8. Traffic Light with Pedestrian Button
Welcome to the next phase of our Arduino journey. In the previous lesson, we built a foundational traffic light system, a staple of our roads, controlling the flow with red, yellow, and green lights. Now, we’re adding a layer of interaction that reflects real-world complexities: a pedestrian button. This feature introduces a human element to our electronic crossroads, allowing for a dynamic interplay between the walkways and roadways at our busy intersections.
In this lesson, you will learn to:
  • Understand how button work and their role in circuits.
  • Learn to use digitalRead() to detect pin input levels.
  • Implement if statements to create conditional behaviors in traffic light systems.
As we delve into this project, we’ll explore not just the technical setup but also the logic and programming that make such systems both possible and efficient in managing pedestrian and vehicle traffic.
Building the Circuit
Components Needed
1 * Arduino Uno R3
1 * Red LED
1 * Yellow LED
1 * Green LED
list_uno_r3
list_red_led
list_yellow_led
list_green_led
1 * Push Button
1 * Breadboard
3 * 220Ω Resistor
1 * 10K Ohm Resistor
list_button
list_breadboard
list_220ohm
list_10kohm
1 * USB Cable
Jumper Wires
1 * Multimeter
list_usb_cable
list_wire
list_meter
Building Step-by-Step
Follow the wiring diagram, or the steps below to build your circuit.
../_images/8_traffic_light_button.png
  1. Start with the traffic light circuit from the previous lesson.
../_images/7_traffic_light.png
  1. Find a push button.
../_images/8_traffic_button.png
Buttons are ubiquitous components in electronics, acting as switches to make or break circuits. Below is the internal structure of a button, with its common symbol used in circuit diagrams.
../_images/8_traffic_button_symbol.png
Though buttons have four pins, pins 1 and 2 are connected, as are pins 3 and 4. Pressing the button connects all four pins, closing the circuit.
  1. Insert the button into the breadboard across the middle gap, with pins in holes 18e, 18f, 20e, and 20f.
If you’re unsure how to insert the button, try both orientations. One way, the pin spacing will be slightly too narrow to fit.
../_images/8_traffic_light_button_button.png
  1. Connect the button’s top-right pin to digital pin 8 on the Arduino Uno R3 with a long jumper wire, inserting one end into hole 18j and the other into pin 8.
../_images/8_traffic_light_button_pin8.png
  1. Place a 10K Ohm resistor between the button’s top-left pin and ground, connecting one end to hole 18a and the other to the breadboard’s negative rail. This resistor pulls pin 8 to ground, stabilizing it at LOW when the button is not pressed.
Pin 8 serves as an input to read the button’s state. Arduino boards read voltages between 0 and approximately 5 volts at input pins, interpreting them as either LOW or HIGH based on a threshold voltage. For a pin to read as HIGH, it must have over 3 volts. To read as LOW, it must have less than 1.5 volts.
If without the 10K resistor, pin 8 connects only to the button, floating between 0 and 5V, causing its state to fluctuate randomly between HIGH and LOW.
The 10K resistor connected from pin 8 to ground pulls the pin’s voltage down to ground level, ensuring it reads as LOW when the button is unpressed.
  1. Lastly, power the button by connecting the breadboard’s positive rail to the Arduino Uno R3’s 5V pin with a red power wire.
Question:
Your traffic light is a mix of series and parallel circuits. Discuss which parts of your circuit are in series and why. Then, explain which parts are in parallel and why.
Code Creation
Initializing Pins
So far, you’ve programmed the traffic lights to sequentially flash green, yellow, and red LEDs. In this lesson, you’ll program your pedestrian button so that when pressed, the red and yellow LEDs turn off while the green LED flashes, indicating it’s safe for pedestrians to cross.
  1. Open the sketch you saved earlier, Lesson7_Traffic_Light. Hit “Save As…” from the “File” menu, and rename it to Lesson8_Traffic_Light_Button. Click “Save”.
  2. In the void setup() function, add another pinMode() command to declare pin 8 as input (INPUT). Then, add a code comment to explain your new command.
