2. Your First Circuit
Welcome to the electrifying world of your first circuit, where a simple switch can light up your surroundings, and a single click can bring gadgets to life. This lesson is your gateway to understanding the unseen force of electricity that powers the devices we use every day. Ever curious about how your favorite gadgets operate or what makes lights glow? It’s time to embark on a hands-on exploration of circuit building.
As we begin this adventure, we’ll explore the origins of electricity and trace the pathways of electrons as they flow through circuits. This lesson serves as a practical introduction to the components of a circuit and how they interact to perform various functions. You’ll also play the role of an electrical detective, discovering how to effectively harness and measure this lively force.
Get ready for some electrifying experiments! Here’s what you’ll achieve:
  • Use a breadboard for easy circuit construction.
  • Read resistor color codes to manage electrical flow.
  • Understand how LEDs control the direction of current.
  • Learn about voltage from Arduino Uno R3.
  • Discover how electrons flow through a circuit.
  • Recognize different types of circuits and their functions.
Are you ready to dive into your first circuit-building experience? Let’s get charged up and begin this enlightening journey!
Components Needed
1 * Arduino Uno R3
1 * Red LED
1 * 220Ω Resistor
Jumper Wires
list_uno_r3
list_red_led
list_220ohm
list_wire
1 * USB Cable
1 * Breadboard
list_usb_cable
list_breadboard
  1. Locate your breadboard.
The breadboard you’ll be using is called a solderless breadboard. Each hole on the breadboard contains a metal connector that grips the wire when inserted. This helps to prevent the wire from being pulled out, ensuring a secure connection in your circuit.
../_images/2_breadboard_half.png
Ever wonder why the essential electronic tool in your hand shares a name with the kitchen board used for slicing bread? It’s quite a story! Back in the days before the 1970s, electronics were assembled on literal wooden boards, sometimes repurposed kitchen breadboards, by nailing or gluing components onto them and making connections with wires.
../_images/2_breadboard_circuit.jpg
From the 1960s to the 1980s, engineers experimented with wire wrapping for more complex circuits, which was semi-permanent and required specific tools but was eventually deemed too cumbersome and not suited for repeated use.
../_images/2_breadboard_wire_wrap.jpg
Then, in the early 1970s, Ronald J. Portugal revolutionized prototyping with the invention of the “solderless breadboard,” making circuit assembly faster, easier, and requiring no soldering. This innovative tool quickly outshined wire wrapping, leading to the breadboards we know today, named for their historical predecessors but designed for the modern maker.
Ever curious about what lies beneath the surface of a breadboard? Hidden behind its plastic facade and a layer of sticky foam, covered by yellow protective paper, lies the heart of the breadboard’s functionality: dozens of metal strips.
It’s best not to peel away this protective layer. We’ve done it here just to show you what’s inside.
../_images/2_breadboard_internal0.jpg
If you were to (though we strongly advise against it) pull out these metal parts with pliers, you’d discover that each piece is a metal clip with small teeth. Each strip features five teeth, correlating with the five holes on the breadboard’s surface for each row. The power rails have longer strips with fifty teeth.
../_images/2_breadboard_internal1.jpg
These tiny teeth are perfect for gripping onto the legs of electronic components. When a component is inserted into the breadboard, the clip opens slightly to snugly grasp the metal leg. Any other component inserted into the same row of teeth will be electrically connected.
../_images/2_breadboard_internal2.jpg
This clever design allows for easy and flexible prototyping without the need for soldering, making breadboards an essential tool for electronics enthusiasts and professionals alike.
Most breadboards have some numbers, letters and plus and minus signs on them. Although the labels will vary from breadboard to breadboard, the function is basically the same. These labels allow you to find the corresponding holes more quickly when building your circuit. The row numbers and column letters help you to precisely locate the holes on the breadboard, for example, hole “C15” is where column C intersects row 15.
../_images/2_breadboard_letter_number.jpg
The sides of the breadboard are usually distinguished by red and blue (or other colors), as well as plus and minus signs, and are usually used to connect to the power supply, known as the power bus. When building a circuit, it is common to connect the negative terminal to the blue (-) column and the positive terminal to the red (+) column.
../_images/2_breadboard_plus_minus.jpg
Resistor
  1. Locate a 220-ohm resistor.
../_images/2_220_resistor.png
Resistors help manage the flow of electricity in a circuit by converting electrical energy into heat. Each resistor has two wires, one on each end, allowing electricity to pass in either direction, which means they can be placed in any direction on the circuit.
A resistor’s ohm value tells us the amount of resistance it adds. A higher ohm value means more resistance. For instance, a 220-ohm resistor adds 220 ohms of resistance, and a 10 kiloohm resistor adds 10 kilo ohms.
To read a resistor’s value, check the color bands. This chart explains the meaning behind each color band on a resistor. The multiplier is represented in scientific notation, where the exponent indicates the number of zeros added to the number represented by the color bands. For instance, a 4-band resistor shown at the top of the chart starts with a green band. Green stands for the number 5, so the resistance value begins with 5. The second band is brown, so the next number is 1. The multiplier band is red, valued at 2, meaning we add two zeros. This results in a total resistance of 5100 ohms, or 5.1 kilohms (5.1kΩ).
../_images/2_resistor_card.png
The chart shown here represents all the resistors included in your kit. For this lesson, we’ll be using a 220-ohm resistor.
../_images/2_all_resistor.png
  1. Bend the leads of the resistor so they face the same direction.
../_images/2_220_resistor_pin.png
  1. Insert one lead into the top hole of the breadboard’s negative side, connecting the resistor to the power source. Insert the other lead of the 220 ohm resistor into hole 1b of the breadboard.
