2.14 Water Level Detection
In this lesson, we will learn how to use a water sensor with the Raspberry Pi Pico 2 to detect the presence of water or measure the water level. This sensor is commonly used in projects related to rainfall detection, water level monitoring, and liquid leakage alerts.
How the Water Sensor Works
The water sensor has a series of exposed parallel wire traces that detect water droplets or measure the volume of water. As water comes into contact with these traces, the sensor outputs an analog signal. The more water that comes into contact with the sensor, the higher the output value, which can be read by the Raspberry Pi Pico 2’s analog-to-digital converter (ADC).
Do not fully submerge the sensor in water. Only the area with the exposed traces should come into contact with water.
Using the sensor in a humid environment while powered may cause the probe to corrode faster, so it is recommended to power the sensor only when taking readings.
What You’ll Need
Newton Lab Kit |
450+ |
SN |
COMPONENT |
QUANTITY |
Micro USB Cable |
Several |
Circuit Diagram
Wiring Diagram
Writing the Code
We’ll write a simple MicroPython program to read the analog value from the water sensor and print it to the console. As the water sensor is submerged, the value read by GP28 will increase.
Open the
2.14_feel_the_water_level.pyfromnewton-lab-kit/micropythonor copy the code into Thonny, then click “Run” or press F5.Ensure the correct interpreter is selected: MicroPython (Raspberry Pi Pico).COMxx.
import machine
import utime
# Initialize ADC on GP28
sensor = machine.ADC(28)
# Read the analog value from the sensor
value = sensor.read_u16()
print("Water level reading:", value)
utime.sleep(0.2) # Delay to avoid flooding the console with data
When the code is running, slowly submerge the water sensor into water, watching the values printed to the console. As the sensor detects more water, the printed value will increase.
Learn More: Using the Sensor for Leak Detection
We can also use the water sensor to detect liquid leakage by treating it like a digital sensor. Here’s how:
Measure the Baseline Value:
First, take a reading from the water sensor in a completely dry environment. Record this value to use as a threshold.
If the sensor’s reading goes above the baseline threshold, we can assume that the sensor is in contact with water, indicating a potential leak.
Leak Detection Code:
In this example, we’ll check if the sensor’s reading exceeds the threshold value (which you’ll need to set based on your environment).
import machine import utime # Initialize ADC on GP28 sensor = machine.ADC(28) # Set a threshold value based on dry readings (adjust as needed) threshold = 30000 while True: # Read the analog value from the sensor value = sensor.read_u16() # Check if the value exceeds the threshold, indicating water exposure if value > threshold: print("Liquid leakage detected!") utime.sleep(0.2) # Delay for readability
The program checks if the sensor’s value exceeds a predefined threshold. If the value is higher, it prints a message indicating water or liquid leakage.
Practical Applications
Leak Detection: Place the sensor near water pipes, and it can alert you if a pipe starts leaking.
Water Level Monitoring: Use the sensor in tanks or containers to monitor the water level and trigger alerts or actions.
Rain Detection: Install the sensor outdoors (with appropriate protection) to detect rainfall.
Conclusion
The water sensor is a simple yet powerful tool for detecting water levels or potential liquid leakage. By integrating it with the Raspberry Pi Pico 2, you can create responsive and useful water detection systems for a variety of applications.
