2.19 GAME - Fishing
Here, we play a fishing game with a button.
When the script is running, the fish swim left and right on the stage, you need to press the button when the fish is almost close to the hook (it is recommended to press it for a longer time) to catch the fish, and the number of fish caught will be recorded automatically.
Build the Circuit
The button is a 4-pin device, since the pin 1 is connected to pin 2, and pin 3 to pin 4, when the button is pressed, the 4 pins are connected, thus closing the circuit.
Build the circuit according to the following diagram.
Connect one of the pins on the left side of the button to pin 12, which is connected to a pull-down resistor and a 0.1uF (104) capacitor (to eliminate jitter and output a stable level when the button is working).
Connect the other end of the resistor and capacitor to GND, and one of the pins on the right side of the button to 5V.
Programming
We need to select an Underwater backdrop first, then add a Fish sprite and let it swim back and forth on the stage. Then draw a Fishhook sprite and control it by a button to start fishing. When the Fish sprite touches the Fishhook sprite in the hooked state (turns red), it will be hooked.
1. Adding a backdrop
Use the Choose a Backdrop button to add an Underwater backdrop.
2. Fishhook sprite
The Fishhook sprite is intended to have the effect that it normally stays underwater in a yellow state; when the button is pressed, it is in a fishing state (red) and it moves above the stage.
There is no Fishhook sprite in Pictoblox, we can modify the Glow-J sprite to look like a fishhook.
Add the Glow-J sprite via Choose a Sprite.
Now go to the Costumes page of the Glow-J sprite, select Cyan’s fill in the screen and remove it. Then change the J color to red and also reduce its width. The most important point to note is that you need to have the top of it just at the center point.
Use the Line tool to draw a line as long as possible from the center point up (line out of the stage). Now that the sprite is drawn, set the sprite name to Fishhook and move it to the right position.
When the green flag is clicked, set the sprite’s color effect to 30 (yellow), and set its initial position.
If the button is pressed, set the color effect to 0 (red, start fishing state), wait for 0.1 and then move the Fishhook sprite to the top of the stage. Release the button and let the Fishhook return to its initial position.
3. Fish sprite
The effect to be achieved by the Fish sprite is to move left and right on the stage, and when it encounters a Fishhook sprite in the fishing state, it shrinks and moves to a specific position and then disappears, and then clones a new fish sprite again.
Now add the fish sprite and adjust its size and position.
Create a variable score to store the number of fish caught, hide this sprite and clone it.
Show the clone of the fish sprite, switch its costume and finally set the initial position.
Make the fish sprite’s clone move left and right and bounce back when it touches the edge.
The fish sprite (of the clone) will not react when it passes the Fishhook sprite; when it touches the Fishhook sprite in the fishing state (turns red), it will be caught, at which point the score (variable score) +1, and it will also show a score animation (shrinks 40%, quickly moves to the position of the scoreboard and disappears). At the same time, a new fish is created (a new fish sprite clone) and the game continues.
You need to click on the color area in the [Touch color] block, and then select the eyedropper tool to pick up the red color of the Fishhook sprite on the stage. If you choose a color arbitrarily, this [Touch color] block will not work.
