Lesson 12 Joystick PS2ΒΆ
A joystick is an input device consisting of a stick that pivots on a base and reports its angle or direction to the device it is controlling. Joysticks are often used to control video games and robots. A Joystick PS2 is used here.
Components
1 * SunFounder Uno board
1 * USB data cable
1 * Joystick PS2 module
1 * 5-Pin anti-reverse cable
Principle
This module has two analog outputs (corresponding to X and Y coordinates) and one digital output representing whether it is pressed on Z axis.
Experimental Procedures
Step 1: Build the circuit
The wiring between the Joystick PS2 and SunFounder Uno board:
Joystick PS2 |
SunFounder Uno |
GND |
GND |
VCC |
5V |
Bt |
7 |
x |
A0 |
y |
A1 |
Step 2: Open the code file
Step 3: Select correct Board and Port
Step 4: Upload the sketch to the SunFounder Uno board
Now, push the rocker and the coordinates of X and Y axes displayed on Serial Monitor will change accordingly; press the button, and the coordinate of Z=0 will also be displayed.