    // Setup code here, to run once:
    pinMode(3, OUTPUT); // Set pin 3 as output
    pinMode(4, OUTPUT); // Set pin 4 as output
    pinMode(5, OUTPUT); // Set pin 5 as output
    pinMode(8, INPUT);  // Declare pin 8 (button) as input
    // put your main code here, to run repeatedly:
    digitalWrite(3, HIGH);  // Light up the LED on pin 3
    digitalWrite(4, LOW);   // Switch off the LED on pin 4
    digitalWrite(5, LOW);   // Switch off the LED on pin 5
    delay(10000);           // Wait for 10 seconds
    digitalWrite(3, LOW);   // Switch off the LED on pin 3
    digitalWrite(4, HIGH);  // Light up the LED on pin 4
    digitalWrite(5, LOW);   // Switch off LED on pin 5
    delay(3000);            // Wait for 3 seconds
    digitalWrite(5, HIGH);  // Light up LED on pin 5
  1. After coding, verify your sketch and upload the code to the Arduino Uno R3.
Measuring Voltage at Pin 8
We already know how the LEDs section of our circuit works from the previous lesson. Each LED, acting as an output, is controlled by different pins on the Arduino Uno R3.
However, the button connected to pin 8 on the board is different. It’s an input device. Pin 8 will read incoming voltage instead of sending voltage out.
Let’s use a multimeter to test the voltage at pin 8 when the button is pressed and released. You might need a friend to help press the button for this measurement.
  1. Adjust the multimeter to the 20 volts DC setting.
../_images/multimeter_dc_20v.png
  1. When the button is not pressed, measure the voltage at pin 8. Touch the red test lead of the multimeter to pin 8 and the black test lead to GND.
../_images/8_traffic_voltage.png
  1. Record the measured voltage in the table.
Button State
Pin 8 Voltage
State
Release
0.00 volts
Press
  1. Have your friend help you press the button, then continue measuring the voltage at pin 8.
  1. When the button is pressed, record the voltage at pin 8 in the table.
Button State
Pin 8 Voltage
State
Release
0.00 volts
Press
≈4.97 volts
  1. Arduino boards read voltages between 0 and approximately 5 volts at input pins, interpreting them as either LOW or HIGH based on a threshold voltage. For a pin to read as HIGH, it must have over 3 volts. To read as LOW, it must have less than 1.5 volts.
    Based on the measured voltage, fill in the state for pin 8.
Button State
Pin 8 Voltage
Pin 8 State
Release
0.00 volts
LOW
Press
≈4.97 volts
HIGH
Conditional Statements
The traffic light should display two different behaviors depending on whether the button is pressed:
  • When the button is pressed, the code for the pedestrian crossing should run, and the green LED should blink.
  • When the button is not pressed, the traffic light should operate normally as you’ve programmed.
To program these behaviors, you’ll use a new coding function known as conditional statements.
Conditional statements are sometimes called if-then statements, or simply, an if statement. Conditional statements allow you to run certain lines of code when a specific condition or scenario is true.
../_images/if.png
You often use conditional statements in everyday life to make decisions, such as:
start;
if cold;
then wear a coat;
end;
In the Arduino IDE, a conditional statement looks like this:
if (condition) {
    commands to run when the condition is true
The condition is within parentheses, using comparison operators to compare two or more values. These values can be numbers, variables, or inputs coming into the Arduino Uno R3.
Here’s a list of comparison operators and how they’re used in the condition part of an if statement:
Comparison Operator
Meaning
Example
Equals
if (digitalRead(8) == HIGH) {do something}
Not equal
if (digitalRead(5) != LOW) {do something}
Less than
if (distance < 100) {do something}
Greater than
if (count > 5) {do something}
Less than or equal to
if (number <= minValue) {do something}
Greater than or equal to
if (number >= maxValue) {do something}
The equality comparison uses two equals signs(==). A single equals sign (=) is used for assigning a value to a variable (explained in later sections), while double equals are used for comparing two values.
When comparing two values in a condition, the result can be True or False. If the condition is True, then the commands within the curly brackets are executed. If the condition is False, then the commands within the curly brackets are skipped.
In coding, conditional statements can be simple or involve complex logical arguments with multiple conditions and scenarios. You’ll be using the basic form of if statements next.
