6.4 Using an Infrared Remote Control
In this lesson, we’ll learn how to use an infrared (IR) remote control and an IR receiver module with the Raspberry Pi Pico 2. This will allow us to receive and decode signals from an IR remote, enabling us to control our projects wirelessly.
What You’ll Need
Newton Lab Kit |
450+ |
SN |
COMPONENT |
QUANTITY |
Micro USB Cable |
Several |
Understanding Infrared Communication
Infrared communication involves transmitting data wirelessly using infrared light. Common household devices like TVs and DVD players use IR remote controls for operation.
IR Transmitter (Remote Control): Emits modulated infrared light when a button is pressed.
IR Receiver Module: Detects the modulated IR light and converts it into electrical signals that can be decoded.
Circuit Diagram
Wiring Diagram
Writing the Code
Let’s write a MicroPython script to receive and decode IR signals from the remote control.
Open the
6.4_ir_remote_control.pyfromnewton-lab-kit/micropythonor copy the code into Thonny, then click “Run” or press F5.Ensure the correct interpreter is selected: MicroPython (Raspberry Pi Pico).COMxx.
Here you need to use the libraries in
ir_rxfolder, please check if it has been uploaded to Pico, for a detailed tutorial refer to Upload the Libraries to Pico.
from machine import Pin
from ir_rx.nec import NEC_8 # Adjust based on your remote's protocol
from ir_rx.print_error import print_error
# Initialize the IR receiver pin
ir_pin = Pin(17, Pin.IN)
# Callback function to handle received data
def ir_callback(data, addr, ctrl):
if data < 0: # Repeat code or error
key = decode_key(data)
print("Received Key:", key)
# Function to decode the received data into key presses
def decode_key(data):
key_codes = {
0x45: "POWER",
0x46: "MODE",
0x47: "MUTE",
0x44: "PLAY/PAUSE",
0x40: "BACKWARD",
0x43: "FORWARD",
0x07: "EQ",
0x15: "-",
0x09: "+",
0xD: "U/SD",
0x16: "0",
0x19: "cycle",
0xC: "1",
0x5E: "3",
0x18: "2",
0x8: "4",
0x1C: "5",
0x5A: "6",
0x42: "7",
0x52: "8",
0x4A: "9",
0x0: "ERROR",
# Add more key codes based on your remote
return key_codes.get(data, "UNKNOWN")
# Instantiate the IR receiver
ir = NEC_8(ir_pin, ir_callback)
ir.error_function(print_error) # Optional: to print errors
time.sleep(1) # Keep the main thread alive
ir.close()
print("Program terminated")
When you run this code and press buttons on your infrared remote control, the Thonny Shell (or any other serial monitor) will display the name of the key you pressed. For example, if you press the “PLAY” button on the remote, the Shell will show “Received Key: PLAY”.
Understanding the Code
Import Modules:
ir_rx.nec.NEC_8: The NEC protocol decoder for 8-bit addresses.print_error: Function to print error messages.
import time from machine import Pin from ir_rx.nec import NEC_8 from ir_rx.print_error import print_error
Initialize IR Receiver Pin:
Define Callback Function:
This function is called automatically when data is received. The data parameter contains the key code.
def ir_callback(data, addr, ctrl): if data < 0: pass # Ignore repeat codes else: key = decode_key(data) print("Received Key:", key)
Decode Key Function:
Maps received key codes to human-readable labels.
def decode_key(data): key_codes = { 0x45: "POWER", 0x46: "MODE", 0x47: "MUTE", 0x44: "PLAY/PAUSE", 0x40: "BACKWARD", 0x43: "FORWARD", 0x07: "EQ", 0x15: "-", 0x09: "+", 0xD: "U/SD", 0x16: "0", 0x19: "cycle", 0xC: "1", 0x5E: "3", 0x18: "2", 0x8: "4", 0x1C: "5", 0x5A: "6", 0x42: "7", 0x52: "8", 0x4A: "9", 0x0: "ERROR", # Add more key codes based on your remote } return key_codes.get(data, "UNKNOWN")
Instantiate IR Receiver:
Sets up the IR receiver with the callback function.
ir = NEC_8(ir_pin, ir_callback) ir.error_function(print_error)
Main Loop:
Keeps the program running to listen for IR signals. Gracefully handles program termination.
try: while True: time.sleep(1) except KeyboardInterrupt: ir.close() print("Program terminated")
Applications
Control Projects Wirelessly: Use the IR remote to control LEDs, motors, or other peripherals.
Build a Universal Remote Decoder: Expand the code to handle multiple protocols or remotes.
Conclusion
In this lesson, you’ve learned how to use an IR receiver with the Raspberry Pi Pico 2 to decode signals from an infrared remote control. This enables you to add wireless control to your projects using common household remotes.
