5.3 Creating a Time Counter with a 4-Digit 7-Segment Display
In this lesson, we’ll learn how to use a 4-digit 7-segment display with the Raspberry Pi Pico 2 to create a simple time counter. The display will count up every second, showing the elapsed time in seconds.
What You’ll Need
Newton Lab Kit |
450+ |
SN |
COMPONENT |
QUANTITY |
Micro USB Cable |
Several |
4(220Ω) |
7 |
Understanding the 4-Digit 7-Segment Display
A 4-digit 7-segment display consists of four individual 7-segment displays combined into a single module. Each digit shares the same segment control lines (a to g and dp), but each digit has its own common cathode control. This configuration allows us to control which digit is active at any given time.
To display different numbers on each digit using shared segment lines, we use a technique called multiplexing. We rapidly switch between digits, updating one digit at a time, but so quickly that it appears as if all digits are displayed simultaneously due to the persistence of vision.
Circuit Diagram
Here the wiring principle is basically the same as 5.1 Using the 74HC595 Shift Register, the only difference is that Q0-Q7 are connected to the a ~ g pins of the 4-digit 7-segment display.
Then G10 ~ G13 will select which 7-segment display to work.
Wiring Diagram
Segment Connections (through 220 Ω resistors):
Q0 → Segment a
Q1 → Segment b
Q2 → Segment c
Q3 → Segment d
Q4 → Segment e
Q5 → Segment f
Q6 → Segment g
Q7 → Segment dp (decimal point)
Common Cathode Connections (Digit Select Pins):
Digit 1 (Leftmost Digit): Connect to GP10 on the Pico
Digit 2: Connect to GP11
Digit 3: Connect to GP12
Digit 4 (Rightmost Digit): Connect to GP13
Writing the Code
Let’s write a MicroPython program to create a time counter that increments every second and displays the count on the 4-digit 7-segment display.
Open the
5.3_time_counter.pyfromnewton-lab-kit/micropythonor copy the code into Thonny, then click “Run” or press F5.Ensure the correct interpreter is selected: MicroPython (Raspberry Pi Pico).COMxx.
import machine
import utime
# Define the binary codes for each digit (0-9)
SEGMENT_CODES = [
0x3F, # 0
0x06, # 1
0x5B, # 2
0x4F, # 3
0x66, # 4
0x6D, # 5
0x7D, # 6
0x07, # 7
0x7F, # 8
0x6F # 9
# Initialize the control pins for 74HC595
SDI = machine.Pin(18, machine.Pin.OUT) # Serial Data Input (DS)
RCLK = machine.Pin(19, machine.Pin.OUT) # Register Clock (STCP)
SRCLK = machine.Pin(20, machine.Pin.OUT) # Shift Register Clock (SHCP)
# Initialize digit select pins (common cathodes)
digit_pins = [
machine.Pin(10, machine.Pin.OUT), # Digit 1
machine.Pin(11, machine.Pin.OUT), # Digit 2
machine.Pin(12, machine.Pin.OUT), # Digit 3
machine.Pin(13, machine.Pin.OUT) # Digit 4
# Function to send data to 74HC595
def shift_out(data):
RCLK.low()
for bit in range(7, -1, -1):
SRCLK.low()
bit_val = (data >> bit) & 0x01
SDI.value(bit_val)
SRCLK.high()
RCLK.high()
# Function to display a digit at a specific position
def display_digit(position, digit):
# Turn off all digits
for dp in digit_pins:
dp.high()
# Send segment data
shift_out(SEGMENT_CODES[digit])
# Activate the selected digit (common cathode is active low)
digit_pins[position].low()
# Small delay to allow the digit to be visible
utime.sleep_ms(5)
# Turn off the digit
digit_pins[position].high()
# Function to display a number on the 4-digit display
def display_number(number):
# Extract individual digits
digits = [
(number // 1000) % 10,
(number // 100) % 10,
(number // 10) % 10,
number % 10
# Display each digit rapidly
for i in range(4):
display_digit(i, digits[i])
# Main loop
counter = 0
last_update = utime.ticks_ms()
# Update the counter every 1000 ms (1 second)
current_time = utime.ticks_ms()
if utime.ticks_diff(current_time, last_update) >= 1000:
counter += 1
if counter > 9999:
counter = 0
last_update = current_time
# Continuously refresh the display
display_number(counter)
When you run this code, the 4-digit 7-segment display will function as a counter, incrementing the displayed number by 1 every second, starting from 0 up to 9999, then resetting to 0 and repeating the cycle continuously.