    Resistors are considered non-polarized components, meaning the direction they face in a circuit doesn’t matter.
../_images/2_connect_resistor.png
LED
  1. Find the red LED.
../_images/2_red_led.png
LEDs, or Light Emitting Diodes, are specialized electronic components that emit light when an electric current flows through them in a specific direction.
../_images/2_led_polarity.jpg
The most common LED colors are red, yellow, blue, green, and white, with the emitted light typically matching the color of the LED itself.
../_images/2_led_color.png
These devices are designed with two leads: a longer one known as the anode and a shorter one called the cathode. To function properly, the anode should be connected to the positive terminal of the power source, and the cathode should be connected to the negative terminal or ground. Some LEDs feature a flat edge on the side of the cathode to aid in correct placement.
../_images/2_led_pin.jpg
  1. Insert the cathode of the LED (the short lead) into hole 1e on the breadboard. This connects the LED to the 220Ω resistor. Remember, holes 1b and 1e are connected underneath the breadboard.
LEDs are considered to be polarized components, meaning that current can only flow through them in one direction. If you find that the LED does not light up, try swapping the connections.
../_images/2_connect_led.png
Jumper Wire
  1. Find a jumper wire.
Your kit includes jumper wires of different colors and lengths, all functioning the same. Use varying colors for easy circuit identification and shorter wires for a tidy setup. Each wire consists of a conductive core and an insulated coating to prevent unintended contacts.
../_images/2_wire_color.jpg
  1. Insert one end of the jumper wire into hole 1j on the breadboard. This connects the jumper wire to the LED, as holes 1f and 1j are linked underneath the breadboard. Insert the other end of the jumper wire into the top hole of the breadboard’s positive rail. Now, the jumper wire connects the LED and the ground wire together.
../_images/2_connect_wire.png
Arduino Uno R3
  1. Find your Arduino Uno R3.
../_images/1_uno_board.png
In this lesson, we’re using the Arduino Uno R3 as a power supply. Its 5V pin serves as the positive terminal and the GND pin as the negative terminal, supplying a steady 5V to the circuit.
../_images/1_uno_power_pin.png
However, connecting the power supply’s terminals directly without a load can cause a short circuit, generating heat and potentially causing damage or fire. Always include a load, like an LED or resistor, to prevent short circuits.
../_images/2_short_circuit.png
  1. Connect a wire from the positive rail on the right side of the breadboard to the 5V pin on the Arduino Uno R3. It is recommended to use a red or orange wire to represent the positive terminal, which can be particularly helpful for quickly identifying connections in complex projects.
../_images/2_uno_5v.png
  1. Finally, connect a wire from the negative rail on the left side of the breadboard to the GND pin on the Arduino Uno R3. A black or green wire is suggested for consistency, using the same color to represent the negative terminal across all circuits.
../_images/2_uno_gnd.png
  1. Finally, power the Arduino Uno R3 by connecting it to a computer or a power socket using the USB cable provided in the kit, and the LED should light up.
    ../_images/2_first_circuit.png
After connecting your Arduino Uno R3 and witnessing the LED light up, you’re not just looking at a simple circuit — you’re observing the fundamentals of electricity at work. Let’s delve into what makes your circuit come to life.
Understanding Electricity in Circuits
Electricity Essentials
The flow of electrons from the negative to the positive is what we understand as the actual electron flow. Initially, scientists like Ben Franklin believed that the current was a movement of positive charges, which is why conventional current is defined as flowing from positive to negative.
../_images/2_uno_current.png
However, in reality, electrons, which carry a negative charge, move from the negative terminal to the positive terminal. Most countries today still use the conventional current flow model. Thus, in diagrams and when designing electronic components, current is depicted as flowing from the positive to the negative terminal, even though electrons actually flow in the opposite direction.
../_images/2_uno_electron.png
  • A Traditional current direction
  • B Actual electron flow direction
  • C Electrons (not to scale)
  • D Wire
There are two types of current generated by a power source: alternating current (AC) and direct current (DC). A battery or a Microcontroller like Arduino Uno R3 provides DC, where the current flows in one direction—from the positive to the negative terminal.
With AC, however, the current changes direction periodically. The voltage in the circuit reverses as the current changes direction, compelling it to flow the other way. Most homes and buildings are powered by AC circuits, such as the 120 volts at 60 Hz from wall outlets in American homes or 220 volts at 50 Hz in many European homes.
Safety in Circuitry
When connecting a power source, a prudent approach is to attach the positive end to the circuit first, followed by the negative. Conversely, when disconnecting, you should remove the negative end first to prevent short circuits. This course utilizes low voltage and current, so there’s no risk of electric shock or injury. But good safety practices can prevent harm when working with higher voltages and currents, like replacing car batteries or repairing outlets.
Closed and Open Circuits
As electricity flows through the LED, resistor, jumper wires, and back into the breadboard’s negative rail, it forms what is known as a closed circuit. If you were to remove a wire from the breadboard, the LED would go out because the current has stopped — the circuit is now open.
../_images/2_open_circuit.png
By mastering these basics, you’re on your way to understanding and creating more complex electronics that power our world.
Questions:
  1. Remove the red wire from the breadboard and experiment by placing it in different holes on the breadboard. Observe any changes in the LED. Sketch the hole positions that allow the LED to light up.
  1. What happens if you reverse the pins of the LED? Will it light up? Why or why not?
