motor, and embedded board.
It works like this: The microcontroller sends out PWM signals to the servo, and then the embedded board in the servo receives the signals through the signal pin and controls the motor inside to turn. As a result, the motor drives the gear system and then motivates the shaft after deceleration. The shaft and potentiometer of the servo are connected together. When the shaft rotates, it drives the potentiometer, so the potentiometer outputs a voltage signal to the embedded board. Then the board determines the direction and speed of rotation based on the current position, so it can stop exactly at the right position as defined and hold there.
The angle is determined by the duration of a pulse that is applied to the control wire. This is called Pulse width Modulation. The servo expects to see a pulse every 20 ms. The length of the pulse will determine how far the motor turns. For example, a 1.5ms pulse will make the motor turn to the 90 degree position (neutral position).
When a pulse is sent to a servo that is less than 1.5 ms, the servo rotates to a position and holds its output shaft some number of degrees counterclockwise from the neutral point. When the pulse is wider than 1.5 ms the opposite occurs. The minimal width and the maximum width of pulse that will command the servo to turn to a valid position are functions of each servo. Generally the minimum pulse will be about 0.5 ms wide and the maximum pulse will be 2.5 ms wide.
Schematic Diagramο
Build the Circuitο
Note: Connect the brown to GND, Red to VCC, Orange to pin12 of the control board.
For C Language Usersο
Commandο
1. Go to the folder of the code.
cd /home/pi/electronic-kit/for-raspberry-pi/c/Lesson_16_Servo
2. Compile the code.
gcc 16_Servo.c -lwiringPi
3. Run the executable file.
After the program is executed, the servo will rotate from 0 degrees to 180 degrees, and then from 180 degrees to 0 degrees, circularly.
If it does not work after running, or there is an error prompt: "wiringPi.h: No such file or directory", please refer to C code is not working?.
Codeο
#include <wiringPi.h>
#include <softPwm.h>
#include <stdio.h>
#define ServoPin 1
long Map(long value,long fromLow,long fromHigh,long toLow,long toHigh){
return (toHigh-toLow)*(value-fromLow) / (fromHigh-fromLow) + toLow;
void setAngle(int pin, int angle){ //Specif a certain rotation angle (0-180) for the servo
if(angle < 0)
angle = 0;
if(angle > 180)
angle = 180;
softPwmWrite(pin,map(angle,0,180,5,25));
int main(void)
int i;
if(wiringPiSetup() == -1){ //when initialize wiring faiservo,print message to screen
softPwmCreate(servoPin, 0, 200); //initialize PMW pin of servo
for(i=0;i<181;i++){
setAngle(ServoPin,i);
delay(1);
delay(500);
for(i=181;i>-1;i--){
delay(1);
delay(500);
Code Explanationο
6.long Map(long value,long fromLow,long fromHigh,long toLow,long toHigh){
7. return (toHigh-toLow)*(value-fromLow) / (fromHigh-fromLow) + toLow;
8.}
Create a map() function to map value in the following code.
9.void setAngle(int pin, int angle){ //Specif a certain rotation angle (0-180) for the servo
10. if(angle < 0)
11. angle = 0;
12. if(angle > 180)
13. angle = 180;
14. softPwmWrite(pin,map(angle,0,180,5,25));
15.}
Define a function to limit the angle of the servo to 0 to 180 in order to set the angle of servo.
This function can change the duty cycle of the PWM pin.
To make the servo rotate to 0 ~ 180 Β°, the pulse width should change within the range of 0.5ms ~ 2.5ms when the period is 20ms; in the function, softPwmCreate(), we have set that the period is 200x100us=20ms, thus we need to map 0 ~ 180 to 5x100us ~ 25x100us.
25. softPwmCreate(ServoPin, 0, 200);
The function is to use softwares to create a PWM pin, servoPin, then the initial pulse widths of them are set to 0, and the period of PWM is 200 x100us.
27. for(i=0;i<181;i++){
28. setAngle(ServoPin,i);
29. delay(1);
30. }
In a for loop, we want servo to rotate from 0 degrees to 180 degrees.
32. for(i=181;i>-1;i--){
33. setAngle(ServoPin,i);
34. delay(1);
35. }
In a for loop, we want servo to rotate from 180 degrees to 0 degrees.
For Python Language Usersο
Commandο
cd /home/pi/electronic-kit/for-raspberry-pi/python
2. Run the code.
sudo python3 16_Servo.py
Codeο
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like electronic-kit/for-raspberry-pi/python. After modifying the code, you can run it directly to see the effect.
import RPi.GPIO as GPIO
SERVO_MIN_PULSE = 500
SERVO_MAX_PULSE = 2500
ServoPin = 18
def map(value, inMin, inMax, outMin, outMax):
return (outMax - outMin) * (value - inMin) / (inMax - inMin) + outMin
def setup():
global p
GPIO.setmode(GPIO.BCM) # Numbers GPIOs by BCM
GPIO.setup(ServoPin, GPIO.OUT) # Set ServoPin's mode is output
GPIO.output(ServoPin, GPIO.LOW) # Set ServoPin to low
p = GPIO.PWM(ServoPin, 50) # set Frequecy to 50Hz
p.start(0) # Duty Cycle = 0
def setAngle(angle): # make the servo rotate to specific angle (0-180 degrees)
angle = max(0, min(180, angle))
pulse_width = map(angle, 0, 180, SERVO_MIN_PULSE, SERVO_MAX_PULSE)
pwm = map(pulse_width, 0, 20000, 0, 100)
p.ChangeDutyCycle(pwm)#map the angle to duty cycle and output it
def loop():
for i in range(0, 181, 5): #make servo rotate from 0 to 180 deg
setAngle(i) # Write to servo
time.sleep(0.002)
time.sleep(1)
for i in range(180, -1, -5): #make servo rotate from 180 to 0 deg
setAngle(i)
time.sleep(0.001)
time.sleep(1)
def destroy():
p.stop()
GPIO.cleanup()
if __name__ == '__main__': #Program start from here
setup()
loop()
destroy()
Code Explanationο
9.def map(value, inMin, inMax, outMin, outMax):
10. return (outMax - outMin) * (value - inMin) / (inMax - inMin) + outMin
17. p = GPIO.PWM(ServoPin, 50)
18. p.start(0)
Set the servoPin to PWM pin, then the frequency to 50 hz, and the period to 20ms. p.start(0): Run the PWM functionοΌand set the initial value to 0.
20.def setAngle(angle): # make the servo rotate to specific angle (0-180 degrees)
21. angle = max(0, min(180, angle))
22. pulse_width = map(angle, 0, 180, SERVO_MIN_PULSE, SERVO_MAX_PULSE)
23. pwm = map(pulse_width, 0, 20000, 0, 100)
24. p.ChangeDutyCycle(pwm)#map the angle to duty cycle and output it
Create a function, setAngle() to write angle that ranges from 0 to 180 into the servo.
24.p.ChangeDutyCycle(pwm)
This function can change the duty cycle of the PWM. To render a range 0 ~ 180Β° to the servo, the pulse width of the servo is set to 0.5ms-2.5ms.
In the previous codes, the period of PWM was set to 20ms, thus the duty cycle of PWM is (0.5/20)%-(2.5/20)%, and the range 0 ~ 180 is mapped to 2.5 ~ 12.5.
28. for i in range(0, 181, 5): #make servo rotate from 0 to 180 deg
29. setAngle(i) # Write to servo
30. time.sleep(0.002)
32. for i in range(180, -1, -5): #make servo rotate from 180 to 0 deg
33. setAngle(i)
34. time.sleep(0.001)
Phenomenon Pictureο
