FAQ
What is included in the kit?
The kit includes an Arduino Uno R3 and a variety of sensors, modules, components, and accessories for building experiments and projects.
What is the difference between “Video Tutorials” and “Hands-on Lessons”?
Video Tutorials help you understand concepts and see demonstrations.
Hands-on Lessons guide you through building circuits and writing code using the kit components.
Tip:
Watch the video first, then complete the hands-on lesson for better retention.
Why the Arduino UNO R3 Cannot Be Used
Even when using an official Arduino UNO R3, the board may fail to work properly due to environmental or operational reasons. Below are the most common causes and explanations.
USB driver or operating system issues
The Arduino UNO R3 uses an ATmega16U2 USB interface chip, which is normally recognized automatically on Windows 10 / 11 and macOS.
However, on older systems (such as Windows 7 or lightweight Windows installations), the required USB CDC driver may be missing. In this case, the computer may fail to recognize the Arduino serial device.
Solution:
Manually update or install the Arduino USB driver via Device Manager.
It is recommended to include USB driver update instructions in the FAQ for reference.
Incorrect board or port selected in Arduino IDE
If the correct Board or Port is not selected in the Arduino IDE, uploading sketches will fail.
A common error message is:
stk500_recv(): programmer not responding
This is a configuration issue and does not indicate hardware damage.
Solution:
Select Arduino UNO under Tools → Board
Select the correct serial port under Tools → Port
Using a USB hub or unstable USB port
If the Arduino is connected through:
USB hubs
USB ports on monitors
USB ports integrated into keyboards
The power supply and signal may be unstable, causing the Arduino to fail USB enumeration.
Recommendation:
Connect the Arduino directly to the computer’s USB port.
USB port issues on the computer
Some USB ports may have issues such as:
Insufficient power (common on front-panel USB ports)
Poor physical contact
Damaged USB ports
Recommendation:
Try a different USB port
Preferably use the rear USB ports on the motherboard
Using USB power and external power at the same time
If the Arduino is powered by USB while external power is also supplied via 5V or Vin, it may cause:
Voltage regulator lock-up
Overheating of the power circuit
Unstable USB communication
This may cause the Arduino to appear disconnected or unstable.
Recommendation:
Avoid supplying USB power and external power at the same time unless required and properly designed.
Wiring errors causing USB chip damage
When connecting external modules, incorrect wiring may cause damage to the ATmega16U2 USB chip, including:
Reversing 5V and GND
Applying high voltage (such as 12V) to Arduino pins
Power conflicts between USB and external supplies
In this case, the Arduino may still power on, but the computer will not recognize the serial port.
Note:
This type of failure is caused by incorrect operation and is not a quality issue with the Arduino board itself.
Why the Multimeter Cannot Be Used
Even if the multimeter itself is functioning normally, incorrect usage may cause it to appear as not turning on or unable to measure. Below are the most common causes and solutions.
Battery not installed
Although a 9V battery is included in the kit, it must be installed by the user. If no battery is installed, the multimeter screen will not turn on.
A video tutorial for battery installation is available in Measuring with a Multimeter.
Test leads connected to the wrong jacks
If the red test lead is inserted into the 10A or mA jack, the multimeter will not display readings when measuring voltage or resistance.
For voltage or resistance measurements:
Red lead → VΩ
Black lead → COM
Incorrect measurement range selected
If the selected mode does not match the measurement target, for example:
Measuring DC voltage using AC range
Measuring voltage using resistance mode
The multimeter will not show correct readings.
Solution:
Select the appropriate range: * DCV for DC voltage * Ω for resistance
Multimeter powers on but cannot measure
If the multimeter displays values but cannot measure accurately, the test leads may be damaged.
Repeated pulling or twisting of the leads can cause internal wire breakage and unstable contact.
Solution:
Replace the test leads if unstable or intermittent readings occur
How do I run my first Arduino program?
Connect the Arduino board to your computer using a USB cable.
Open Arduino IDE and select the correct Board and Port.
Open an example sketch (such as Blink) and click Upload.
Confirm the on-board LED behavior to verify it works.
My circuit does not work as expected. What should I do first?
Re-check wiring against the tutorial diagram (most issues are wiring mistakes).
Verify component polarity (LED direction, electrolytic capacitor polarity, etc.).
Confirm power and ground are connected correctly.
Use a multimeter to verify voltage at key points if available.