Button Not Pressed
Building on our understanding of conditional statements, let’s apply this concept to enhance our traffic light sketch. Given that a button’s press alters the flow of traffic, we’ll incorporate a condition to monitor the button’s state.
  1. From our earlier measurements of pin 8’s voltage, we know that when the button is not pressed, pin 8 is LOW. So, if the state of pin 8 read is LOW, it means it’s not pressed. Now, at the beginning of the void loop() function in your previous code, enter the following statement:
        if (digitalRead(8) == LOW) {
Just like the digitalWrite() command is used for output pins, the digitalRead() command is used for input pins. digitalRead(pin) is the command to read if a digital pin is HIGH or LOW.
Here is its syntax:
  • digitalRead(pin): Reads the value from a specified digital pin, either HIGH or LOW.
    Parameters
    • pin: the Arduino pin number you want to read
    Returns
    HIGH or LOW
  1. Next, add the commands to run when the button is not pressed. These commands are the ones you’ve already created for running the normal traffic light.
    • You can cut and paste these commands inside the curly brackets of the if statement,
    • Or, you could simply move the right curly bracket of the if statement to after the last delay.
    • Use whichever method suits you. After doing so, your void loop() function should look something like this:
Notice how the commands within the if statement are indented. Using indentation helps keep your code tidy and clarifies the commands being executed within a function. Although it might take a few extra seconds, using indentation, line breaks, and code comments can maintain the aesthetics of your code, which will be beneficial in the long run.
A common syntax error is forgetting the required number of curly brackets. Sometimes, the right bracket is missed in a function, or too many right brackets are added. In your sketch, every left bracket needs a right bracket. Proper indentation also helps you troubleshoot mismatched brackets.
When the Button Is Pressed
Now it’s time to write the code that allows pedestrians to cross the street when the button is pressed.
This will require a second conditional statement. However, this time you’ll need to compare the digitalRead() value of pin 8 to HIGH instead of LOW.
When the button is pressed, the traffic light needs to stop all vehicles and signal that it’s safe for pedestrians to cross. To achieve this, you’ll turn off the red and yellow LEDs and make the green LED blink. Within the curly brackets of your second conditional statement, add three digitalWrite() commands:
  • Turn on the green LED connected to pin 3.
  • Turn off the yellow LED connected to pin 4.
  • Turn off the red LED connected to pin 5.
Then, make the green LED blink. Remember, the blinking frequency is determined by your delay() statements.
Your sketch should look something like this:
    pinMode(3, OUTPUT);  // declare pin 3 (green LED) as output
    pinMode(4, OUTPUT);  // declare pin 4 (yellow LED) as output
    pinMode(5, OUTPUT);  // declare pin 5 (red LED) as output
    pinMode(8, INPUT);   // declare pin 8 (button) as input
    // Main code to run repeatedly:
    if (digitalRead(8) == HIGH) {  //if the button is pressed:
        delay(500);                  // Wait half a second
Upload your code to the Arduino Uno R3. Once the sketch is fully transferred, the code will execute.
Observe the behavior of your traffic light. Press the button and wait for the traffic light to complete its cycle. Does the pedestrian green light blink? When the button is released, does the traffic light return to its normal operation mode? If not, make adjustments to your sketch and re-upload it to the R3.
Once completed, save your sketch.
Question
During testing, you may notice that the green LED only blinks while the pedestrian button is kept pressed, but pedestrians can’t cross the road while continuously pressing the button. How can you modify the code to ensure that once the pedestrian button is pressed, the green LED lights up long enough for a safe crossing without requiring continuous pressing? Please write down the pseudo-code solution in your handbook.
Summary
In this lesson, we’ve delved into integrating a pedestrian button into a traffic light system, simulating a real-world scenario that balances the flow of both pedestrian and vehicular traffic. We explored the workings of a button in an electronic circuit and utilized the digitalRead() function to monitor input from the button. By implementing conditional statements with if structures, we programmed the traffic lights to respond dynamically to pedestrian input, enhancing our understanding of interactive systems. This lesson not only reinforced our skills in Arduino programming but also highlighted the practical application of these technologies in managing everyday situations efficiently.
