πŸ‘‰ Ready to explore and create with us? Click [here] and join today!
2.9 Light Alarm Clock
In life, there are various kinds of time alarm clocks. Now let’s make a light-controlled alarm clock. When morning comes, the brightness of light increases and this light-controlled alarm clock will remind you that it’s time to get up.
../_images/10_clock.png
You Will Learn
  • Photoresistor working principle
  • Stopping sound playback and stopping scripts from running
Build the Circuit
A photoresistor or photocell is a light-controlled variable resistor. The resistance of a photoresistor decreases with increasing incident light intensity.
Build the circuit according to the following diagram.
Connect one end of the photoresistor to 5V, the other end to A0, and connect a 10K resistor in series with GND at this end.
So when the light intensity increases, the resistance of a photoresistor decreases, the voltage division of the 10K resistor increases, and the value obtained by A0 becomes larger.
../_images/photoresistor_circuit.png
Programming
1. Select a sprite
Delete the default sprite, click the Choose a Sprite button in the lower right corner of the sprite area, enter bell in the search box, and then click to add it.
../_images/10_sprite.png
2. Read the value of A0
Create two variables before and current. When green flag is clicked, read the value of A0 and store it in variable before as a reference value. In [forever], read the value of A0 again, store it in the variable current.
../_images/10_reada0.png
3. Make a sound
When the value of current A0 is greater than the previous 50, which represents the current light intensity is greater than the threshold, then let the sprite make a sound.
../_images/10_sound.png
4. Turning the sprite
Use [turn block] to make the bell sprite turn left and right to achieve the alarm effect.
../_images/10_turn.png
5. stop all
Stops the alarm when it has been ringing for a while.
../_images/10_stop.png
