3.6 Controlling a Water Pump
In this lesson, we’ll learn how to control a small water pump using the Raspberry Pi Pico 2 and an L293D motor driver. A small centrifugal pump can be used for projects like automatic plant watering systems or creating miniature water features. Controlling the pump is similar to controlling a DC motor, as it uses the same principles.
What You’ll Need
Newton Lab Kit |
450+ |
SN |
COMPONENT |
QUANTITY |
Micro USB Cable |
Several |
7 |
9V Battery |
8 |
Important Notes Before You Begin
Pump Setup: Connect the tubing to the pump’s outlet. Submerge the pump in water before powering it on.
Avoid Dry Running: Ensure the pump is always submerged. Running the pump dry can cause overheating and damage the motor.
Prevent Clogging: If you’re using the pump for watering plants, make sure the water is free of debris to prevent clogging.
Priming the Pump: If water doesn’t come out initially, there might be air trapped in the tubing. You may need to prime the pump by allowing water to flow through to remove air bubbles.
Circuit Diagram
L293D is a motor driver chip, EN is connected to 5V to make L293D work. 1A and 2A are the inputs connected to GP15 and GP14 respectively; 1Y and 2Y are the outputs connected to the two ends of the motor.
Y (output) is in phase with A (input), so if GP15 and GP14 are given different levels respectively, the direction of motor rotation can be changed.
Wiring Diagram
In this circuit, you will see that the button is connected to the RUN pin. This is because the motor is operating with too much current, which may cause the Pico to disconnect from the computer, and the button needs to be pressed (for the Pico’s RUN pin to receive a low level) to reset.
Writing the Code
We’ll write a simple MicroPython program to start the pump. The pump will run continuously once the code is executed.
Open the
3.6_pumping.pyfromnewton-lab-kit/micropythonor copy the code into Thonny, then click “Run” or press F5.Ensure the correct interpreter is selected: MicroPython (Raspberry Pi Pico).COMxx.
import machine
import utime
# Define the control pins connected to the L293D
pump_in1 = machine.Pin(14, machine.Pin.OUT)
pump_in2 = machine.Pin(15, machine.Pin.OUT)
# Start the pump by setting IN1 high and IN2 low
pump_in1.high()
pump_in2.low()
# Keep the pump running indefinitely
utime.sleep(1)
When the code is running, the pump should start running, and water should flow through the tubing.
Understanding the Code
Import Modules:
machine: Access to hardware-related functions.utime: Time-related functions for delays.
Initialize Control Pins:
pump_in1andpump_in2control the pump via the L293D.pump_in1 = machine.Pin(14, machine.Pin.OUT) pump_in2 = machine.Pin(15, machine.Pin.OUT)
Start the Pump:
Sets the pump to run in one direction by applying a high signal to IN1 and a low signal to IN2.
pump_in1.high() pump_in2.low()
Keep the Pump Running:
An infinite loop keeps the program running.
while True: utime.sleep(1)
Troubleshooting Tips
Pump Doesn’t Start:
Check all wiring connections.
Ensure the power supply module is set to 5V and turned on.
Make sure the pump is submerged in water.
Pico Becomes Unresponsive:
If the Pico disconnects or the program stops, you may need to reset it.
Use the reset connection by momentarily connecting the RUN pin to GND.
Pump Continues Running After Stopping the Script:
The last state of the GPIO pins remains unchanged after stopping the script.
Reset the Pico to stop the pump by connecting RUN to GND.
Safety Precautions
Electrical Safety:
Be cautious when working with water and electronics.
Keep the Pico and other electronic components away from water to prevent damage or injury.
Pump Care:
Do not let the pump run dry.
Clean the pump regularly if using it with water that may contain particles.
Conclusion
In this lesson, you’ve learned how to control a small water pump using the Raspberry Pi Pico 2 and an L293D motor driver. This setup can be the foundation for projects like automated plant watering systems or miniature fountains.
