.. note::
**Why Join?**
- **Expert Support**: Solve post-sale issues and technical challenges with help from our community and team.
- **Learn & Share**: Exchange tips and tutorials to enhance your skills.
- **Exclusive Previews**: Get early access to new product announcements and sneak peeks.
- **Special Discounts**: Enjoy exclusive discounts on our newest products.
- **Festive Promotions and Giveaways**: Take part in giveaways and holiday promotions.
👉 Ready to explore and create with us? Click [|link_sf_facebook|] and join today!
3.1.5 Battery Indicator
.. note::
.. image:: img/mcp3008_and_adc0834.jpg
:width: 25%
:align: left
Depending on your kit version, please identify whether you have **ADC0834** or **MCP3008** and proceed with the matching section.
In this course, we will make a battery indicator device that can
visually display the battery level on the LED Bargraph.
Components
.. image:: img/list_Battery_Indicator.png
:align: center
Schematic Diagram
GPIO17 Pin 11 0 17
GPIO18 Pin 12 1 18
GPIO27 Pin 13 2 27
GPIO25 Pin 22 6 25
GPIO12 Pin 32 26 12
GPIO16 Pin 36 27 16
GPIO20 Pin 38 28 20
GPIO21 Pin 40 29 21
GPIO5 Pin 29 21 5
GPIO6 Pin 31 22 6
GPIO13 Pin 33 23 13
GPIO19 Pin 35 24 19
GPIO26 Pin 37 25 26
.. image:: img/Schematic_three_one5.png
:align: center
Experimental Procedures
**Step 1:** Build the circuit.
.. image:: img/image248.png
:width: 800
:align: center
**For C Language Users**
**Step 2:** Go to the folder of the code.
.. raw:: html
.. code-block::
cd ~/davinci-kit-for-raspberry-pi/c/3.1.5/
**Step 3:** Compile the code.
.. raw:: html
.. code-block::
gcc 3.1.5_BatteryIndicator.c -lwiringPi
**Step 4:** Run the executable file.
.. raw:: html
.. code-block::
After the program runs, give the 3rd pin of ADC0834 and the GND a
lead-out wire separately and then lead them to the two poles of a
battery separately. You can see the corresponding LED on the LED
Bargraph is lit up to display the power level (measuring range: 0-5V).
.. note::
If it does not work after running, or there is an error prompt: \"wiringPi.h: No such file or directory\", please refer to :ref:`install_wiringpi`.
**Code Explanation**
.. code-block:: c
void LedBarGraph(int value){
for(int i=0;i<10;i++){
digitalWrite(pins[i],HIGH);
for(int i=0;i
.. code-block::
**Step 3:** Run the executable file.
.. raw:: html
.. code-block::
sudo python3 3.1.5_BatteryIndicator.py
**Code**
.. note::
You can **Modify/Reset/Copy/Run/Stop** the code below. But before that, you need to go to source code path like ``davinci-kit-for-raspberry-pi/python``.
.. raw:: html
.. code-block:: python
import RPi.GPIO as GPIO
import ADC0834
ledPins = [25, 12, 16, 20, 21, 5, 6, 13, 19, 26]
def setup():
GPIO.setmode(GPIO.BCM)
ADC0834.setup()
for i in ledPins:
GPIO.setup(i, GPIO.OUT)
GPIO.output(i, GPIO.HIGH)
def LedBarGraph(value):
for i in ledPins:
GPIO.output(i,GPIO.HIGH)
for i in range(value):
GPIO.output(ledPins[i],GPIO.LOW)
def destroy():
GPIO.cleanup()
def loop():
LedBarGraph(int(analogVal/25))
if __name__ == '__main__':
setup()
loop()
destroy()
for i in ledPins:
This function works for controlling the turning on or off of the **10**
LEDs on the LED Bargraph. We give these **10** LEDs high levels to let
they are **off** at first, then decide how many LEDs are lit up by
changing the received analog value.
def loop():
analogVal produces values (**0-255**) with varying voltage values
(**0-5V**), ex., if a 3V is detected on a battery, the corresponding
value **152** is displayed on the voltmeter.
The **10** LEDs on the LED Bargraph are used to display the
**analogVal** readings. 255/10=25, so every **25** the analog value
increases, one more LED turns on, ex., if “analogVal=150 (about 3V),
there are 6 LEDs turning on.”
Phenomenon Picture
.. image:: img/image249.jpeg
:align: center
