š Ready to explore and create with us? Click [here] and join today!
1.1.5 4-Digit 7-Segment Displayļ
Introductionļ
Next, follow me to try to control the 4-digit 7-segment display.
Componentsļ
Principleļ
4-Digit 7-segment display consists of four 7- segment displays working together.
The 4-digtal 7-segment display works independently. It uses the principle of human visual persistence to quickly display the characters of each 7-segment in a loop to form continuous strings.
For example, when ā1234ā is displayed on the display, ā1ā is displayed on the first 7-segment, and ā234ā is not displayed. After a period of time, the second 7-segment shows ā2ā, the 1st 3th 4th of 7-segment does not show, and so on, the four digital display show in turn. This process is very short (typically 5ms), and because of the optical afterglow effect and the principle of visual residue, we can see four characters at the same time.
Display Codes
To help you get to know how 7-segment displays(Common Anode) display Numbers, we have drawn the following table. Numbers are the number 0-F displayed on the 7-segment display; (DP) GFEDCBA refers to the corresponding LED set to 0 or 1, For example, 11000000 means that DP and G are set to 1, while others are set to 0. Therefore, the number 0 is displayed on the 7-segment display, while HEX Code corresponds to hexadecimal number.
Schematic Diagramļ
T-Board Name |
physical |
wiringPi |
BCM |
GPIO17 |
Pin 11 |
0 |
17 |
GPIO27 |
Pin 13 |
27 |
GPIO22 |
Pin 15 |
22 |
SPIMOSI |
Pin 19 |
12 |
10 |
GPIO18 |
Pin 12 |
18 |
GPIO23 |
Pin 16 |
23 |
GPIO24 |
Pin 18 |
24 |
Experimental Proceduresļ
Step 1: Build the circuit.
For C Language Usersļ
cd ~/davinci-kit-for-raspberry-pi/c/1.1.5/
Step 3: Compile the code.
gcc 1.1.5_4-Digit.c -lwiringPi
After the code runs, the program takes a count, increasing by 1 per second, and the 4-digit 7-segment display displays the count.
#include <wiringPi.h>
#include <stdio.h>
#include <wiringShift.h>
#include <signal.h>
#include <unistd.h>
#define SDI 5
#define RCLK 4
#define SRCLK 1
const int placePin[] = {12, 3, 2, 0};
unsigned char number[] = {0xc0, 0xf9, 0xa4, 0xb0, 0x99, 0x92, 0x82, 0xf8, 0x80, 0x90};
int counter = 0;
void pickDigit(int digit)
for (int i = 0; i < 4; i++)
digitalWrite(placePin[i], 0);
digitalWrite(placePin[digit], 1);
void hc595_shift(int8_t data)
int i;
for (i = 0; i < 8; i++)
digitalWrite(SDI, 0x80 & (data << i));
digitalWrite(SRCLK, 1);
delayMicroseconds(1);
digitalWrite(SRCLK, 0);
digitalWrite(RCLK, 1);
digitalWrite(RCLK, 0);
void clearDisplay()
int i;
digitalWrite(SDI, 1);
void loop()
clearDisplay();
pickDigit(0);
hc595_shift(number[counter % 10]);
clearDisplay();
pickDigit(1);
hc595_shift(number[counter % 100 / 10]);
clearDisplay();
pickDigit(2);
hc595_shift(number[counter % 1000 / 100]);
clearDisplay();
pickDigit(3);
hc595_shift(number[counter % 10000 / 1000]);
void timer(int timer1)
if (timer1 == SIGALRM)
counter++;
alarm(1);
printf("%d\n", counter);
void main(void)
if (wiringPiSetup() == -1)
return;
pinMode(SDI, OUTPUT);
pinMode(RCLK, OUTPUT);
pinMode(SRCLK, OUTPUT);
pinMode(placePin[i], OUTPUT);
digitalWrite(placePin[i], HIGH);
signal(SIGALRM, timer);
alarm(1);
loop();
Code Explanation
These four pins control the common anode pins of the four-digit 7-segment displays.
A segment code array from 0 to 9 in Hexadecimal (Common anode).
Select the place of the value. there is only one place that should be enable each time. The enabled place will be written high.
void loop()
clearDisplay();
pickDigit(0);
clearDisplay();
pickDigit(1);
clearDisplay();
pickDigit(2);
clearDisplay();
pickDigit(3);
The functionis used to set the number displayed on the 4-digit 7-segment display.
clearDisplay()ļ¼write in 11111111 to turn off these eight LEDs on 7-segment display so as to clear the displayed content.pickDigit(0)ļ¼pick the fourth 7-segment display.hc595_shift(number[counter%10])ļ¼the number in the single digit of counter will display on the forth segment.