Understanding the Code
Import Modules:
machine: Provides access to GPIO pins and hardware functions.utime: Contains time-related functions for delays and timing.
Define Segment Codes:
Each entry corresponds to the segments that need to be lit to display a digit. The values are in hexadecimal format.
# Define the binary codes for each digit (0-9) SEGMENT_CODES = [ 0x3F, # 0 0x06, # 1 0x5B, # 2 0x4F, # 3 0x66, # 4 0x6D, # 5 0x7D, # 6 0x07, # 7 0x7F, # 8 0x6F # 9 ]
Initialize Control Pins:
Assigns the Pico’s GPIO pins to control the 74HC595.
SDI = machine.Pin(18, machine.Pin.OUT) RCLK = machine.Pin(19, machine.Pin.OUT) SRCLK = machine.Pin(20, machine.Pin.OUT)
Initialize Digit Select Pins:
Controls which digit is active. Active low (common cathode).
digit_pins = [ machine.Pin(10, machine.Pin.OUT), machine.Pin(11, machine.Pin.OUT), machine.Pin(12, machine.Pin.OUT), machine.Pin(13, machine.Pin.OUT) ]
Define the
shift_outFunction:Sends 8 bits of data to the 74HC595.
Shifts out the data starting from the most significant bit (MSB).
Pulses the shift and register clocks appropriately.
def shift_out(data): RCLK.low() for bit in range(7, -1, -1): SRCLK.low() bit_val = (data >> bit) & 0x01 SDI.value(bit_val) SRCLK.high() RCLK.high()
Define the
display_digitFunction:Turns off all digits.
Sends the segment code for the digit.
Activates the specified digit by setting its pin low.
Adds a small delay to make the digit visible.
Turns off the digit after displaying.
def display_digit(position, digit): for dp in digit_pins: dp.high() shift_out(SEGMENT_CODES[digit]) digit_pins[position].low() utime.sleep_ms(5) digit_pins[position].high()
Define the
display_numberFunction:Extracts each digit from the number.
Calls
display_digitfor each digit rapidly to create the multiplexing effect.
def display_number(number): # Extract individual digits digits = [ (number // 1000) % 10, (number // 100) % 10, (number // 10) % 10, number % 10 ] # Display each digit rapidly for i in range(4): display_digit(i, digits[i])
Main Loop:
Increments the counter every second.
Resets the counter after reaching 9999.
Continuously calls
display_numberto refresh the display.
counter = 0 last_update = utime.ticks_ms() while True: current_time = utime.ticks_ms() if utime.ticks_diff(current_time, last_update) >= 1000: counter += 1 if counter > 9999: counter = 0 last_update = current_time display_number(counter)
Experimenting Further
Add a Reset Button:
Connect a button to the Pico to reset the counter when pressed.
Display Different Data:
Modify the code to display sensor readings, such as temperature or light levels.
Adjust Display Brightness:
Change the
utime.sleep_ms(5)delay in thedisplay_digitfunction to adjust how long each digit is displayed, affecting brightness.Create a Stopwatch:
Implement start, stop, and reset functionality to use the display as a stopwatch.
Conclusion
In this lesson, you’ve learned how to use a 4-digit 7-segment display with a 74HC595 shift register to create a time counter using the Raspberry Pi Pico 2. By understanding multiplexing and efficient timing, you can display dynamic information on multi-digit displays using minimal GPIO pins.