This is a system-provided function, the prototype of code is:
sig_t signal(int signum,sig_t handler);
After executing the signal(), once the process receives the corresponding signum (in this case SIGALRM), it immediately pauses the existing task and processes the set function (in this case timer(sig)).
alarm(1);
This is also a system-provided function. The code prototype is:
unsigned int alarm (unsigned int seconds);
It generates a SIGALRM signal after a certain number of seconds.
counter++;
alarm(1);
We use the functions above to implement the timer function.
After the alarm() generates the SIGALRM signal, the timer function is called. Add 1 to counter, and the function, alarm(1) will be repeatedly called after 1 second.
For Python Language Usersļ
Step 3: Run the executable file.
sudo python3 1.1.5_4-Digit.py
After the code runs, the program takes a count, increasing by 1 per second, and the 4 digit display displays the count.
You can Modify/Reset/Copy/Run/Stop the code below. But before that, you need to go to source code path like davinci-kit-for-raspberry-pi/python.
import RPi.GPIO as GPIO
import threading
SDI = 24
RCLK = 23
SRCLK = 18
placePin = (10, 22, 27, 17)
counter = 0
timer1 = 0
def clearDisplay():
for i in range(8):
GPIO.output(SDI, 1)
GPIO.output(SRCLK, GPIO.HIGH)
GPIO.output(SRCLK, GPIO.LOW)
GPIO.output(RCLK, GPIO.HIGH)
GPIO.output(RCLK, GPIO.LOW)
def hc595_shift(data):
for i in range(8):
GPIO.output(SDI, 0x80 & (data << i))
def pickDigit(digit):
for i in placePin:
GPIO.output(i,GPIO.LOW)
GPIO.output(placePin[digit], GPIO.HIGH)
def timer():
global counter
global timer1
timer1 = threading.Timer(1.0, timer)
timer1.start()
counter += 1
print("%d" % counter)
def loop():
global counter
clearDisplay()
pickDigit(0)
clearDisplay()
pickDigit(1)
hc595_shift(number[counter % 100//10])
clearDisplay()
pickDigit(2)
hc595_shift(number[counter % 1000//100])
clearDisplay()
pickDigit(3)
hc595_shift(number[counter % 10000//1000])
def setup():
GPIO.setmode(GPIO.BCM)
GPIO.setup(SDI, GPIO.OUT)
GPIO.setup(RCLK, GPIO.OUT)
GPIO.setup(SRCLK, GPIO.OUT)
for i in placePin:
GPIO.setup(i, GPIO.OUT)
global timer1
timer1.start()
def destroy(): # When "Ctrl+C" is pressed, the function is executed.
global timer1
GPIO.cleanup()
timer1.cancel() # cancel the timer
if __name__ == '__main__': # Program starting from here
setup()
loop()
destroy()
Code Explanation
A segment code array from 0 to 9 in hexadecimal (common anode).
def clearDisplay():
for i in range(8):
GPIO.output(SDI, 1)
Write ā1ā for eight times in SDI., so that the eight LEDs on the 7-segment Dispaly will turn off so as to clear the displayed content.
for i in placePin:
def loop():
global counter
clearDisplay()
pickDigit(0)
clearDisplay()
pickDigit(1)
clearDisplay()
pickDigit(2)
clearDisplay()
pickDigit(3)
The function is used to set the number displayed on the 4-digit 7-segment Dispaly.
First, start the fourth segment display,Ā write the single-digitĀ number. Then start the third segment display, and type inĀ the tensĀ digit;Ā after that,Ā start the second and the first segment display respectively,Ā and write the hundredsĀ and thousands digits respectively.Ā Because the refreshingĀ speedĀ is veryĀ fast, we see aĀ completeĀ four-digit display.
timer1.start()
The module, threading is the common threading module in Pythonļ¼and Timer is the subclass of it. The prototype of code is:
class threading.Timer(interval, function, args=[], kwargs={})
After the interval, the function will be run. Here, the interval is 1.0ļ¼and the function is timer(). start () means the Timer will start at this point.
def timer():
global counter
global timer1
timer1.start()
counter += 1
After Timer reaches 1.0s, the Timer function is called; add 1 to counter, and the Timer is used again to execute itself repeatedly every second.
Phenomenon Pictureļ
